3 messages2010-10-22 14:33 UTCthrough 2010-10-22 16:33 UTC
Re: [Cal_Boats] Engine Temp Normal-Max?
je… [at] mindspring.com2010-10-22 14:33 UTC
Raw water cooled engines [ in salt water ] must not be operated higher than about 150*, or the salts will coat the engine's water passages, and restrict water flow.
Joe DeMers
>From: sculler2000 <sc… [at] yahoo.com>
>Sent: Oct 22, 2010 10:27 AM
>To: Ca… [at] yahoogroups.com
>Subject: [Cal_Boats] Engine Temp Normal-Max?
>Folks,
>My Volvo diesel MD6A looks (to me ) to be running a little hot. Then it occurred to me that I might want to see what exactly "Hot" is.
>My owners manual does not say except that the thermostat is "fully open" at 165 or so.
>Does that mean that 165 is "normal" and above that woulde be high?
>If I run for a while at cruising RPMs of 2,300 I am at 185 degrees or so and I can run at that temp for hours it would seem.
>If I push the engine, it will go to 200ish but I don't do that because it seems high to me.
>How does that sound to you?
>Chris
>Cal31, Poulsbo, WA
>Yahoo! Groups Links
RE: [Cal_Boats] Engine Temp Normal-Max?
r good2010-10-22 16:21 UTC
Joe, does that also pertain to engines which are "fresh" water cooled (fresh water plus antifreeze) which then disipate heat via a heat exchanger which uses salt water?
(was that sentence cumbersome enough to obscure its intent?)
Date: Fri, 22 Oct 2010 10:33:50 -0400
Subject: Re: [Cal_Boats] Engine Temp Normal-Max?
Joe DeMers
>Folks,
>Chris
>Cal31, Poulsbo, WA
>Yahoo! Groups Links
Joe DeMers2010-10-22 16:33 UTC
Fresh water cooled engines operate about 185*F and do not have a problem
with salts accumulating due to overheated seawater.
*> > Joe DeMers - owner*
Sound Marine Diesel LLC
*phone & fax (860) 666-2184*
> Reggie
> From: je… [at] mindspring.com
> Joe DeMers
> -----Original Message-----
> >From: sculler2000 <sc… [at] yahoo.com <mailto:sc… [at] yahoo.com>>
> >To: Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com>
> >Folks,
> open" at 165 or so.
> >Chris
> >Cal31, Poulsbo, WA
> >Yahoo! Groups Links
> Version: 9.0.862 / Virus Database: 271.1.1/3212 - Release Date: 10/22/10 02:34:00
*Joe DeMers - owner*
