23 messages2010-08-26 19:48 UTCthrough 2010-08-31 20:20 UTC
Drilling Stainless
Wayne Gillikin2010-08-26 19:48 UTC
I have to drill several small holes (for #6 screws) in 1 7/8" stainless tubing.
I got the right sized Cobolt bits as the group recommended awhile ago. My
problem is that the placement needs to be reasonably accurate. How do I keep
the drill bit from walking all over the tube when I try to drill it. Is there
some type of guide that will hold the bit steady while I drill? Something I can
buy or make? Any ideas?
Wayne
Re: [Cal_Boats] Drilling Stainless
GE… [at] comcast.net2010-08-26 19:53 UTC
Try a sharp punch tap with hammer to set a start.
Sent: Thursday, August 26, 2010 3:48:09 PM
Subject: [Cal_Boats] Drilling Stainless
I have to drill several small holes (for #6 screws) in 1 7/8" stainless tubing. I got the right sized Cobolt bits as the group recommended awhile ago. My problem is that the placement needs to be reasonably accurate. How do I keep the drill bit from walking all over the tube when I try to drill it. Is there some type of guide that will hold the bit steady while I drill? Something I can buy or make? Any ideas?
Wayne
RE: [Cal_Boats] Drilling Stainless (Wayne)
Michael Robinson2010-08-26 20:03 UTC
Center punch:
http://www.google.com/products/catalog?q=center+punch&hl=en&cid=17705507848971684611&ei=ucd2TMrKH4faNZ7BqMUB&sa=title&ved=0CFEQ8wIwBjgA#p
Drill slowly and lube with cutting oil.
Mike
Date: Thu, 26 Aug 2010 12:48:09 -0700
Wayne
Re: [Cal_Boats] Drilling Stainless (Wayne)
Kirk Grier2010-08-26 20:08 UTC
Maybe something like these specifically for drilling in pipe/tubing.
http://www.skygeek.com/ats-36.html
http://www.trick-tools.com/Punch_Drilling/drill_rite_drill_guide.html
Kirk
On 8/26/2010 1:03 PM, Michael Robinson wrote:
> Center punch:
> <http://www.google.com/products/catalog?q=center+punch&hl=en&cid=17705507848971684611&ei=ucd2TMrKH4faNZ7BqMUB&sa=title&ved=0CFEQ8wIwBjgA#p>
> Drill *_slowly_* and lube with cutting oil.
> */Mike/*
> From: wa… [at] yahoo.com
> Thanks,
> Wayne
Kirk Grier
kg… [at] kirkgrier.com
ti… [at] ch2m.com2010-08-26 21:28 UTC
Drilling on something round is problematic, if accuracy is required to template two pieces then there are other problems to deal with.
It might help to know what you are doing.
I sometimes drill only one hole in a pattern, then put pieces together, then drill the farthest hole while the assy is clamped., insert the bolt and continue – like the torque pattern on a head of a car.
If the holes have to match either side of the tube, then usually drilling two holes is best – both from the outside.
dEmO
in Plutoniumville
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of GE… [at] comcast.net
Sent: Thursday, August 26, 2010 12:53 PM
To: Cal Boats
Subject: Re: [Cal_Boats] Drilling Stainless
Wayne
Allen Edwards2010-08-26 21:30 UTC
And a drill press and a machine vice. Also, drill a hole 1/2 the diameter
first.
> ----- Original Message -----
> From: "Wayne Gillikin" <wa… [at] yahoo.com>
> Thanks,
> Wayne
Gerald Sobel2010-08-26 22:36 UTC
Wayne,
An idea popped into my head. Take a short piece of one by four, say six inches long. Cut a V-shape about half an inch deep using two cuts of a saw at 45 degrees relative to the wood surface, in the middle accross it, then drill a hole thru the middle of the V holding the drill as vertical as you can. Then clamp the V- shape to the tube using one or two C-clamps, and then drill through the wood hole to make your hole. I've never tried doing that that way, but I bet it would work. If you need to install a two hole bracket, say, bolt the part to the tube and use the second hole in the bracket to find and make the second drill hole.
Hope it works.
Date: Thursday, August 26, 2010, 12:48 PM
Thanks,Wayne
chris1232010-08-26 22:56 UTC
In Rock Hall two boats down a lad was drilling his SS tubing to repair his
Bimini. He had this rather cool guide that clamped onto the tube and held
the bit steady while he was drilling. Asked where he got it, he said ebay.
Never seen it again and cant find it. Anyone have a clue as that was one
handy piece of kit.
On Thu, Aug 26, 2010 at 4:03 PM, Michael Robinson <mi… [at] hotmail.com
> wrote:
> Center punch:
> Drill *slowly* and lube with cutting oil.
> *Mike*
> Thanks,
> Wayne
James Pollock2010-08-26 23:13 UTC
You need to use a sharp center punch. Remember to use some oil to lubricate and
cool the bit, or you could burn up the drill bit tip.
Wayne
Husar, Charlie [USA]2010-08-27 00:50 UTC
Half of a number 6 is a dang small hole. It does indicate that a a very stable set-up is needed with good speed and pressure control to keep from snapping a bunch of bits (of course meaning that the B&D variable hand drill probably will be hard put to do the trick). Might work with a lot of caution.
Sent: Thursday, August 26, 2010 5:31 PM
And a drill press and a machine vice. Also, drill a hole 1/2 the diameter first.
On Thu, Aug 26, 2010 at 12:53 PM, <GE… [at] comcast.net<mailto:GE… [at] comcast.net>> wrote:
From: "Wayne Gillikin" <wa… [at] yahoo.com<mailto:wa… [at] yahoo.com>>
To: "Cal Boats" <Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com>>
Wayne
Gerald Sobel2010-08-27 04:30 UTC
Yup, number six is already pretty small. Sounds like another case where...silly cone grease to the rescue!
--- On Thu, 8/26/10, Husar, Charlie [USA] <hu… [at] bah.com> wrote:
Subject: RE: [Cal_Boats] Drilling Stainless
Date: Thursday, August 26, 2010, 5:50 PM
caution.
Edwards
To:
Stainless
And
first.
Try a sharp
2010 3:48:09 PM
Stainless
ideas?
Wayne
Gerald Sobel2010-08-27 04:35 UTC
PS. The reason I recommended making a simple wooden jig to make the hole in my previous reply is, if this is a stanchion, and, say, not very well secured to a fiberglass boat deck, it might not be a good idea to give it a smart, sharp wack with a ball peen hammer and a center punch. Of course, on the other hand, if'n it isn't well secured, it would be a good opportunity to remove it from the boat and refasten it properly with a broad base plate below deck.
Date: Thursday, August 26, 2010, 9:30 PM
caution.
Edwards
To:
Stainless
And
first.
Try a sharp
2010 3:48:09 PM
Stainless
ideas?
Wayne
Chuck Lennox2010-08-27 05:25 UTC
Wayne
You could build a jig out of wood and use a drill bushing to guide the drill.
Using a 2x4, drill a 1 7/8 hole. Cut though center of hole. Now you install a
drill bushing for your size drill in one half of 2x4.
You can make a bushing or buy one
http://www.mcmaster.com/#drill-bushings-and-liners/=8kwlfn this is just a
example of a # 6 bushing.
I have built bushings out of brass, aluminum and steel. It depends on have many
holes you are going to drill.
Cut a small amount from the second unused half (for better clamping action).
Center punch drill site. Clamp the two halves together. Drill slow and use
cutting oil.
Tim's idea of drill both sides does work better than drilling straight though.
I don't know what tooling you have. If you have a drill press it goes much
better.
Sent: Thu, August 26, 2010 12:48:09 PM
Wayne
Chuck Lennox2010-08-27 05:44 UTC
i found this on the net
If they have the correct bushing this would be a cool way to go.
Chuck
Sent: Thu, August 26, 2010 10:25:32 PM
Wayne
cutting oil.
better.
Wayne
Wayne Gillikin2010-08-27 17:20 UTC
Thanks, Kirk. Thats the kind of thing I was hoping to find. The jig looks like
it will make the job fool-proof.
Regards,
Wayne
Sent: Thu, August 26, 2010 4:08:39 PM
Subject: Re: [Cal_Boats] Drilling Stainless (Wayne)
Kirk
>Center punch:
>Mike
>Thanks,
>Wayne
-- Kirk Grier kg… [at] kirkgrier.com
Tom Vandiver2010-08-28 08:52 UTC
?? Plutoniumville Is that near Unobtanium City?
Tom Vandiver
Sent: Thu, August 26, 2010 4:28:35 PM
dEmO
in Plutoniumville
From:Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of
To: Cal Boats
Wayne
Gerald Sobel2010-08-28 09:06 UTC
Gad, the last thing we need is a Cal 40 with radioactive contamination to add to its unfortunate mid ocean experience with antibiotic resistant flesh eating bacteria!
dEMo is going to turn into the 'Monster from the Blue Lagoon'. Am dating myself?
Timmothy, are you working to clean up the Hanford atomic bomb building site?
Date: Saturday, August 28, 2010, 1:52 AM
Tom Vandiver
dEmO
in Plutoniumville
To: Cal Boats
Wayne
ti… [at] ch2m.com2010-08-28 15:48 UTC
Jerry – good guess – yes dEmO is at Hanford dEmOing the plutonium reactors and site(s) of the (IN)famous Manhattan project…and cold war.
I thought sanding the bottom of the Cal 40 was difficult?
Try it with materials that” bite back!”
I have also located and supported the local brews:
· Halflife Hefeweizen
· Atomic Amber
· Plutonium Porter
· Oppenheimer Oatmeal Stout
· Iridium IPA…and discovered the beeriodic table of ingredients.
Sent: Saturday, August 28, 2010 2:06 AM
Tom Vandiver
dEmO
in Plutoniumville
To: Cal Boats
Wayne
Next thing in Nav lights was: RE: [Cal_Boats] Drilling Stainless
Gerald Sobel2010-08-28 18:53 UTC
dEMo
Is wearing a lead jock strap legal while racing a centerboard dinghy?
Enquiring minds don't wanna know.
You could write an article in Practical Sailor "Emergency Navigation Lites Made from Long Lasting Materials from Super-fund Site Needs no Batteries"
Date: Saturday, August 28, 2010, 8:48 AM
war.
Halflife Hefeweizen
Atomic Amber
Plutonium Porter
Sobel
dating myself?
Tom Vandiver
"ti… [at] ch2m.com" <ti… [at] ch2m.com>
Drilling
It
I
If
dEmO
in
Plutoniumville
To: Cal Boats
Try a sharp punch
I
Wayne
Plutoniumville
ti… [at] ch2m.com2010-08-31 14:45 UTC
Just in case there was interest.. the project I am on.
http://www.neimagazine.com/story.asp?sectioncode=76&storyCode=2057284
Plutonium -Ville.
Sailing content – stopping the waste from reaching the Columbia River
dEmO
Tom Vandiver
dEmO
in Plutoniumville
To: Cal Boats
Wayne
Re: [Cal_Boats] Plutoniumville
chris1232010-08-31 18:45 UTC
Great job. Now I know why I enjoy your posts. Used to work for your
competitor Agra-Moneco now AMEC as an environmental consultant.
Sailing content; monitoring ice floes in the arctic to see if a CAL-20 can
do the North West passage. As of yesterday, its was open. Only 1500 miles
from Baffin Island to Tuk and with a 3 foot draft, its shoal friendly. Short
season however..:)
http://nsidc.org/data/seaice_index/images/daily_images/N_daily_extent_hires.png
(and if you think I;m serious I have property for sale in Florida)
> Plutonium -Ville.
> dEmO
> Behalf Of *Gerald Sobel
> *Sent:* Saturday, August 28, 2010 2:06 AM
> *Subject:* Re: [Cal_Boats] Drilling Stainless
> eating bacteria!
> myself?
> site?
> Jerry
> --- On *Sat, 8/28/10, Tom Vandiver <bs… [at] yahoo.com>* wrote:
> From: Tom Vandiver <bs… [at] yahoo.com>
> Tom Vandiver
> *From:* "ti… [at] ch2m.com" <ti… [at] ch2m.com>
> *Sent:* Thu, August 26, 2010 4:28:35 PM
> *Subject:* RE: [Cal_Boats] Drilling Stainless
> dEmO
> in Plutoniumville
> Behalf Of *GE… [at] comcast.net
> *Sent:* Thursday, August 26, 2010 12:53 PM
> *To:* Cal Boats
> Thanks,
> Wayne
RE: [Cal_Boats] Plutoniumville
r good2010-08-31 19:53 UTC
doesn't almost everyone have property for sale in Florida? So when will you begin lining up crew for the NW Passage trip?
Date: Tue, 31 Aug 2010 14:45:37 -0400
Subject: Re: [Cal_Boats] Plutoniumville
Great job. Now I know why I enjoy your posts. Used to work for your competitor Agra-Moneco now AMEC as an environmental consultant.
Sailing content; monitoring ice floes in the arctic to see if a CAL-20 can do the North West passage. As of yesterday, its was open. Only 1500 miles from Baffin Island to Tuk and with a 3 foot draft, its shoal friendly. Short season however..:)
Plutonium -Ville.
dEmO
Tom Vandiver
dEmO
in Plutoniumville
To: Cal Boats
Wayne
mike farrell2010-08-31 20:20 UTC
I'll Crew if you buy this Bridge I have for sale at a reduced rate for Labor
Day!!
Mu Best, Mike
To: ca… [at] yahoogroups.com
Sent: Tue, August 31, 2010 12:53:41 PM
Subject: RE: [Cal_Boats] Plutoniumville
however..:)
>Plutonium -Ville.
>dEmO
>Gerald Sobel
>bacteria!
>myself?
>Jerry
>Tom Vandiver
>From:"ti… [at] ch2m.com" <ti… [at] ch2m.com>
>dEmO
>in Plutoniumville
>To: Cal Boats
>Thanks,
>Wayne
