17 messages2010-11-01 22:05 UTCthrough 2010-11-04 02:30 UTC
Cal 29 Reefing
david dobbs2010-11-01 22:05 UTC
Guys,
I know we've discussed this before, but I need help with my main reefing setup. When I go to the mast to attach the reef cringle I have to remove the sail stop in the track in order to allow 2 sail slugs to drop out and be able to attach the cringle, then put the sail stop back in to keep the other slugs from falling out. I have installed a Tides Marine sail track on the mast which converted my external track to an internal one that lets the sail come down easily.
Regards,
David Dobbs Cal 29 411
Re: [Cal_Boats] Cal 29 Reefing
DavidOwen2010-11-01 22:50 UTC
Elegant: A dog-bone from your sailmaker with a stainless ring to
catch the horn.
Moderate: Use a line with a reefing hook to pull the cringle down to
the lowest height that still allows the stacked up foot to clear the
stop. You will need a termination point for the line; a block with a
cleat or ?
Cheap: Tie a loop through the reef cringle the right length to catch
the reefing horn on the boom with the sail stacked above your stop.
Use sail twine to whip the center portion, leaving a nice eye in the
end so it looks pretty.
Wilkie
On Nov 1, 2010, at 3:05 PM, david dobbs wrote:
> Guys,
> Regards,
Allen Edwards2010-11-01 23:34 UTC
Take out one of the slugs and leave it out. If this leaves the sail
unsupported, you might add a slug back between the existing ones but where
it will clear when reefed. In other words, the slugs on the main should be
in a position that allows you to reef. That said, I had two mains made and
both times I was assured that they would allow for the reefing and they
didn't do that either time. But I had extended my track so it was not a
problem. Wood has its advantages.
On Mon, Nov 1, 2010 at 3:05 PM, david dobbs <tm… [at] yahoo.com> wrote:
> Guys,
> come down easily.
> Regards,
mike farrell2010-11-02 00:04 UTC
Dear David,
I sailed a Pilot 35 with a Proctor spar that had a track such as
yours. There were 2 options, a gate and a lace line. The lace line held the
slugs so it could be unlaced. There were 2 small grommets at each slug location
and the lace line was attached to the sail. I remember the lower 5 slugs were
attached this way. When I reefed I unlaced how many I needed depending on how
deep I reefed. Alternately the gate which was about 2-2.5' above the gooseneck
could be opened to release the slugs. This gate was needed to remove the slugs
when changing sails. There was a 2nd track with a gate for the trysail which
was loosefooted and set without the boom.
My Best, Mike
Sent: Mon, November 1, 2010 4:34:53 PM
Subject: Re: [Cal_Boats] Cal 29 Reefing
Take out one of the slugs and leave it out. If this leaves the sail unsupported,
you might add a slug back between the existing ones but where it will clear when
reefed. In other words, the slugs on the main should be in a position that
allows you to reef. That said, I had two mains made and both times I was
assured that they would allow for the reefing and they didn't do that either
time. But I had extended my track so it was not a problem. Wood has its
advantages.
>Guys,
>Regards,
Re: [Cal_Boats] Cal 29 Reefing(Mike F)
david dobbs2010-11-02 00:42 UTC
Mike,
I like the gate idea, but have only seen one, which Selden makes. I hate to buy one and find out it won't fit. Maybe I'll try to build one from wood and epoxy coat it, and see how it works. Next year, the mast is on the rack and a little hard to get at!
Regards,
Dave
Date: Monday, November 1, 2010, 7:04 PM
Dear David,
I sailed a Pilot 35 with a Proctor spar that had a track such as yours. There were 2 options, a gate and a lace line. The lace line held the slugs so it could be unlaced. There were 2 small grommets at each slug location and the lace line was attached to the sail. I remember the lower 5 slugs were attached this way. When I reefed I unlaced how many I needed depending on how deep I reefed. Alternately the gate which was about 2-2.5' above the gooseneck could be opened to release the slugs. This gate was needed to remove the slugs when changing sails. There was a 2nd track with a gate for the trysail which was loosefooted and set without the boom.
My Best, Mike
Take out one of the slugs and leave it out. If this leaves the sail unsupported, you might add a slug back between the existing ones but where it will clear when reefed. In other words, the slugs on the main should be in a position that allows you to reef. That said, I had two mains made and both times I was assured that they would allow for the reefing and they didn't do that either time. But I had extended my track so it was not a problem. Wood has its advantages.
Guys,
Regards,
Re: [Cal_Boats] Cal 29 Reefing(David O)
david dobbs2010-11-02 00:57 UTC
Wilkie,
I had dog bones put in for the reef cringles, I suppose I could just attach a line to the dog bone and tighten it up to the reef hook. Won't be very seaman-like, but in sailing usually simpler is better, and not worry about the stacked up sail.
Regards,
David D.
Date: Monday, November 1, 2010, 5:50 PM
Elegant: A dog-bone from your sailmaker with a stainless ring to catch the horn.
Moderate: Use a line with a reefing hook to pull the cringle down to the lowest height that still allows the stacked up foot to clear the stop. You will need a termination point for the line; a block with a cleat or ?
Cheap: Tie a loop through the reef cringle the right length to catch the reefing horn on the boom with the sail stacked above your stop. Use sail twine to whip the center portion, leaving a nice eye in the end so it looks pretty.
Wilkie
Guys,
Regards,
chris1232010-11-02 01:09 UTC
No idea what dog bones are, well as they relate to sails anyways so google
gives me this rather interesting discussion which may be helpful .....
enjoy....
http://www.ericsonyachts.org/infoexchange/archive/index.php/t-2393.html
On Mon, Nov 1, 2010 at 8:57 PM, david dobbs <tm… [at] yahoo.com> wrote:
> Wilkie,
> Regards,
> David D.
> --- On *Mon, 11/1/10, DavidOwen <wi… [at] mariposasailing.com>* wrote:
> From: DavidOwen <wi… [at] mariposasailing.com>
> horn.
> pretty.
> Wilkie
> Guys,
> come down easily.
> Regards,
chris1232010-11-02 01:13 UTC
And a little more detail on how this relates to the main sail setup and
config
http://www.offshoresailsrts.net/en/about_mainsails_extras.html
Regards
Mark Alan Stahnke (MAS Consulting)2010-11-02 15:08 UTC
I believe my Mainsail has about 3" from feet to the first track slide. This has never posed a problem with my ability to achieve proper sail trim before or after reefing. In any event, there will be some tension on the slides when you bring the reef point at or below the slides. Simply mark your halyard so when you reef you can drop the sail to the optimum position before you pull in the tack line and then outhaul.
Mark
Cal 2-29
San Pedro
Sent: Monday, November 01, 2010 5:42 PM
Subject: Re: [Cal_Boats] Cal 29 Reefing(Mike F)
Mike,
Regards,
Dave
Dear David,
My Best, Mike
Guys,
Regards,
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5583 (20101101) __________
http://www.eset.com
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5585 (20101102) __________
http://www.eset.com
Mark Alan Stahnke (MAS Consulting)2010-11-02 15:15 UTC
I botch that email meant to say about three feet from foot to the first slide.
Sent: Tuesday, November 02, 2010 8:08 AM
Mark
Cal 2-29
San Pedro
Mike,
Regards,
Dave
Dear David,
My Best, Mike
Guys,
Regards,
http://www.eset.com
http://www.eset.com
http://www.eset.com
http://www.eset.com
RE: [Cal_Boats] Cal 29 Reefing(Mike F)
Husar, Charlie [USA]2010-11-02 16:41 UTC
Folks, I think it is actually the height of the reefing cringle above the first slide that matters. When reefing, the sail has a folding point where the slide hits the track stop. If the distance from the first slide to the cringle is not at least equal to the distance from the bottom of the slide to hook on the boom, the sail will not down far enough. This was/is a problem on the CAL 25 as well.
The same applies for successive reefs going up the sail, but the slide to cringle distance increases as the slides bunch up at the bottom of the track.
One old solution is to use a jackline that has the slides attached and eyes in the sail that the line goes through. When line is pulled tight, the sail sort of pulls forward to the slides. When released, there is extra line to let the sail pull down. I can fake a picture if needed.
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Mark Alan Stahnke (MAS Consulting)
Sent: Tuesday, November 02, 2010 11:15 AM
From: Mark Alan Stahnke (MAS Consulting)<mailto:ma… [at] cox.net>
Mark
Cal 2-29
San Pedro
Mike,
Regards,
Dave
--- On Mon, 11/1/10, mike farrell <ve… [at] yahoo.com<mailto:ve… [at] yahoo.com>> wrote:
Dear David,
My Best, Mike
On Mon, Nov 1, 2010 at 3:05 PM, david dobbs <tm… [at] yahoo.com<http://us.mc1113.mail.yahoo.com/mc/compose?to=tm… [at] yahoo.com>> wrote:
Guys,
Regards,
http://www.eset.com
http://www.eset.com
http://www.eset.com
http://www.eset.com
Allen Edwards2010-11-02 18:46 UTC
I just want to clarify my earlier post. I agree with what is said here and
the point I was making is that if the slides are located as Charlie points
out, it will just work. The solution for 10 years for Papoose was to cut
off one slide that was placed right on the cringle. One of the 4 mistakes
North made on that sail. If the sailmaker can move the slides, or if you
can do without one that is just in the wrong place, it should work.
My first sail came with a line you could untie and some fancy slides with
roller bearings on the slide that ran on the line. The line was attached
(through metal loops) to the sail every slide point but both above and below
the slide so that when the line was pulled tight, the slide was well
supported. It was a pain. It would be much easier to relocate the properly
space the slides and just live with whatever spacing you end up with.
I would say this is a concept that is difficult for sailmakers to get right
so it is not surprising that people have troubles with it. Both my mains
were made wrong for the way the boat was measured. The first sail I just
didn't use one of the slides, the second sail I added an extension the the
track so that the distance Charlie is talking about was cut to basically
zero.
On Tue, Nov 2, 2010 at 9:41 AM, Husar, Charlie [USA]
> track.
> Cheers
> Charlie
> Behalf Of *Mark Alan Stahnke (MAS Consulting)
> *Sent:* Tuesday, November 02, 2010 11:15 AM
> *Subject:* Re: [Cal_Boats] Cal 29 Reefing(Mike F)
> slide.
> *From:* Mark Alan Stahnke (MAS Consulting) <ma… [at] cox.net>
> *Sent:* Tuesday, November 02, 2010 8:08 AM
> Mark
> Cal 2-29
> San Pedro
> *From:* david dobbs <tm… [at] yahoo.com>
> *Sent:* Monday, November 01, 2010 5:42 PM
> Mike,
> Regards,
> Dave
> --- On *Mon, 11/1/10, mike farrell <ve… [at] yahoo.com>* wrote:
> From: mike farrell <ve… [at] yahoo.com>
> Dear David,
> My Best, Mike
> *From:* Allen Edwards <al… [at] PaloAltoPhoto.com>
> *Sent:* Mon, November 1, 2010 4:34:53 PM
> Allen
> > wrote:
> Guys,
> come down easily.
> Regards,
> http://www.eset.com
> http://www.eset.com
> http://www.eset.com
> http://www.eset.com
Husar, Charlie [USA]2010-11-02 20:05 UTC
Allen, I likewise put a track extension on one of my CAL 25s. It being an exterior track, it was not a pleasure getting it aligned so that slides would not bind on the joint.
Those hard rubber mallets are often useful.
Sent: Tuesday, November 02, 2010 2:46 PM
I just want to clarify my earlier post. I agree with what is said here and the point I was making is that if the slides are located as Charlie points out, it will just work. The solution for 10 years for Papoose was to cut off one slide that was placed right on the cringle. One of the 4 mistakes North made on that sail. If the sailmaker can move the slides, or if you can do without one that is just in the wrong place, it should work.
My first sail came with a line you could untie and some fancy slides with roller bearings on the slide that ran on the line. The line was attached (through metal loops) to the sail every slide point but both above and below the slide so that when the line was pulled tight, the slide was well supported. It was a pain. It would be much easier to relocate the properly space the slides and just live with whatever spacing you end up with.
I would say this is a concept that is difficult for sailmakers to get right so it is not surprising that people have troubles with it. Both my mains were made wrong for the way the boat was measured. The first sail I just didn't use one of the slides, the second sail I added an extension the the track so that the distance Charlie is talking about was cut to basically zero.
On Tue, Nov 2, 2010 at 9:41 AM, Husar, Charlie [USA] <hu… [at] bah.com<mailto:hu… [at] bah.com>> wrote:
From: Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com> [mailto:Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com>] On Behalf Of Mark Alan Stahnke (MAS Consulting)
Mark
Cal 2-29
San Pedro
Mike,
Regards,
Dave
From: mike farrell <ve… [at] yahoo.com<mailto:ve… [at] yahoo.com>>
Dear David,
My Best, Mike
Guys,
Regards,
http://www.eset.com
http://www.eset.com
http://www.eset.com
http://www.eset.com
Allen Edwards2010-11-02 23:25 UTC
Washers under the low one works too.
On Tue, Nov 2, 2010 at 1:05 PM, Husar, Charlie [USA]
> Cheers
> Charlie
> Behalf Of *Allen Edwards
> *Sent:* Tuesday, November 02, 2010 2:46 PM
> zero.
> Allen
>> track.
>> Cheers
>> Charlie
>> slide.
>> Mark
>> Cal 2-29
>> San Pedro
>> Mike,
>> Regards,
>> Dave
>> Dear David,
>> boom.
>> My Best, Mike
>> Allen
>> > wrote:
>> Guys,
>> come down easily.
>> Regards,
>> http://www.eset.com
>> http://www.eset.com
>> http://www.eset.com
>> http://www.eset.com
RE: [Cal_Boats] Cal 29,Sail Track(Charlie)
david dobbs2010-11-03 01:57 UTC
Charlie,
My 29 came with the external track. Whoever invented that needs to go boat hell. I bought a Tides Marine track, and it works great. When I release the halyard the sail falls; I don't have to pull the sail down like I did before.
Regards,
David Dobbs
--- On Tue, 11/2/10, Husar, Charlie [USA] <hu… [at] bah.com> wrote:
Subject: RE: [Cal_Boats] Cal 29 Reefing(Mike F)
Date: Tuesday, November 2, 2010, 3:05 PM
On Tue, Nov 2, 2010 at 9:41 AM, Husar, Charlie [USA] <hu… [at] bah.com> wrote:
Mark
Cal 2-29
San Pedro
Mike,
Regards,
Dave
Dear David,
My Best, Mike
Guys,
Regards,
http://www.eset.com
http://www.eset.com
http://www.eset.com
http://www.eset.com
Re: [Cal_Boats] Cal 29,Sail Track(Charlie)
Chris2010-11-03 20:04 UTC
On 11/2/2010 9:57 PM, david dobbs wrote:
> Charlie,
> like I did before.
My other boat has a standard old sail track, unlike the Cal 20 with its
groove for either the bolt rope or sail slugs (I added slugs to my "new"
used mainsail).
The other boat with its sail track is an old CCA-style rig with a
relatively low aspect ratio main, as compared with current practice.
The sail slides have always run on the track pretty freely, but a bit of
paraffin applied to the track works wonders. I also use paraffin in the
groove/on the slugs for the Cal 20. It makes a big difference. Paraffin
is my friend: cheap, non-sticky, weather-resistant, effective. It's a
great lubricant for outdoor sliding surfaces.
Re: [Cal_Boats] Cal 29,Sail Track(Chris)
david dobbs2010-11-04 02:30 UTC
Chris C.
Better engineering and manufacture are better than a remedial cure for a bad design. Why would anyone design an external track with slides that require close tolerance in order to move up or down when there may be pressure opposing that? I repeat, BAD DESIGN. I don't care if it was Bill Lapworth, it was a bad design for a mast track from anyone. Yes, it caused me some distress, and has been corrected.
Regards,
David Dobbs, Cal29 411
--- On Wed, 11/3/10, Chris <cc… [at] lsnm.org> wrote:
Subject: Re: [Cal_Boats] Cal 29,Sail Track(Charlie)
Date: Wednesday, November 3, 2010, 3:04 PM
Charlie,
My other boat has a standard old sail track, unlike the Cal 20 with its groove for either the bolt rope or sail slugs (I added slugs to my "new" used mainsail).
The other boat with its sail track is an old CCA-style rig with a relatively low aspect ratio main, as compared with current practice. The sail slides have always run on the track pretty freely, but a bit of paraffin applied to the track works wonders. I also use paraffin in the groove/on the slugs for the Cal 20. It makes a big difference. Paraffin is my friend: cheap, non-sticky, weather-resistant, effective. It's a great lubricant for outdoor sliding surfaces.
