2 messages2010-10-13 11:59 UTCthrough 2010-10-13 18:24 UTC
Re:CAL 2-29 sailing was mast screws
Alfred Poor2010-10-13 11:59 UTC
Randy wrote:
"Other than that,. it is sail in clean air, sail at 10-15 degrees and change
head sails when the boat get over 25 degrees."
I didn't race our Cal 29 when we had it (aside from the Good Old Boat
Regatta), but I absolutely agree with this piece of advice. It's a boat that
wants to be sail on its feet. The headsail provides the drive, and the main
is there more or less to handle the trim. If you have too much weather helm,
you're slowing down the boat with drag from the rudder so depower the main
(ease the sheet, lower the traveler, flatten the sail). If this causes the
main to flog (which creates drag and wears out the sail), then it needs to
be reefed. If the rail is in the water, then you need less sail in the
foretriangle. Or at least that's what I think worked best.
Alfred Poor
RE: [Cal_Boats] Re:CAL 2-29 sailing was mast screws
Husar, Charlie [USA]2010-10-13 18:24 UTC
So, Alfred, when do you pull up your centerboard? :- ]
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Alfred Poor
Sent: Wednesday, October 13, 2010 7:59 AM
Subject: [Cal_Boats] Re:CAL 2-29 sailing was mast screws
Randy wrote:
"Other than that,. it is sail in clean air, sail at 10-15 degrees and change head sails when the boat get over 25 degrees."
I didn't race our Cal 29 when we had it (aside from the Good Old Boat Regatta), but I absolutely agree with this piece of advice. It's a boat that wants to be sail on its feet. The headsail provides the drive, and the main is there more or less to handle the trim. If you have too much weather helm, you're slowing down the boat with drag from the rudder so depower the main (ease the sheet, lower the traveler, flatten the sail). If this causes the main to flog (which creates drag and wears out the sail), then it needs to be reefed. If the rail is in the water, then you need less sail in the foretriangle. Or at least that's what I think worked best.
Alfred Poor
