19 messages2010-09-13 16:16 UTCthrough 2010-11-02 21:46 UTC
fall sailing
Chris Campbell2010-09-13 16:16 UTC
OK, more of my ramblings about fall sailing. On Saturday, I was
sailing my other boat, the 26' Seafarer. It was a nice sunny day, and
those have been rare this month. The NOAA weather forecast was "gusty
winds with gusts of 20 mph." They normally don't make such a deal of
irregular winds so I took them seriously and reefed the main.
My old nemesis is the roller reefing, and sure enough, the main looked
quite sad when I hoisted it--lots of vertical wrinkles. But I was
single-handing and had raised sail in a dredged navigation channel, so I
decided to live with it. When the sail was drawing, it filled out well
and looked better. Out in the Bay, I measured average winds of 14 knots
and peaks of 18 knots, and the boat sailed along happily under reefed
main and jib at speeds in the upper 5 knot range with little heeling.
This is a shoal-draft keel-centerboarder, and when she's overpowered,
she lets you know. But there was no distress, just easy sailing on a
close to broad reach. I sailed out about 8 mi. and the wind was
dropping, so after some hesitation I "shook out" (unrolled) the reef. I
came about and headed back on a beam reach, doing around 6 knots
comfortably. It was a perfect day.
The wind direction--mostly west--meant that I could sail in _and_ out of
the river, a happy and rare occurrence. As I entered the mouth of the
river, I had to pinch up periodically because of fluky winds and a
narrow place in the channel where the depth goes to 2 feet abruptly to
leeward of me. I'd get headed and then stalled so l was playing with
main & jib sheets. All of a sudden there was a serious blast of wind,
one that I saw about half a second before it hit, and before I could pop
the mainsheet out of the cleat I saw water over the rail...and whoa!!,
water over the cockpit coaming!!, and lots of stuff changing sides down
below. She was almost on beam ends. I finally wrestled the mainsheet
out of the cleat and she popped up and the gust passed and all was
normal again. For a couple seconds I thought I was going to find out
how quickly the cockpit clears when it's filled, as we have discussed
before. (Luckily, this boat has a high bridge deck to keep water in the
cockpit).
The only casualty of the event was a little bottle where I keep spare
varnish for touch-ups. I needed to use it, but after the stuff below
all pitched around, it was nowhere to be found. Mystery. Looked
everywhere. Otherwise, it was just a lovely day for sailing, a sunny
last-gasp day for us.
Re: [Cal_Boats] fall sailing
Allen Edwards2010-09-13 16:36 UTC
I listened to people tell me to get rid of the roller reefing for 10 years
before I did it. It has now been 10 years with slab reefing. From that
experience I offer this advice: Get rid of the roller reefing.
On Mon, Sep 13, 2010 at 9:16 AM, Chris Campbell <
cl… [at] charterinternet.com> wrote:
> OK, more of my ramblings about fall sailing. On Saturday, I was sailing
> my other boat, the 26' Seafarer. It was a nice sunny day, and those have
> been rare this month. The NOAA weather forecast was "gusty winds with gusts
> of 20 mph." They normally don't make such a deal of irregular winds so I
> decided to live with it. When the sail was drawing, it filled out well and
> looked better. Out in the Bay, I measured average winds of 14 knots and
> peaks of 18 knots, and the boat sailed along happily under reefed main and
> jib at speeds in the upper 5 knot range with little heeling. This is a
> shoal-draft keel-centerboarder, and when she's overpowered, she lets you
> know. But there was no distress, just easy sailing on a close to broad
> reach. I sailed out about 8 mi. and the wind was dropping, so after some
> hesitation I "shook out" (unrolled) the reef. I came about and headed back
> on a beam reach, doing around 6 knots comfortably. It was a perfect day.
> The wind direction--mostly west--meant that I could sail in *and* out of
> river, I had to pinch up periodically because of fluky winds and a narrow
> place in the channel where the depth goes to 2 feet abruptly to leeward of
> me. I'd get headed and then stalled so l was playing with main & jib
> sheets. All of a sudden there was a serious blast of wind, one that I saw
> about half a second before it hit, and before I could pop the mainsheet out
> of the cleat I saw water over the rail...and whoa!!, water over the cockpit
> coaming!!, and lots of stuff changing sides down below. She was almost on
> beam ends. I finally wrestled the mainsheet out of the cleat and she popped
> up and the gust passed and all was normal again. For a couple seconds I
> thought I was going to find out how quickly the cockpit clears when it's
> filled, as we have discussed before. (Luckily, this boat has a high bridge
> deck to keep water in the cockpit).
> varnish for touch-ups. I needed to use it, but after the stuff below all
> pitched around, it was nowhere to be found. Mystery. Looked everywhere.
> Otherwise, it was just a lovely day for sailing, a sunny last-gasp day for
> us.
> Chris Campbell
Chris Campbell2010-09-13 17:16 UTC
> years before I did it. It has now been 10 years with slab reefing.
> From that experience I offer this advice: Get rid of the roller reefing.
I know. But that boat has a pretty spruce boom that I hate to screw up
with lots of added-on hardware. So I live with the roller reefing and
try to get the best possible shape in the sail. I'm thinking about
adding reefing cringles to the sail so I could use a tack outhaul and
then secure the tack down to the boom with a short length of line--kind
of like using a sail tie to secure the tack down on the Cal 20.
I have groused about roller reefing forever and was pleasantly surprised
at how good the sail shape ended up on Saturday. The major drawback,
even if you can get a good shape, is the awkwardness of reefing while
underway (almost impossible single-handed, because you're always doing
it after it becomes necessary). My good shape happened because I did it
in the slip before going out.
The other solution is to go out with a crew, but if I waited for crew to
be ready & willing, I'd never go sailing. Maybe I need to change my
deodorant or toothpaste.
Helen Horn2010-09-13 17:47 UTC
Sounds like it was fun, you'll probably get the willies next time on your way
back in at that spot. by the way, look behind the stove if it's gimballed. helen
Sent: Mon, September 13, 2010 9:16:31 AM
Subject: [Cal_Boats] fall sailing
OK, more of my ramblings about fall sailing. On Saturday, I was sailing my
other boat, the 26' Seafarer. It was a nice sunny day, and those have been
rare this month. The NOAA weather forecast was "gusty winds with gusts of
20 mph." They normally don't make such a deal of irregular winds so I took
My old nemesis is the roller reefing, and sure enough, the main looked quite
sad when I hoisted it--lots of vertical wrinkles. But I was single-handing
and had raised sail in a dredged navigation channel, so I decided to live
with it. When the sail was drawing, it filled out well and looked better.
Out in the Bay, I measured average winds of 14 knots and peaks of 18 knots,
and the boat sailed along happily under reefed main and jib at speeds in the
upper 5 knot range with little heeling. This is a shoal-draft
keel-centerboarder, and when she's overpowered, she lets you know. But
there was no distress, just easy sailing on a close to broad reach. I
sailed out about 8 mi. and the wind was dropping, so after some hesitation I
"shook out" (unrolled) the reef. I came about and headed back on a beam
The wind direction--mostly west--meant that I could sail in and out of the
river, a happy and rare occurrence. As I entered the mouth of the river, I
had to pinch up periodically because of fluky winds and a narrow place in
the channel where the depth goes to 2 feet abruptly to leeward of me. I'd
get headed and then stalled so l was playing with main & jib sheets. All of
a sudden there was a serious blast of wind, one that I saw about half a
second before it hit, and before I could pop the mainsheet out of the cleat
I saw water over the rail...and whoa!!, water over the cockpit coaming!!,
and lots of stuff changing sides down below. She was almost on beam ends.
I finally wrestled the mainsheet out of the cleat and she popped up and the
gust passed and all was normal again. For a couple seconds I thought I was
going to find out how quickly the cockpit clears when it's filled, as we
have discussed before. (Luckily, this boat has a high bridge deck to keep
us.
Chris Campbell2010-09-13 19:52 UTC
> your way back in at that spot. by the way, look behind the stove if
Stove's not gimballed but _that's where it is!_ Dunno why I didn't look
there, where it probably landed when the boat righted herself. Duh.
I always get nervous in that spot anyway--it's where there's the danger
of running aground and where you get squeezed in with a bunch of
powerboats. It's where I ran out of gas once. It's near where I was
hit by a squall once. I try to be vigilant there.
Chris
mike farrell2010-09-13 20:16 UTC
As a sailor who kept roller reefing on a 7 ton boat. I say NEVER AGAIN!!!
Slab reefing makes so much more sense. I concur with Allen.
My Best,Mike
Sent: Mon, September 13, 2010 9:36:56 AM
Subject: Re: [Cal_Boats] fall sailing
On Mon, Sep 13, 2010 at 9:16 AM, Chris Campbell <cl… [at] charterinternet.com>
>other boat, the 26' Seafarer. It was a nice sunny day, and those have been rare
>this month. The NOAA weather forecast was "gusty winds with gusts of 20 mph."
>They normally don't make such a deal of irregular winds so I took them seriously
>My old nemesis is the roller reefing, and sure enough, the main looked quite sad
>when I hoisted it--lots of vertical wrinkles. But I was single-handing and had
>raised sail in a dredged navigation channel, so I decided to live with it. When
>the sail was drawing, it filled out well and looked better. Out in the Bay, I
>measured average winds of 14 knots and peaks of 18 knots, and the boat sailed
>along happily under reefed main and jib at speeds in the upper 5 knot range with
>little heeling. This is a shoal-draft keel-centerboarder, and when she's
>overpowered, she lets you know. But there was no distress, just easy sailing on
>a close to broad reach. I sailed out about 8 mi. and the wind was dropping, so
>after some hesitation I "shook out" (unrolled) the reef. I came about and
>headed back on a beam reach, doing around 6 knots comfortably. It was a perfect
>day.
>river, a happy and rare occurrence. As I entered the mouth of the river, I had
>to pinch up periodically because of fluky winds and a narrow place in the
>channel where the depth goes to 2 feet abruptly to leeward of me. I'd get
>headed and then stalled so l was playing with main & jib sheets. All of a
>sudden there was a serious blast of wind, one that I saw about half a second
>before it hit, and before I could pop the mainsheet out of the cleat I saw water
>over the rail...and whoa!!, water over the cockpit coaming!!, and lots of stuff
>changing sides down below. She was almost on beam ends. I finally wrestled the
>mainsheet out of the cleat and she popped up and the gust passed and all was
>normal again. For a couple seconds I thought I was going to find out how
>quickly the cockpit clears when it's filled, as we have discussed before.
>(Luckily, this boat has a high bridge deck to keep water in the cockpit).
>The only casualty of the event was a little bottle where I keep spare varnish
>for touch-ups. I needed to use it, but after the stuff below all pitched
>around, it was nowhere to be found. Mystery. Looked everywhere. Otherwise,
>it was just a lovely day for sailing, a sunny last-gasp day for us.
>Chris Campbell
mike farrell2010-09-13 20:19 UTC
My crew liked beer in bottles! I provided beer.
I singlehand or sail with my wife (3rd) I don't need to provide.
My Best, Mike
Sent: Mon, September 13, 2010 10:16:35 AM
I know. But that boat has a pretty spruce boom that I hate to screw up with
lots of added-on hardware. So I live with the roller reefing and try to get the
best possible shape in the sail. I'm thinking about adding reefing cringles to
the sail so I could use a tack outhaul and then secure the tack down to the boom
with a short length of line--kind of like using a sail tie to secure the tack
down on the Cal 20.
I have groused about roller reefing forever and was pleasantly surprised at how
good the sail shape ended up on Saturday. The major drawback, even if you can
get a good shape, is the awkwardness of reefing while underway (almost
impossible single-handed, because you're always doing it after it becomes
necessary). My good shape happened because I did it in the slip before going
out.
The other solution is to go out with a crew, but if I waited for crew to be
ready & willing, I'd never go sailing. Maybe I need to change my deodorant or
toothpaste.
Allen Edwards2010-09-14 01:34 UTC
I am the kind of guy who tries every way to do something I can think of
until I get something I like. What I have for my reefing I like very much
although I almost never reef with my new main, but that is another story.
I have a line tied to a cleat on the mast with a hook on the end of it.
That is the tack when reefing. Very easy to put in and much easier than
having a fixed hook on the boom.
I have a padeye just a tad aft of the single reefing cringle. The end of
the reef line goes through it and has a figure 8 knot to keep it from going
through the eye. That line goes through the cringle and as far aft as I can
on the boom to a cheek block. The line runs forward and in my case it goes
to a winch on the boom but if I had to do it over again I would not do that
but instead would lead it to another winch through a stopper, probably the
spinnaker halyard winch. That can be mast mounted, or fed back to the cabin
top. Mine is, like I said, on the boom near the mast as I lower my sail and
do all the reefing from the mast position.
I am told that trying to have one line do everything (tack and clew) only
works on paper although I have not tried that one.
I know if you change, you will wonder why you didn't do it earlier.
On the other hand, you could get a new main with full battons and learn how
to spill wind and you won't have to reef. I only reefed once this season.
It was blowing 35.
On Mon, Sep 13, 2010 at 10:16 AM, Chris Campbell <
> with lots of added-on hardware. So I live with the roller reefing and try
> to get the best possible shape in the sail. I'm thinking about adding
> reefing cringles to the sail so I could use a tack outhaul and then secure
> the tack down to the boom with a short length of line--kind of like using a
> how good the sail shape ended up on Saturday. The major drawback, even if
> you can get a good shape, is the awkwardness of reefing while underway
> (almost impossible single-handed, because you're always doing it after it
> becomes necessary). My good shape happened because I did it in the slip
> before going out.
> or toothpaste.
> Chris Campbell
Chris Campbell2010-09-14 12:58 UTC
> of until I get something I like. What I have for my reefing I like
> very much although I almost never reef with my new main, but that is
> another story.
Your system is about the same as on my Cal 20, except that I have a
fixed hook at the gooseneck for the tack. Reefing tends to be an
end-of-season activity here, when the winds pick up.
The line running through the clew cringle on my boat tends to stretch
out, allowing the clew to rise and go forward, making the sail fuller.
The last time I reefed it I ran one of my sail gaskets through the
cringle and around the boom to prevent this. It seemed to work fine but
it's an extra step. I'll probably buy some new low-stretch line to
replace the current one that came with the boat, some sort of single-braid.
Fall Sailing
James2010-11-02 06:57
Just got back from sailing just before a storm blew up here on the West Coast. What a blast, literally! We haven't sailed in many strong winds, so this was a learning experience for us. We sailed across a 2 mile channel with a full main and a small triangle of a jib, which was a mistake. We were constantly letting the wind glance off the main. So when we reached Savary Island, we fully reefed the main for the return trip.
Lots of control, lots of speed, and lots of fun! On the return I commented to my wife that the wind was so strong, it was causing spray--she said, you mean like a whale?? Sure enough, it was a whale. We headed towards it but lost it in the seas. I posted a video at:
http://www.theskeltons.org/chaseme/southeaster.wmv
OK, the bumpers went overboard early and my wife was already holding on for dear life trying to get the video and not slip out of the boat. But it gives you an idea of how fast we went!
--Jim
Re: [Cal_Boats] Fall Sailing
Chris2010-11-02 13:03 UTC
> trip.
The response from at least one Great Lakes sailor is....jealousy. My
mooring field had three boats left last weekend, and now is down to zero.
RE: [Cal_Boats] Fall Sailing
Husar, Charlie [USA]2010-11-02 14:57 UTC
Chris, we start Frostbite racing in Annapolis this Sunday. Seventeen CAL 25s entered. :- ]
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Chris
Sent: Tuesday, November 02, 2010 9:03 AM
Subject: Re: [Cal_Boats] Fall Sailing
The response from at least one Great Lakes sailor is....jealousy. My mooring field had three boats left last weekend, and now is down to zero.
Chris2010-11-02 16:09 UTC
I hope you all get sunburned and dehydrated. Do I sound jealous?
But on the happier side of things, I voted this morning and my bicycle
was one of three at the polling place. Life is fine when you live in a
place where people ride bikes to vote. Problem is, at this time of year
the helmet that's designed to funnel air over the head works too well,
and my poor bald head gets frozen. The bike shop gets under-helmet caps
in soon.
Chris
r good2010-11-02 16:29 UTC
CAL do-rag!
Date: Tue, 2 Nov 2010 12:09:51 -0400
But on the happier side of things, I voted this morning and my bicycle was one of three at the polling place. Life is fine when you live in a place where people ride bikes to vote. Problem is, at this time of year the helmet that's designed to funnel air over the head works too well, and my poor bald head gets frozen. The bike shop gets under-helmet caps in soon.
Chris
chris1232010-11-02 18:10 UTC
Chris
A nice option and will make you look young is to get a simple ski board
helmet. They are inexpensive and solid. Back home all the winter cyclists
would switch to them about now with lots of reflective tape front and back.
Sailing content.....these are also great if your sailing in colder climates
as they tend to keep you head really warm as you loose 80 percent of your
body heat at the top, neck up. Best part is when it get cold you tend to
move a lot slower and the helmet gives you an advantage on the boom...:)
Best regards
Chris2010-11-02 20:05 UTC
On 11/2/2010 2:10 PM, chris123 wrote:
> Chris
> board helmet. They are inexpensive and solid. Back home all the winter
> cyclists would switch to them about now with lots of reflective tape
> front and back.
> climates as they tend to keep you head really warm as you loose 80
> percent of your body heat at the top, neck up. Best part is when it
> get cold you tend to move a lot slower and the helmet gives you an
My iceboat helmet is an antique one, don't know what it was really
designed for (my father bought it 40 years ago!). It's the same way--
solid and surprisingly warm on the bald head. I tested it once by
landing on my head and thumb. Had to have surgery on the thumb.
Maybe I'll poke around for the ski board version. Most iceboaters use
motorcycle helmets--very large and they look $$$ (but they do have nice
face shields to keep the face warm). That would be too heavy and bulky
for bicycling.
Sadly, by the time it's too cold to sail here without winter garb, the
boats are long ashore for the winter. The last holdouts hauled just
before the huge storm last week.
I had to remove the cover from the Cal 20 on Wednesday to keep it from
blowing over on the trailer. It must have been quite a sight with me in
my coat & tie in howling winds, using lots of sailor language. When I
checked the local NOAA airport weather for the wind speeds, it said 25
mph/ gusts to 40. WTF??? That's nothing! Then somebody gave me a
better NOAA site that recorded >70 mph and another that showed about 65
mph. That's closer to what I was feeling as I cut the cover off. Last
weekend I put it back on, knowing it's unlikely that we'll see ca. 70
mph again this winter (I hope).
Chris
Poersch Jeffrey L.2010-11-02 20:38 UTC
Losing 80% of your body heat thru your head is one of the great urban myths of our time, and completely untrue. The Mythbusters debunked this on in one of there early shows.
See also: http://shc.osu.edu/blog/medical-mythbusters-do-you-really-lose-80-of-your-body-heat-from-your-head
Regards, Jeff
"idisi" - Cal 31
On Nov 2, 2010, at 2:10 PM, chris123 wrote:
> Chris
> A nice option and will make you look young is to get a simple ski board helmet. They are inexpensive and solid. Back home all the winter cyclists would switch to them about now with lots of reflective tape front and back.
> Sailing content.....these are also great if your sailing in colder climates as they tend to keep you head really warm as you loose 80 percent of your body heat at the top, neck up. Best part is when it get cold you tend to move a lot slower and the helmet gives you an advantage on the boom...:)
> Best regards
> /ch
Chris2010-11-02 20:52 UTC
The % may be wrong, but I can assure you that wearing a modern bicycle
helmet, designed to channel air over your head, can be quite
uncomfortable in cold weather for us baldies. Frankly, the % doesn't
matter. It's a question of comfort. You guys with hair just don't
understand.
My female boss was complaining that when she's biking her head gets too
hot because her hair is so thick. I volunteered to accept a transplant
of any follicles she wanted to dispose of. I also explained that she
should not complain about that hair trapping sweat--with none, the sweat
lands in your eyes. Life is so unfair....
chris1232010-11-02 21:46 UTC
You will note that she states, "exposed" which is the key word and I'm going
to disagree with myth busters on this one even though its one of my favorite
shows.
Having spend 6 years in the CDN Arctic I can tell ya something about cold.
Tools break at -60C and so do your lungs. We stopped work at -50C. In all
those years I was never cold when outside except for two body locations as
we were always properly dressed: hands and head (from the neck up) as they
were most exposed. Hands you wear wool finger gloves inside elbow length
mittens with a sheepskin patch on the front, as your nose runs incessantly,
and for the head, a balaclava and preferably a Mountie style muskrat hat, as
it insulates the top of your head by about three inches, the skin breaths,
and the ear flaps come down to the base of your neck. 100 years in the bush
and north worked this design out perfectly.
The key is not to sweat. If you sweat you die. Simple as that. Well not so
dramatic but you immediately would go back to the construction camp and
spend the day inside as your body cannot take it. Just for fun I walked
outside on the landing of the door at -60C, the station supervisor was on
the other side. He counted to 5 then pulled me in. Spend the next three days
in bed sound asleep. Never experienced anything like that....beets the crap
out of you and your head is ready to explode as well as your lungs.
Makes wintering in Rock Hall a very pleasant vacation at a resort.
Sailing content:
So the short answer is in my outdoor survival kit when at sea or in the
bush, I pack three hats for different temperatures. One is always waterproof
for when it rains.
Best regards.
