Transmission information
6 messages2010-10-18 12:39 UTCthrough 2010-10-18 16:28 UTC
Rogers, Christopher C.2010-10-18 12:39 UTC
All I have a 1977 Cal 2-29., powered by a venerable Farymann A30 single cylinder diesel. I would like to identify the transmission characteristics, particularly the reduction ratio, to check my propeller against. It feels like I need to wind the engine up to full throttle to get over 5.5 kts or so. According to the manual that came with the boat, the options are a Hurth, a Nanni, or a Ronim transmission. The Hurth had a screw-in dipstick, so that's elimintated. I found the following stamped numbers on the back of the casing: 99641 0030, which don't quite seem to match up to the pattern given in the manual. It I tried to make it fit, the last number is supposed to be the reduction ration, which would be 3.0:1? That seems like an strange number to me (actually, it's odd!), and a high reduction ratio for an engine that's only rated at 2500 RPM. Any idea on what this might be? Chris Rogers Cal 2-29 699 "Fujin"
Re: [Cal_Boats] Transmission information
Joe DeMers2010-10-18 14:07 UTC
Please send a picture, and I can ID your transmission. *Joe DeMers - owner* Sound Marine Diesel LLC SoundMarineDiesel.com <http://www.soundmarinediesel.com/> *phone & fax (860) 666-2184* On 10/18/2010 8:39 AM, Rogers, Christopher C. wrote: > > > All > I have a 1977 Cal 2-29., powered by a venerable Farymann A30 single > cylinder diesel. I would like to identify the transmission > characteristics, particularly the reduction ratio, to check my > propeller against. It feels like I need to wind the engine up to full > throttle to get over 5.5 kts or so. > According to the manual that came with the boat, the options are a > Hurth, a Nanni, or a Ronim transmission. The Hurth had a screw-in > dipstick, so that's elimintated. > I found the following stamped numbers on the back of the casing: > 99641 0030, which don't quite seem to match up to the pattern given in > the manual. It I tried to make it fit, the last number is supposed to > be the reduction ration, which would be 3.0:1? That seems like an > strange number to me (actually, it's odd!), and a high reduction ratio > for an engine that's only rated at 2500 RPM. > Any idea on what this might be? > Chris Rogers > Cal 2-29 699 "Fujin" > > > > > > > No virus found in this incoming message. > Checked by AVG - www.avg.com > Version: 9.0.862 / Virus Database: 271.1.1/3200 - Release Date: 10/16/10 02:34:00 > > -- *Joe DeMers - owner* Sound Marine Diesel LLC SoundMarineDiesel.com <http://www.soundmarinediesel.com/> *phone & fax (860) 666-2184*
RE: [Cal_Boats] Transmission information
Rogers, Christopher C.2010-10-18 14:40 UTC
Will do. Chris From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Joe DeMers Sent: Monday, October 18, 2010 10:07 AM To: Ca… [at] yahoogroups.com Subject: Re: [Cal_Boats] Transmission information Please send a picture, and I can ID your transmission. Joe DeMers - owner Sound Marine Diesel LLC SoundMarineDiesel.com<http://www.soundmarinediesel.com/> phone & fax (860) 666-2184 On 10/18/2010 8:39 AM, Rogers, Christopher C. wrote: All I have a 1977 Cal 2-29., powered by a venerable Farymann A30 single cylinder diesel. I would like to identify the transmission characteristics, particularly the reduction ratio, to check my propeller against. It feels like I need to wind the engine up to full throttle to get over 5.5 kts or so. According to the manual that came with the boat, the options are a Hurth, a Nanni, or a Ronim transmission. The Hurth had a screw-in dipstick, so that's elimintated. I found the following stamped numbers on the back of the casing: 99641 0030, which don't quite seem to match up to the pattern given in the manual. It I tried to make it fit, the last number is supposed to be the reduction ration, which would be 3.0:1? That seems like an strange number to me (actually, it's odd!), and a high reduction ratio for an engine that's only rated at 2500 RPM. Any idea on what this might be? Chris Rogers Cal 2-29 699 "Fujin" No virus found in this incoming message. Checked by AVG - www.avg.com<http://www.avg.com> Version: 9.0.862 / Virus Database: 271.1.1/3200 - Release Date: 10/16/10 02:34:00 -- Joe DeMers - owner Sound Marine Diesel LLC SoundMarineDiesel.com<http://www.soundmarinediesel.com/> phone & fax (860) 666-2184
Mark Alan Stahnke (MAS Consulting)2010-10-18 14:51 UTC
Speaking transmission issues, for the first time since I purchased the boat 6 yrs ago, my starter is acting up. It is engaging about 1/2 the time otherwise it spins. I was told by my dock buddies to check the wiring connections at solenoid and the starter gear shaft may need lubrication so it slides into flywheel. any thoughts on this. Is there an inspection port or way to clean and remove shaft without removing the starter? Mark ----- Original Message ----- From: Rogers, Christopher C. To: Ca… [at] yahoogroups.com Sent: Monday, October 18, 2010 7:40 AM Subject: RE: [Cal_Boats] Transmission information Will do. Chris From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Joe DeMers Sent: Monday, October 18, 2010 10:07 AM To: Ca… [at] yahoogroups.com Subject: Re: [Cal_Boats] Transmission information Please send a picture, and I can ID your transmission. Joe DeMers - owner Sound Marine Diesel LLC SoundMarineDiesel.com phone & fax (860) 666-2184 On 10/18/2010 8:39 AM, Rogers, Christopher C. wrote: All I have a 1977 Cal 2-29., powered by a venerable Farymann A30 single cylinder diesel. I would like to identify the transmission characteristics, particularly the reduction ratio, to check my propeller against. It feels like I need to wind the engine up to full throttle to get over 5.5 kts or so. According to the manual that came with the boat, the options are a Hurth, a Nanni, or a Ronim transmission. The Hurth had a screw-in dipstick, so that's elimintated. I found the following stamped numbers on the back of the casing: 99641 0030, which don't quite seem to match up to the pattern given in the manual. It I tried to make it fit, the last number is supposed to be the reduction ration, which would be 3.0:1? That seems like an strange number to me (actually, it's odd!), and a high reduction ratio for an engine that's only rated at 2500 RPM. Any idea on what this might be? Chris Rogers Cal 2-29 699 "Fujin" No virus found in this incoming message.Checked by AVG - www.avg.com Version: 9.0.862 / Virus Database: 271.1.1/3200 - Release Date: 10/16/10 02:34:00 -- Joe DeMers - owner Sound Marine Diesel LLC SoundMarineDiesel.com phone & fax (860) 666-2184 __________ Information from ESET NOD32 Antivirus, version of virus signature database 5542 (20101018) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com __________ Information from ESET NOD32 Antivirus, version of virus signature database 5542 (20101018) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com
engine starter [ was Transmission information
Joe DeMers2010-10-18 15:09 UTC
What engine are we discussing? Joe D On 10/18/2010 10:51 AM, Mark Alan Stahnke (MAS Consulting) wrote: > > > Speaking transmission issues, for the first time since I purchased the > boat 6 yrs ago, my starter is acting up. It is engaging about 1/2 the > time otherwise it spins. I was told by my dock buddies to check the > wiring connections at solenoid and the starter gear shaft may need > lubrication so it slides into flywheel. > any thoughts on this. Is there an inspection port or way to clean and > remove shaft without removing the starter? > Mark > > ----- Original Message ----- > *From:* Rogers, Christopher C. <mailto:ch… [at] jhuapl.edu> > *To:* Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> > *Sent:* Monday, October 18, 2010 7:40 AM > *Subject:* RE: [Cal_Boats] Transmission information > > Will do. > > Chris > > *From:* Ca… [at] yahoogroups.com > <mailto:Ca… [at] yahoogroups.com> > [mailto:Ca… [at] yahoogroups.com] *On Behalf Of *Joe DeMers > *Sent:* Monday, October 18, 2010 10:07 AM > *To:* Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> > *Subject:* Re: [Cal_Boats] Transmission information > > Please send a picture, and I can ID your transmission. > > *Joe DeMers - owner* > > Sound Marine Diesel LLC > > SoundMarineDiesel.com <http://www.soundmarinediesel.com/> > > *phone & fax (860) 666-2184* > > > > On 10/18/2010 8:39 AM, Rogers, Christopher C. wrote: > > All > > I have a 1977 Cal 2-29., powered by a venerable Farymann A30 > single cylinder diesel. I would like to identify the transmission > characteristics, particularly the reduction ratio, to check my > propeller against. It feels like I need to wind the engine up to > full throttle to get over 5.5 kts or so. > > According to the manual that came with the boat, the options are a > Hurth, a Nanni, or a Ronim transmission. The Hurth had a screw-in > dipstick, so that's elimintated. > > I found the following stamped numbers on the back of the casing: > 99641 0030, which don't quite seem to match up to the pattern > given in the manual. It I tried to make it fit, the last number > is supposed to be the reduction ration, which would be 3.0:1? > That seems like an strange number to me (actually, it's odd!), and > a high reduction ratio for an engine that's only rated at 2500 RPM. > > Any idea on what this might be? > > Chris Rogers > > Cal 2-29 699 "Fujin" > > > > > > > > No virus found in this incoming message. > > Checked by AVG -www.avg.com <http://www.avg.com> > > Version: 9.0.862 / Virus Database: 271.1.1/3200 - Release Date: 10/16/10 02:34:00 > > > > > > -- > > *Joe DeMers - owner* > > Sound Marine Diesel LLC > > SoundMarineDiesel.com <http://www.soundmarinediesel.com/> > > *phone & fax (860) 666-2184* > > > > __________ Information from ESET NOD32 Antivirus, version of virus > signature database 5542 (20101018) __________ > > The message was checked by ESET NOD32 Antivirus. > > http://www.eset.com > > > > __________ Information from ESET NOD32 Antivirus, version of virus > signature database 5542 (20101018) __________ > > The message was checked by ESET NOD32 Antivirus. > > http://www.eset.com > > > > > > > No virus found in this incoming message. > Checked by AVG - www.avg.com > Version: 9.0.862 / Virus Database: 271.1.1/3204 - Release Date: 10/18/10 02:34:00 > > -- *Joe DeMers - owner* Sound Marine Diesel LLC SoundMarineDiesel.com <http://www.soundmarinediesel.com/> *phone & fax (860) 666-2184*
Re: [Cal_Boats] engine starter [ was Transmission information
Mark Alan Stahnke (MAS Consulting)2010-10-18 16:28 UTC
Joe, its the Farymann A30 12 hp. Mark ----- Original Message ----- From: Joe DeMers To: Ca… [at] yahoogroups.com Sent: Monday, October 18, 2010 8:09 AM Subject: [Cal_Boats] engine starter [ was Transmission information What engine are we discussing? Joe D On 10/18/2010 10:51 AM, Mark Alan Stahnke (MAS Consulting) wrote: Speaking transmission issues, for the first time since I purchased the boat 6 yrs ago, my starter is acting up. It is engaging about 1/2 the time otherwise it spins. I was told by my dock buddies to check the wiring connections at solenoid and the starter gear shaft may need lubrication so it slides into flywheel. any thoughts on this. Is there an inspection port or way to clean and remove shaft without removing the starter? Mark ----- Original Message ----- From: Rogers, Christopher C. To: Ca… [at] yahoogroups.com Sent: Monday, October 18, 2010 7:40 AM Subject: RE: [Cal_Boats] Transmission information Will do. Chris From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Joe DeMers Sent: Monday, October 18, 2010 10:07 AM To: Ca… [at] yahoogroups.com Subject: Re: [Cal_Boats] Transmission information Please send a picture, and I can ID your transmission. Joe DeMers - owner Sound Marine Diesel LLC SoundMarineDiesel.com phone & fax (860) 666-2184 On 10/18/2010 8:39 AM, Rogers, Christopher C. wrote: All I have a 1977 Cal 2-29., powered by a venerable Farymann A30 single cylinder diesel. I would like to identify the transmission characteristics, particularly the reduction ratio, to check my propeller against. It feels like I need to wind the engine up to full throttle to get over 5.5 kts or so. According to the manual that came with the boat, the options are a Hurth, a Nanni, or a Ronim transmission. The Hurth had a screw-in dipstick, so that's elimintated. I found the following stamped numbers on the back of the casing: 99641 0030, which don't quite seem to match up to the pattern given in the manual. It I tried to make it fit, the last number is supposed to be the reduction ration, which would be 3.0:1? That seems like an strange number to me (actually, it's odd!), and a high reduction ratio for an engine that's only rated at 2500 RPM. Any idea on what this might be? Chris Rogers Cal 2-29 699 "Fujin" No virus found in this incoming message.Checked by AVG - www.avg.com Version: 9.0.862 / Virus Database: 271.1.1/3200 - Release Date: 10/16/10 02:34:00 -- Joe DeMers - owner Sound Marine Diesel LLC SoundMarineDiesel.com phone & fax (860) 666-2184 __________ Information from ESET NOD32 Antivirus, version of virus signature database 5542 (20101018) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com __________ Information from ESET NOD32 Antivirus, version of virus signature database 5542 (20101018) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com No virus found in this incoming message. Checked by AVG - www.avg.com Version: 9.0.862 / Virus Database: 271.1.1/3204 - Release Date: 10/18/10 02:34:00 -- Joe DeMers - owner Sound Marine Diesel LLC SoundMarineDiesel.com phone & fax (860) 666-2184 __________ Information from ESET NOD32 Antivirus, version of virus signature database 5542 (20101018) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com __________ Information from ESET NOD32 Antivirus, version of virus signature database 5542 (20101018) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com
