Re: Cal 25 Jib Fair lead
2 messages2010-09-17 14:17 UTCthrough 2010-09-17 16:42 UTC
Lee Jay Karns2010-09-17 14:17 UTC
I will measure the track and report back to you which size I have. Thanks for your response. Bestest, Lee >D ()->--- /\ If you are going to be dumb, you better be tough. ******************* office:440.333.5271 cell:440.227.5719 fax:440.356.0978 *******************
RE: [Cal_Boats] Re: Cal 25 Jib Fair lead
Husar, Charlie [USA]2010-09-17 16:42 UTC
Lee, here are some shots of the track. If your boat has not been reworked, you have the old track. That was the original equipment. The new blocks will not fit the old track because the lip on the old track is vertically fatter than the new stuff. The repaired (note the screw in the set pin) bullseye block is used at the back of the tack to create a rising line feed into the winch, thus reducing sheet overrides. The new track comes in 2 versions, one version (shown) has more pin-stop holes to allow more granular adjustment. By the by, the bullseye block can be replaced with plain old bullseye bolted directly into the deck. I can show some pictures of that if you like. Cheers Charlie From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Lee Jay Karns Sent: Friday, September 17, 2010 10:18 AM To: Ca… [at] yahoogroups.com Subject: [Cal_Boats] Re: Cal 25 Jib Fair lead I will measure the track and report back to you which size I have. Thanks for your response. Bestest, Lee >D ()->--- /\ If you are going to be dumb, you better be tough. ******************* office:440.333.5271 cell:440.227.5719 fax:440.356.0978 *******************
