3 messages2010-09-24 10:11 UTCthrough 2010-09-24 17:29
Re: Fuel Problem - Need Help (Paul & Joe D.)
John2010-09-24 10:11 UTC
Paul- it was running 10-15 minutes out of the tank.
Joe- bled the injectors, too, takes a long time and much cranking to get
them bled.
John Stacklyn
Cal 31 #33 "Sol Survivor"
Shell Point, FL
Re: [Cal_Boats] Re: Fuel Problem - Need Help (Paul & Joe D.)
jr… [at] triad.rr.com2010-09-24 11:26 UTC
One of the older boats in our marina had this problem a few years back. After much time searching and testing, with a per hour mechanic aboard, they finally replaced the fuel line from the tank to the filter. Problem solved.
John
Sender: Ca… [at] yahoogroups.com
Date: Fri, 24 Sep 2010 06:11:46
Reply-To: Ca… [at] yahoogroups.com
Subject: [Cal_Boats] Re: Fuel Problem - Need Help (Paul & Joe D.)
them bled.
John Stacklyn
Shell Point, FL
sculler20002010-09-24 17:29
John,
I have the same engine and pump and have bled it several times over the years when changing filters but have never had the kind of trouble that you seem to be having.
You are right about how the tubes to the injectors take a long time to bleed
I have had it run for 15 minutes and quit but once I bleed it a second time and get it running I am good to go.
My guess is that you did all of the obvious stuff (lines, bleeding, filters).
Might be time for a pro. (or a different one)
Chris
Cal 31 "Mo"
Poulsbo, WA
> them bled.
> Thanks,
> John Stacklyn
> Shell Point, FL
