Re: [Cal_Boats] Lazy Jack Photos [4 Attachments]
2 messages2010-10-16 12:46 UTCthrough 2010-10-16 14:22 UTC
pw… [at] aol.com2010-10-16 12:46 UTC
Dan - Thanks for the fast service with the photos! I just have a few questions . . . Obviously the loops under the boom don't slide down the boom to the mast with the pad-eyes there, so when you retract the system I presume that the line that forms the hypotenuse of the right triangle formed by the boom and mast must run up to the mast thru a block or another pad-eye and down the side of the mast correct? This line is then loosened allowing all the jack lines to fall parallel to the boom and I'm guessing you've measured them so that the rings are able to hook on something on the forward end of the boom or the mast? Since I already have 3 lines exiting my mast at various heights on both side I am tempted to figure out a way to bring them down inside the mast and out the bottom . . . . hmmmm have to think about that one. Thanks again - Paul West Adventure Kwest '80 Cal 39 In a message dated 10/15/2010 9:35:10 P.M. Eastern Daylight Time, da… [at] hotmail.com writes: [_Attachment(s)_ (mip://02844168/default.html#TopText) from Daniel McCutcheon included below] Here are the photos. Hope they make things clearer. The beads are to keep everything ligned up after the system is dialed in. Someone said earlier they didn't like Lazy Jacks, as they tend to fowl the main (especially the battens). This has certainly been my experiance. One suggestion is to run the top bridal to the spreaders, therby allowing a greater spread, lest chance of fowling. The solution I'm working on is to secure the main with a continuous "zip line" that can be progresively pulled out as I raise the main, allowing me to have the Lazy Jacks retracted once the main is stowed, therfore not a fowling factor. I'll let you know how that really ends up working. Dan Wasn't ready to pull down the hamack yet. Dan
chris1232010-10-16 14:22 UTC
Perhaps hanging the system off the spreaders will make the needed lines more visible and avoid confusion in the rigging. My current is off the mast and far to much chaffing when the system is retracted, both at sea and at dockside. Would solve this problem as well. /ch >
