24 messages2010-10-10 23:13 through 2010-10-16 00:41 UTC
Mainsail Luff Track Screw Heads Broken
Ken2010-10-10 23:13
Today,while sailing on my Cal 2-24 two of the screw heads on my mainsail luff track broke just above my boom, so that the lower track is now pulled away from the mast. Can anybody tell me what I need to do to fix these broken screws? For example, should just take the mast off, and take it to a machine shop to have folks better equipped drill them out? Thank you very much. Ken
Re: [Cal_Boats] Mainsail Luff Track Screw Heads Broken
Allen Edwards2010-10-11 00:54 UTC
I know nothing of your problem but if it were my boat I would want to know
why they broke before I fixed them. Perhaps you have a new sail that isn't
right. Perhaps you reefed and tightened the clew before the tack.
Something is wrong as there really should not be enough force there to
break screws. If you really feel that nothing broke them, you might want to
replace all of them all the way up.
> much. Ken
Donald2010-10-11 01:27 UTC
Had the same issue on my 29. Ended up using a slightly longer screw and
putting a nut on the inside of the mast. I just happened to have a
plastic washer that was domed on one side and fit the contour of the
inside of the mast.
Good Luck
Don
'74 CAL29
Cayuga Lake, NY
Randy Alcorn2010-10-11 04:36 UTC
Hi Ken,
I have had it happen three times on my mast. The first time I took the track to
a machine shop and had the track remade with a larger screw size. I drilled out
the old screws and re-tapped them to the larger size. The second time I was able
to straighten the track and remove the screws with an easy out. However the
third time I bought a goose neck mount from http://www.lefiell.com/. I am going
to drop my mast and do other work and grind off the track and use the goose neck
mount.
Currently my CAL 2-29 is leading both the Ventura county High Points and the
Santa Barbra Channel series which tracks races between clubs from Santa Barbra,
Ventura and Channel Island California. In order to finish the season I used
three stainless steel hose clamps to secure the sliding goose neck in place and
hold the track to the mast. I used black electrical tape between the stainless
steel and the mast to prevent galvanic corrosion. So far so good. Our race
season ends in December and starts in middle of Jan.
Randy
CAL 2-29
Out Patient
Channel Islands Ca
Sent: Sun, October 10, 2010 4:13:35 PM
Subject: [Cal_Boats] Mainsail Luff Track Screw Heads Broken
Ken2010-10-11 21:09
While sailing on my Cal 2-24 two of the screw heads on my mainsail luff track broke just above my boom, so that the lower track is now pulled away from the mast. Can anybody tell me what I need to do to fix these broken screws? For example, should just take the mast off, and take it to a machine shop to have folks better equipped drill them out? Thank you very much. Ken
RE: [Cal_Boats] Mainsail Luff Track Screw Heads Broken
Husar, Charlie [USA]2010-10-12 00:21 UTC
For Randy: Geez I thought I cooked up that hose clamp idea. On my CAL 25s, I put one right through the slider to hold it tight to the boom track and boom. I actually use two shorter ones (that can be butted to each other) to make the sizing easier. In the old days, the track was for an adjustment to allow more curl in the luff. Nowadays we attach the track fitting at the lowest point commensurate with the lower main band, and leave it there.
Ken, a few comments. The track was attached with screws tapped into the thin mast section. This is why they come loose or break after a while. I've seen some tracks that people had welded to increase the strength. Of course welding aluminum (or whatever one calls that process) is apparently a touchy process. Hose clamps will do it.
The track does not need to go into the same holes. No need to take down the mast. Just take off the track, and move it an inch with new holes. If you can't remove the broken screws, then grind them down to smooth. Might put some metal putty in the old holes to reduce leakage, and then sand.
As far as the new holes go, getting centered holes is not easy, since the holes are smaller (need to be tapping size) than the 1/4 inch holes (I am assuming) in the track, and the surface of the mast is curved. Even a small miss makes the holes misalign for putting track back on. Can be painful. Here is an idea. First, drill and tap one hole for the new track placement. Screw the track on with that one hole. Now, for the next hole, get a piece of 1/4" OD tube and stick it in the next hole (when you have suitable aligned the track where you want it). Drill a hole at the ID size of the tubing. This hole will be properly centered. Then remove track, drill hole to proper size, and tap and reinstall track with two screws (I will assume the screws are 1/4-20 machine, probably 1/2" to 3/4" long). Then go to next hole repeating the process. Note that since the boom no longer needs to slide, the track can be quite short. When you have done all the screws, put on your hose clamp. Don't forget your Lanocote on the screws.
Some caution, the original boom track on some older CALs was 7/8" rather than the modern 1" track. Getting a slider to fit this track can be tough (Rig-Rite sells them, but does not produce them very often.) A one inch slider with a hose clamp can be the fall back position.
Someone said they used nuts on the inside of the mast. How did you get them in there? I'd love to know since I tried that. It is a good 3 feet up inside the mast.
My fingers are tired.
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Ken
Sent: Monday, October 11, 2010 5:09 PM
Yahoo! Groups Links
mike farrell2010-10-12 00:27 UTC
Damn good advice!!!
My Best ,Mike Farrell
Sent: Mon, October 11, 2010 5:21:47 PM
Subject: RE: [Cal_Boats] Mainsail Luff Track Screw Heads Broken
mast.
Ken
Yahoo! Groups Links
Yahoo! Groups Links
Husar, Charlie [USA]2010-10-12 00:35 UTC
Shucks, thanks, Mike. That dissertation was the product of some painful experiences, and maybe a little thought.
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of mike farrell
Sent: Monday, October 11, 2010 8:28 PM
Subject: Re: [Cal_Boats] Mainsail Luff Track Screw Heads Broken
Damn good advice!!!
From: Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com> [mailto:Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com>] On Behalf Of Ken
Yahoo! Groups Links
Yahoo! Groups Links
Helen Horn2010-10-12 00:36 UTC
Try to remove the old screws with an easy out type unit, one end will drill a
tiny hole into the sheared off screw, the other end will back it out using a
drill that turns in reverse. However, first try to remove the corroded, oxidized
stuff with rinses of hot water (dried salty stuff) and then solvent like
boshield before working on it. Maybe you won't have to tap for bigger screws.
Helen
screws.
mast.
Ken
Yahoo! Groups Links
Re: Mainsail Luff Track Screw Heads Broken
Ken2010-10-12 01:14
Thank you very much. I don't believe the inside of my track can take a larger screw head, so I am probably going to have to replace the screws with the same size screw. If I remove the old screws part way up the mast, so that I can get behind the track to work on the mast where the broken screws are, can the same size screws be used to reattach the track, or is there lost integrity once they are disturbed? Also, what does "tapping" the screws mean? Clearly, I have never done this sort of thing to my boat before. Thank you again.
--- In Ca… [at] yahoogroups.com, Randy Alcorn <saylorran@...> wrote:
> Hi Ken,
> mount.
> Randy
> CAL 2-29
> Out Patient
> Channel Islands Ca
> Â
> From: Ken <kclark@...>
> Â
Ken2010-10-12 01:34
I believe you are exactly correct. Before I left the mooring, I reefed the main, and tightened the clew before the tack. I guess the tack should have been closer to the mast, but I didn't want the luff to chafe on the mast. I'm not too experienced with technical details like that. I sail on a lake, and seldom go out when the winds are too strong, and I have never reefed while under sail - only before leaving the mooring.
> Allen
> > much. Ken
Ken2010-10-12 01:44
Congratulations on your racing success. I've never raced a sailboat. I've been sailing my cal for about 10 years on Lake St. Clair in Michigan, Kentucky Lake, and now Lake George in NY. I'm a fair weather sailor. My sailing ability allows me to sail on and off my mooring, but not too skilled or experienced with boat repairs. Can do the fiberglass stuff to the hull with the west system, but have never done anything with my running rigging.
> Hi Ken,
> mount.
> Randy
> CAL 2-29
> Out Patient
> Channel Islands Ca
> Â
> Â
Re: [Cal_Boats] Re: Mainsail Luff Track Screw Heads Broken
Allen Edwards2010-10-12 05:41 UTC
Always tighten the halyard when setting a reef before pulling in the reef
line on the clew. You now know why.
> --- In Ca… [at] yahoogroups.com <Cal_Boats%40yahoogroups.com>, Allen
> know
> isn't
> to
> > Allen
> mainsail
> pulled
> to a
> very
> > > much. Ken
Helen Horn2010-10-12 07:49 UTC
If you can remove the screws, assuming the heads snapped off because of
stress wear back and forth, by getting them to unscrew, then you only had bad
screws, unless they worked on the threads too.Then you can see if the threaded
mast holes are good (flashlight, magnifying glass if needed). I got my little
easyout bits which are double-ended with a drill on one and the reverse bit on
the other from OSH which is under Sears' command in California now. They come in
sizes to handle little screws like 4, 6, 8,(those are wood screw sizes) (but
compare to machine screws like 10/32 for example) one to a package, and they
sort of remind you of one of those pins with which you put a watchband back on.
You want it smaller than the shaft of the screw so it doesn't damage the
material or threads you are extracting it from. It also should let you do this
right through the mast track since it is smaller than the track hole. Tapping
makes new threads into material, usually larger diameter than the old one.. so
new screws would be bigger, not what you want as you say. Helen
Sent: Mon, October 11, 2010 6:14:48 PM
Subject: [Cal_Boats] Re: Mainsail Luff Track Screw Heads Broken
> Hi Ken,
>to
>out
>able
>neck
> mount.
> Randy
> CAL 2-29
> Out Patient
> Channel Islands Ca
> Â
> Â
Mark Alan Stahnke (MAS Consulting)2010-10-12 14:50 UTC
Randy, as a 2-29 sailor and 29 racer, I am most interested in what you attribute your success to in the way of boat modifications and choice of headsails vs. conditions. (we know your a great sailor!)
Mark
Sent: Monday, October 11, 2010 6:44 PM
> Hi Ken,
> mount.
> Randy
> CAL 2-29
> Out Patient
> Channel Islands Ca
> Â
> Â
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5524 (20101012) __________
http://www.eset.com
http://www.eset.com
Re:CAL 2-29 sailing was mast screws
Randy Alcorn2010-10-13 04:50 UTC
Mark.
I wish I knew the magic secret. I have sailed my boat for over 10 years and
learned my competition.
I followed the recipe of the PHRF SOCAL website.
http://www.phrfsocal.org/perspective/perspective.php
A. Learn to sail your boat with the sails you have.
B. Once you get the experience, start improving your sails, bottom and trim,
right now I focus on minute trim.
C. Time on water with a dedicated crew equals success.
Other than that,. it is sail in clean air, sail at 10-15 degrees and change head
sails when the boat get over 25 degrees.
I wish I could sail against other CAL 29"s to learn more. but I am sailing
against a Islander 29, CAl 25 and Catalina 27's in the non spin class and Moore
24's, J 24's and J 30's in the spin class in my area.
I just focus on being top 3 pole positions.
I could go on but that is why I would like to get a means to allow our crews to
sail on different boats out here, I have always been Jealous of Class Sea and
Mariposa and their winnings.
Vr
Randy
CAl 2-29\
Out Patient
Channel Islands, Ca
Sent: Tue, October 12, 2010 7:50:59 AM
Subject: Re: [Cal_Boats] Re: Mainsail Luff Track Screw Heads Broken
Mark
>> Hi Ken,
>>to
>>out
>>able
>>neck
>> mount.
>> Randy
>> CAL 2-29
>> Out Patient
>> Channel Islands Ca
>> Â
>> Â
>http://www.eset.com
http://www.eset.com
Ken2010-10-15 00:38
Thank you very much Helen. You're terrific, and very clear in your articulation. Just what I needed. I'll determine the screw size, and order the bits from your OSH. Ken
> --- In Ca… [at] yahoogroups.com, Randy Alcorn <saylorran@> wrote:
> > Hi Ken,
> > I have had it happen three timesà on my mast. The first time I took the track
> >to
> > a machine shop and hadà the trackà remade with a larger screw size. I drilled
> >out
> >able
> > to straighten the track andà remove the screws with an easy out. However the
> >neck
> > mount.
> > Randy
> > CAL 2-29
> > Out Patient
> > Channel Islands Ca
> > Ã
> > From: Ken <kclark@>
> > Ã
Allen Edwards2010-10-15 15:04 UTC
What Helen is saying is correct but in my experience it never is that easy.
If the screws are bronze, you are in luck so go with what Helen is saying.
If the screws are stainless steel, it is unlikely that it will work.
Aluminum and stainless form some kind of corrosion bond that is very
difficult to break. Note that drilling stainless needs Cobalt drill bits.
And not Kobalt as in the Lowels store brand. I have never had an easy out
work for me. What I do is drill out the screw and re-tap. If you are
really lucky, you can drill out the center of the screw and pull the threads
out like removing a spring. I would give that a 10% chance of working. You
should also be award of heli-coils. What you do with these is drill out the
hole larger, tap it with a special tap, and insert the heli-coil which now
has a thread size for your desired screw size. The result is actually
stronger than if you did not use them. If is very difficult to drill
stainless steel though. I would grind the surface first to make it flat and
get a center punch in there somehow (not sure how) to give the drill bit a
place to rest so it doesn't wonder over to the outside of the screw. If you
drill off center and hit the aluminum, the drill bit will prefer the
aluminum and wonder over way off center. The best thing is to hope the
screws are bronze. :-)
> --- In Ca… [at] yahoogroups.com <Cal_Boats%40yahoogroups.com>, Helen Horn
> bad
> threaded
> little
> bit on
> come in
> (but
> they
> back on.
> this
> Tapping
> one.. so
> > To: Ca… [at] yahoogroups.com <Cal_Boats%40yahoogroups.com>
> larger
> same
> can get
> same
> once they
> never
> > --- In Ca… [at] yahoogroups.com <Cal_Boats%40yahoogroups.com>, Randy
> > > Hi Ken,
> the track
> > >to
> drilled
> > >out
> was
> > >able
> However the
> am going
> goose
> > >neck
> > > mount.
> and the
> Barbra,
> used
> place and
> stainless
> race
> > > Randy
> > > CAL 2-29
> > > Out Patient
> > > Channel Islands Ca
> > > Â
> > > From: Ken <kclark@>
> > > Â
> mainsail luff
> away from
> screws? For
> to have
elmerbug2010-10-15 15:58
Another path here, which in materials thick enough to make it practical, is to use Heli-Coils. Heli-Coils have several advantages: 1) They are stainless steel 2) They are stronger than the original threads 3) They end up, post-repair, at the original thread size. I have used them successfully for 35+ years.
Don
> Allen
> > bad
> > threaded
> > little
> > bit on
> > come in
> > (but
> > they
> > back on.
> > this
> > Tapping
> > one.. so
> > > From: Ken <kclark@>
> > larger
> > same
> > can get
> > same
> > once they
> > never
> > > > Hi Ken,
> > the track
> > > >to
> > drilled
> > > >out
> > was
> > > >able
> > However the
> > am going
> > goose
> > > >neck
> > > > mount.
> > and the
> > Barbra,
> > used
> > place and
> > stainless
> > race
> > > > Randy
> > > > CAL 2-29
> > > > Out Patient
> > > > Channel Islands Ca
> > > > Ã
> > > > From: Ken <kclark@>
> > > > Ã
> > mainsail luff
> > away from
> > screws? For
> > to have
RE: [Cal_Boats] Re: Mainsail Luff Track Screw Heads Broken
Husar, Charlie [USA]2010-10-15 16:32 UTC
I go with moving the track an inch up or down and making new tapped holes. I think it easier in the end. Yes, the thinness of the material is a problem. Then there is that hose clamp that was mentioned previously.
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of elmerbug
Sent: Friday, October 15, 2010 11:58 AM
Don
> easy out work for me. What I do is drill out the screw and re-tap.
> If you are really lucky, you can drill out the center of the screw and
> pull the threads out like removing a spring. I would give that a 10%
> chance of working. You should also be award of heli-coils. What you
> do with these is drill out the hole larger, tap it with a special tap,
> and insert the heli-coil which now has a thread size for your desired
> screw size. The result is actually stronger than if you did not use
> them. If is very difficult to drill stainless steel though. I would
> grind the surface first to make it flat and get a center punch in
> there somehow (not sure how) to give the drill bit a place to rest so
> it doesn't wonder over to the outside of the screw. If you drill off
> center and hit the aluminum, the drill bit will prefer the aluminum
> and wonder over way off center. The best thing is to hope the screws
> are bronze. :-)
> Allen
> > > because of stress wear back and forth, by getting them to unscrew,
> > > then you only had
> > bad
> > > the
> > threaded
> > > got my
> > little
> > > reverse
> > bit on
> > > now. They
> > come in
> > > sizes)
> > (but
> > > package, and
> > they
> > > watchband
> > back on.
> > > damage the material or threads you are extracting it from. It also
> > > should let you do
> > this
> > Tapping
> > > old
> > one.. so
> > > From: Ken <kclark@>
> > > take a
> > larger
> > > with the
> > same
> > > that I
> > can get
> > > can the
> > same
> > > integrity
> > once they
> > > I have
> > never
> > > Randy
> > > > Hi Ken,
> > > > I have had it happen three timesÃ, on my mast. The first time I
> > > > took
> > the track
> > > >to
> > > > a machine shop and hadÃ, the trackÃ, remade with a larger screw
> > > > size. I
> > drilled
> > > >out
> > > > time I
> > was
> > > >able
> > > > to straighten the track andÃ, remove the screws with an easy out.
> > However the
> > am going
> > > > use the
> > goose
> > > >neck
> > > > mount.
> > > > Points
> > and the
> > > > from Santa
> > Barbra,
> > > > season I
> > used
> > > > neck in
> > place and
> > > > the
> > stainless
> > > > good. Our
> > race
> > > > Randy
> > > > CAL 2-29
> > > > Out Patient
> > > > Channel Islands Ca
> > > > Ã,
> > > > From: Ken <kclark@>
> > > > Ã,
> > mainsail luff
> > > > pulled
> > away from
> > > > broken
> > screws? For
> > > > shop
> > to have
Yahoo! Groups Links
Gerald Sobel2010-10-15 17:44 UTC
What about forgetting about re doing the exsisting hole, and drilling and tapping a new connection/ hole next to it? And, what about just putting in a pop rivet? Dip it, and plaster the hole with silicone grease first to prevent galvanic reaction before inserting. I recommend silicone grease (obtainable from a pool supply) every time you are in a dis similar metal connection situation, and, when crimping wire connections, or even on screw terminal wire connections. It, or comparable stuff, is a blessing...unless you like the look of corrosion and what it does.
--- On Fri, 10/15/10, Husar, Charlie [USA] <hu… [at] bah.com> wrote:
Subject: RE: [Cal_Boats] Re: Mainsail Luff Track Screw Heads Broken
Date: Friday, October 15, 2010, 9:32 AM
Don
> are bronze. :-)
> Allen
> > > then you only had
> > bad
> > > the
> > threaded
> > > got my
> > little
> > > reverse
> > bit on
> > > now. They
> > come in
> > > sizes)
> > (but
> > > package, and
> > they
> > > watchband
> > back on.
> > > should let you do
> > this
> > Tapping
> > > old
> > one.. so
> > > From: Ken <kclark@>
> > > take a
> > larger
> > > with the
> > same
> > > that I
> > can get
> > > can the
> > same
> > > integrity
> > once they
> > > I have
> > never
> > > Randy
> > > > Hi Ken,
> > > > took
> > the track
> > > >to
> > > > size. I
> > drilled
> > > >out
> > > > time I
> > was
> > > >able
> > However the
> > am going
> > > > use the
> > goose
> > > >neck
> > > > mount.
> > > > Points
> > and the
> > > > from Santa
> > Barbra,
> > > > season I
> > used
> > > > neck in
> > place and
> > > > the
> > stainless
> > > > good. Our
> > race
> > > > Randy
> > > > CAL 2-29
> > > > Out Patient
> > > > Channel Islands Ca
> > > > Ã,
> > > > From: Ken <kclark@>
> > > > Ã,
> > mainsail luff
> > > > pulled
> > away from
> > > > broken
> > screws? For
> > > > shop
> > to have
Yahoo! Groups Links
Helen Horn2010-10-15 17:48 UTC
Allen I agree about the centering of the bit , also, as long as the bit doesn't
contact the mast part nor its threads, the other consequence is as you suggest ,
the screw somewhat disintegrates and the remaining threads peel out, Must
remember to add hot water to soften the buildup of corrosion, maybe add a dose
of vinegar also, and a corrosion-buster product. The tapping for a new insert,
with new threads in the insert to accommodate the original size screw is what
could be done if this fails, and it would be stronger than the old one as you
say. What my thought here is, he would like to keep the original screw size, and
not have to remove the whole track. The bit which is a double-ended unit with a
drill on one end and reverse out on the other costs about $10 or less and can be
used for multiple other jobs later. I used one to remove some old ss screws from
a vang bail on my aluminum mast and it worked nicely. His old screws have
probably broken off irregularly, maybe they have a dip in them, a punch or small
nailset might help center the drill bit point. Grinding off, without removing
track would be hard, maybe a dremel size bit. Staying centered is the most
important, as the tapping if necessary needs to be in the same location. Then,
if all works, when installing the new screws, use lanacote or some other
anticorrosive between the metals. Helen
Sent: Fri, October 15, 2010 8:04:12 AM
What Helen is saying is correct but in my experience it never is that easy. If
the screws are bronze, you are in luck so go with what Helen is saying. If the
screws are stainless steel, it is unlikely that it will work. Aluminum and
stainless form some kind of corrosion bond that is very difficult to break.
Note that drilling stainless needs Cobalt drill bits. And not Kobalt as in the
Lowels store brand. I have never had an easy out work for me. What I do is
drill out the screw and re-tap. If you are really lucky, you can drill out the
center of the screw and pull the threads out like removing a spring. I would
give that a 10% chance of working. You should also be award of heli-coils.
What you do with these is drill out the hole larger, tap it with a special tap,
and insert the heli-coil which now has a thread size for your desired screw
size. The result is actually stronger than if you did not use them. If is very
difficult to drill stainless steel though. I would grind the surface first to
make it flat and get a center punch in there somehow (not sure how) to give the
drill bit a place to rest so it doesn't wonder over to the outside of the screw.
If you drill off center and hit the aluminum, the drill bit will prefer the
aluminum and wonder over way off center. The best thing is to hope the screws
are bronze. :-)
>OSH. Ken
>>in
>> > Hi Ken,
>>track
>> >to
>>drilled
>> >out
>> >able
>>going
>> >neck
>> > mount.
>>Barbra,
>>and
>>stainless
>> > Randy
>> > CAL 2-29
>> > Out Patient
>> > Channel Islands Ca
>> > Â
>> > From: Ken <kclark@>
>> > Â
>>from
>>For
Gregory Branch2010-10-16 00:02
Several additions to this good advice:
1. If you can find a LEFT HAND drill slightly smaller than the inside or root diameter of the thread these work very well to remove screws. (Amazon sells small sets of LH drill bits) You start drilling and the LH drill bit rotation is trying to unscrew the screw for you. At the same time as you drill into the screw you relieve the pressure of the screw in the hole which is very tight due to the corrosion. Many times the screw simply screws out when you are about one diameter into the screw...
2. When installing the SS screws always ALWAYS ALWAYS put on never seize or other chemical to keep down the corrosion. Locktite helps limit corosion as well.
3. If you are screwing SS metal down or have screw heads in contact try using black plastic tape or other insulating material between the head and or SS metal and any aluminum. This will reduce the electrical contact and reduce the corrosion around the head or around the SS metal part.
> Allen
> > bad
> > threaded
> > little
> > bit on
> > come in
> > (but
> > they
> > back on.
> > this
> > Tapping
> > one.. so
> > > From: Ken <kclark@>
> > larger
> > same
> > can get
> > same
> > once they
> > never
> > > > Hi Ken,
> > the track
> > > >to
> > drilled
> > > >out
> > was
> > > >able
> > However the
> > am going
> > goose
> > > >neck
> > > > mount.
> > and the
> > Barbra,
> > used
> > place and
> > stainless
> > race
> > > > Randy
> > > > CAL 2-29
> > > > Out Patient
> > > > Channel Islands Ca
> > > > Ã
> > > > From: Ken <kclark@>
> > > > Ã
> > mainsail luff
> > away from
> > screws? For
> > to have
Mark Alan Stahnke (MAS Consulting)2010-10-16 00:41 UTC
how about grind off broken screw and drill a new hole. Easyouts that small usually break off since the corrosion between the stainless and aluminum is greater in strength than the Easyout. If it does break off then try to get the Easyout, out of the hole and better yet try and grind case hardend steel next to aluminum. Even if you can get it into a drill press, IT SPELLS MESS.
In any case just be carefull.
Mark
Sent: Friday, October 15, 2010 5:02 PM
> Allen
> > bad
> > threaded
> > little
> > bit on
> > come in
> > (but
> > they
> > back on.
> > this
> > Tapping
> > one.. so
> > > From: Ken <kclark@>
> > larger
> > same
> > can get
> > same
> > once they
> > never
> > > > Hi Ken,
> > > > I have had it happen three timesÃ, on my mast. The first time I took
> > the track
> > > >to
> > > > a machine shop and hadÃ, the trackÃ, remade with a larger screw size. I
> > drilled
> > > >out
> > was
> > > >able
> > However the
> > am going
> > goose
> > > >neck
> > > > mount.
> > and the
> > Barbra,
> > used
> > place and
> > stainless
> > race
> > > > Randy
> > > > CAL 2-29
> > > > Out Patient
> > > > Channel Islands Ca
> > > > Ã,
> > > > From: Ken <kclark@>
> > > > Ã,
> > mainsail luff
> > away from
> > screws? For
> > to have
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5535 (20101015) __________
http://www.eset.com
http://www.eset.com
