Still need help with my Atomic 4 ring gear issue Anybody
2 messages2010-08-29 12:41 through 2010-08-30 02:17 UTC
Pierre2010-08-29 12:41
Hi, the starter on my atomic 4 stuck on the on position grinding one side of my ring gear, does anyone know if I can remove the ring gear by heating it up or another method, take it off and turn it around so that I end up with fresh teeth??? Thanks Pierre
Re: [Cal_Boats] Still need help with my Atomic 4 ring gear issue Anybody (Pierre)
ld… [at] comcast.net2010-08-30 02:17 UTC
Pierre: Call the parts ordering number for Moyer Marine (moyermarine.com) ...Ken will answer the phone and he will answer your question. If your solution will not work he will have a part to help you. I have spent a lot of time talking to Ken and he will give you as much time as you need and is incredibley helpful. Les Hester formerly 3-29#1005 Now T34c#198 Sable From: Pierre <pi… [at] yahoo.com> To: Cal Boats <Ca… [at] yahoogroups.com> Sent: Sun, 29 Aug 2010 12:41:24 -0000 (UTC) Subject: [Cal_Boats] Still need help with my Atomic 4 ring gear issue Anybody Hi, the starter on my atomic 4 stuck on the on position grinding one side of my ring gear, does anyone know if I can remove the ring gear by heating it up or another method, take it off and turn it around so that I end up with fresh teeth??? Thanks Pierre
