9 messages2008-03-14 23:09 UTCthrough 2010-09-23 16:08 UTC
Spreaders
st… [at] us.ul.com2008-03-14 23:09 UTC
New spreaders arrived today...Just had to show 'em off.
Steve Urbanski
Elizabeth Grace
1972 Cal 27 Pop-top #141
Chicago, IL
(See attached file: spreaders.pdf)
- For more information about UL, its Marks, and its services for
EMC, quality registrations and product certifications for global
markets, please access our web sites at http://www.ul.com and
http://www.ulc.ca or contact your local sales representative. --
********* Internet E-mail Confidentiality Disclaimer **********
This e-mail message may contain privileged or confidential
information. If you are not the intended recipient, you may not
disclose, use, disseminate, distribute, copy or rely upon this
message or attachment in any way. If you received this e-mail
message in error, please return by forwarding the message and
its attachments to the sender.
UL and its affiliates do not accept liability for any errors,
omissions, corruption or virus in the contents of this message
or any attachments.
Re: [Cal_Boats] Spreaders
Chris Campbell2008-03-17 14:32 UTC
Cool! Explain please. Looks like there's an end cap that captures
the shroud, plus two holes for seizing wire to hold the tip in vertical
position?
Re: [Cal_Boats] Spreaders (Chris)
st… [at] us.ul.com2008-03-19 12:41 UTC
I stumbled onto the JSI site: http://www.newjsi.com/spars_spreaders.aspx
somehow through Google. I had planned to make new spreaders using spruce
from Aircraft Spruce this year since the old spreaders were getting rough.
JSI did a superior job (In my opinion). About two weeks turnaround (just
what they said - which is rare these days). They weld the airfoil shape to
an aluminum block which is machined to match the shape of your old
spreaders, then finish it off with the captivating assembly on the tip.
Kinda expensive since the spreaders approached 25% of what I paid for the
whole boat.
Here are a few more pictures.
(See attached file: spreaders2.pdf)
Steve Urbanski
Elizabeth Grace
Chicago, IL
Ca… [at] yahoogroups.com wrote on 03/17/2008 09:32:41 AM:
> captures the shroud, plus two holes for seizing wire to hold the tip
> in vertical position?
> Chris Campbell
or any attachments.
Chris Campbell2008-03-19 13:24 UTC
> (just what they said - which is rare these days). They weld the
> airfoil shape to an aluminum block which is machined to match the
> shape of your old spreaders, then finish it off with the captivating
> assembly on the tip. Kinda expensive since the spreaders approached
> 25% of what I paid for the whole boat.
Well, we all know that price is no measure of the value of our boats
(and I'm not kidding at all about that). And I always try to bear in
mind that the boat's equipment is my protection against harm in a
dangerous environment. None of us breathe through gills or can adjust
our body temp downward. Finally, the way we prepare and maintain our
boats reflects somewhat on our general competence. We've all known
people who had nice boats that were poorly maintained and always on the
verge of some disaster--hardware failing, pins falling out, running
rigging breaking. If you needed help in a difficult situation, would
you look to that skipper or the one with the boat that was always well
kept and organized?
That said, I did do a repair on my old spruce spreaders (other boat)
last spring. The boat has a spruce mast and these look good on it. The
repair involved replacing a 40-plus year old repair done by somebody
else. Mine ought to last longer than that.
spreaders
Michael Kennedy2009-02-18 13:54 UTC
I sent this photo to Rob off-list yesterday because I was at the
office and not at the e-mail account that is subscribed. Here is the
photo of Conquest's old spreaders. The rigging was rod so there was a
terminal joint at the spreader. Rod rigging doesn't like bending. The
spreader tip, badly corroded as you can see, had a pin that went
through the two terminals connecting them and anchoring the spreader
at that point. With wire rigging, that is not necessary as the wire
can bend at that point but the spreader angle needs to be correct to
avoid a vector other than along its axis.
Anyway, here is the photo.
The entire mast looked like this so it was all replaced.
Mike Kennedy
Conquest Cal 40 # 96
spreaders
Helen Horn2010-09-22 23:23 UTC
Three years ago I lightly sanded off the flaky varnish on our standard cal 29
wooden spreaders and used a layer of smith's penetrating epoxy, let it get
tacky, then painted with easypoxy gloss white. When we hauled the mast this last
fall it was still really firm and wiped down with water to look as good as new.
But I lightly sanded again and put one more layer on, then used some green and
yellow paints to paint a squiggley snake on top of each one with open red mouths
and sharp white teeth (only a bird would think these were snakes). The yard
thought it was funny but no more birdxxxx on the sailcover or deck. now some
little birds think the lifelines are a hoot.at least it's closer to the
scuppers. HH
Re: [Cal_Boats] spreaders
Allen Edwards2010-09-23 00:45 UTC
Please to send me a picture of the snake. I want to paint them on my
spreaders. What a great idea!!!
> 29 wooden spreaders and used a layer of smith's penetrating epoxy, let it
> get tacky, then painted with easypoxy gloss white. When we hauled the mast
> this last fall it was still really firm and wiped down with water to look as
> good as new. But I lightly sanded again and put one more layer on, then used
> some green and yellow paints to paint a squiggley snake on top of each one
> with open red mouths and sharp white teeth (only a bird would think these
> were snakes). The yard thought it was funny but no more birdxxxx on the
> sailcover or deck. now some little birds think the lifelines are a hoot.atleast it's closer to the scuppers. HH
Chris Campbell2010-09-23 15:35 UTC
Another alternative is to run a line of monofilament fish line just
above the spreader, interfering with landing by the birds.
Allen Edwards2010-09-23 16:08 UTC
I am thinking that the snakes will keep birds off more than the spreaders.
I hope Helen took a picture.
On Thu, Sep 23, 2010 at 8:35 AM, Chris Campbell <
> Another alternative is to run a line of monofilament fish line just above
> Chris Campbell
