27 messages2010-11-22 14:03 UTCthrough 2010-11-23 23:00 UTC
blood & bugs on paint
Chris2010-11-22 14:03 UTC
Cal sailors:
Let us imagine that your Cal is hurtling down the highway at night,
going 60 mph. The tow vehicle runs over a dead animal, one not dead
enough to have dried out, and blood squirts on the topsides. At the
same time, kamikaze bugs, attracted by the brilliance of your polished
hull, smash into it, leaving bug innards all over.
And then you go sailing, figuring that you'll wash the debris off
later. When you do, nothing happens. Water does not help. Try mineral
spirits; nope, no luck. How about shellac thinner (alcohol of some
persuasion)? No help. Maybe 3M Adhesive Remover? Won't budge it.
Now imagine that instead of a gel-coated Cal, I'm talking about a
painted car. What will take animal blood and squashed bugs off my
prized '86 Mustang?
Re: [Cal_Boats] blood & bugs on paint
Allen Edwards2010-11-22 14:23 UTC
I would go in this order. Obviously try detergent and hot water first.
These are all automotive products:
1) Tar remover (probably won't work)
2) Black streak remover (might work)
3) Car polish (might work)
4) Rubbing compound (will work) -- try fine grades first.
On Mon, Nov 22, 2010 at 6:03 AM, Chris <cc… [at] lsnm.org> wrote:
> Cal sailors:
> prized '86 Mustang?
> Chris Campbell
Chris2010-11-22 15:23 UTC
> first. These are all automotive products:
So what is tar remover? I figured it must be close to mineral spirits,
which had no effect. Is kerosene or diesel fuel significantly different?
Re: blood & bugs on paint
sailingbuds2010-11-22 15:24
Try a simple answer: "Simple Green!" You may have to soak it up a bit and do a couple of applications. Auto shop gave me this helpful hint and it works.
> prized '86 Mustang?
> Chris Campbell
Re: [Cal_Boats] Re: blood & bugs on paint
Chris2010-11-22 15:26 UTC
> and it works.
I'll try that, too. My first water-based effort was using a car-wash
detergent.
DavidOwen2010-11-22 15:52 UTC
I used Simple Green on one of my motorcycles and it softened the paint
on the frame. Don't use it full strength....
Wilkie
> hint and it works.
> > prized '86 Mustang?
> > Chris Campbell
chris1232010-11-22 21:24 UTC
As far as I know it toluene. The chemistry of organics (which I failed) is
the chemistry of petroleum and natural based compounds.
When it come to petrochemical based solvents they are all similar in
structure but different enough to make a difference. The rule of thumb with
organics is general is the like disolves in like. So what may not work with
mineral spirits may work with something that is very close. Its kinda like
pharmaceuticals which are really complex molecultes and act differently in
each person (even more complex)
Take Nexium for example it may work for you. Take the mirror image of that
drug (same molecule except reversed if you look at on paper, and it may not
work for you) I know this one from experience. I had to use the other stuff
for a while at 3.00 CDN a pill.
As far as I know toluene and MEK are available at ACE. These are basically
paint strippers.
I would think you would have better luck with a very mild rubbing compound
as it seams to me the "juices" have impregnated the dried paint layer. Hence
nothing is taking the stuff off. Once you buff out the stuff, then remember
to add polish out the areas and wax liberally.
Best regards
> Chris Campbell
Gregory Rogers2010-11-22 21:39 UTC
Have you considered using clay bar?
> paint strippers.
> Best regards
>> Chris Campbell
> /ch
Chris2010-11-22 22:05 UTC
> failed) is the chemistry of petroleum and natural based compounds.
> basically paint strippers.
> compound as it seams to me the "juices" have impregnated the dried
> paint layer. Hence nothing is taking the stuff off.
I'll try some toluene and/or MEK (if thinned Simple Green does not
help); have both on hand but they seemed a bit aggressive. I'll try a
bit on a cotton swab. Luckily, the stuff is mostly on the rocker panels
and lower portions of doors, where any screw-ups are less visible.
This stuff is surface-layer accumulation. If I work at it with a finger
nail, most spots scrape off. It's just a pain to do it that way. If
all else fails, I may try sharpening a piece of some durable wood like
oak as a mild scraper.
It is interesting how the organic solvents are so picky about what they
dissolve. I'm just hoping that whatever works on bug juice & carcass
blood doesn't like car paint.
> Once you buff out the stuff, then remember to add polish out the areas
> and wax liberally.
> Best regards
> spirits, which had no effect. Is kerosene or diesel fuel
> Chris Campbell
> /ch
Chris2010-11-22 22:09 UTC
No. I have a vague recollection about this as a finish-cleaning tool.
I'lll Google it.
Michael Hofstetter2010-11-22 22:41 UTC
A tool that one of my friends in the construction industry turned me on to are
scraperite blades (http://www.scraperite.com/). They might give you a truer
edge than sharpened wood.
They work wonders for most tasks on the boat and I have used them on my car for
bugs and other derbis also. Pretty simple idea but basically a razor shaped
blade made in various denistys of plastic for applications exactly like this.
Also did a dream job removing the vinyl graphics that the previous owner of my
28-2 applied 10+ years ago.
Good Luck!
Mike Hofstetter
1988 Cal 28-2 "Sails Call"
Baltimore
Sent: Mon, November 22, 2010 5:05:32 PM
Subject: Re: [Cal_Boats] blood & bugs on paint
>As far as I know it toluene. The chemistry of organics (which I failed) is the
>As far as I know toluene and MEK are available at ACE. These are basically paint
>strippers.
>I would think you would have better luck with a very mild rubbing compound as it
>seams to me the "juices" have impregnated the dried paint layer. Hence nothing
I'll try some toluene and/or MEK (if thinned Simple Green does not help); have
both on hand but they seemed a bit aggressive. I'll try a bit on a cotton swab.
Luckily, the stuff is mostly on the rocker panels and lower portions of doors,
This stuff is surface-layer accumulation. If I work at it with a finger nail,
most spots scrape off. It's just a pain to do it that way. If all else fails,
I may try sharpening a piece of some durable wood like oak as a mild scraper.
dissolve. I'm just hoping that whatever works on bug juice & carcass blood
Once you buff out the stuff, then remember to add polish out the areas and wax
liberally.
>Best regards
>>>I would go in this order. Obviously try detergent and hot water first. These
>So what is tar remover? I figured it must be close to mineral spirits, which
>>Chris Campbell
>/ch
RE: [Cal_Boats] blood & bugs on paint
Husar, Charlie [USA]2010-11-22 23:32 UTC
I think OxyClean works on blood? Takes some soaking time.
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Chris
Sent: Monday, November 22, 2010 5:06 PM
As far as I know it toluene. The chemistry of organics (which I failed) is the chemistry of petroleum and natural based compounds.
As far as I know toluene and MEK are available at ACE. These are basically paint strippers.
I would think you would have better luck with a very mild rubbing compound as it seams to me the "juices" have impregnated the dried paint layer. Hence nothing is taking the stuff off.
I'll try some toluene and/or MEK (if thinned Simple Green does not help); have both on hand but they seemed a bit aggressive. I'll try a bit on a cotton swab. Luckily, the stuff is mostly on the rocker panels and lower portions of doors, where any screw-ups are less visible.
This stuff is surface-layer accumulation. If I work at it with a finger nail, most spots scrape off. It's just a pain to do it that way. If all else fails, I may try sharpening a piece of some durable wood like oak as a mild scraper.
It is interesting how the organic solvents are so picky about what they dissolve. I'm just hoping that whatever works on bug juice & carcass blood doesn't like car paint.
Once you buff out the stuff, then remember to add polish out the areas and wax liberally.
Best regards
On Mon, Nov 22, 2010 at 10:23 AM, Chris <cc… [at] lsnm.org<mailto:cc… [at] lsnm.org>> wrote:
I would go in this order. Obviously try detergent and hot water first. These are all automotive products:
So what is tar remover? I figured it must be close to mineral spirits, which had no effect. Is kerosene or diesel fuel significantly different?
Danny2010-11-22 23:35
Steel wool!
> Cal sailors:
<SNIP>
> prized '86 Mustang?
> Chris Campbell
Allen Edwards2010-11-23 00:44 UTC
This is the black streak remover I have used for cleaning my RV. It works
great.
http://www.starbrite.com/productdetail.cfm?ID=1014&ProductCat=Marine&ProductSCat=Cleaners%20-%20Washes%20Marine&ProductSSCat=Black%20Streak%20Remover
<http://www.starbrite.com/productdetail.cfm?ID=1014&ProductCat=Marine&ProductSCat=Cleaners%20-%20Washes%20Marine&ProductSSCat=Black%20Streak%20Remover>
On Mon, Nov 22, 2010 at 3:35 PM, Danny <db… [at] easystreet.net> wrote:
> Steel wool!
> --- In Ca… [at] yahoogroups.com <Cal_Boats%40yahoogroups.com>, Chris
> > Cal sailors:
> <SNIP>
> > prized '86 Mustang?
> > Chris Campbell
john raxter2010-11-23 01:21 UTC
According to NCIS and several murder mysteries, Clorox bleach should remove
the blood stains. Bug and tar remover from your local auto parts store
should handle the rest.
YMMV (haven't tried the blood stain removal, but bug and tar works)
John
Of Chris
Sent: Monday, November 22, 2010 9:04 AM
Subject: [Cal_Boats] blood & bugs on paint
Cal sailors:
prized '86 Mustang?
ti… [at] ch2m.com2010-11-23 02:14 UTC
80 grit 'll gitter
Cheers,
Timm Lessley
(Sent from Blackberry)
(503) 863-4019
Sent: Monday, November 22, 2010 04:35 PM
Subject: [Cal_Boats] Re: blood & bugs on paint
Steel wool!
--- In Ca… [at] yahoogroups.com<mailto:Cal_Boats%40yahoogroups.com>, Chris <ccampbell@...> wrote:
> Cal sailors:
<SNIP>
> prized '86 Mustang?
> Chris Campbell
Gerald Sobel2010-11-23 04:49 UTC
Wouldn't a little bleach or hydrogen peroxide oxide the stain? Oxacylic acid maybe?
Otherwize, how about 30 grit?
--- On Mon, 11/22/10, ti… [at] ch2m.com <ti… [at] ch2m.com> wrote:
Subject: Re: [Cal_Boats] Re: blood & bugs on paint
Date: Monday, November 22, 2010, 6:14 PM
80 grit 'll gitter
Cheers,
Timm Lessley
(503) 863-4019
Steel wool!
> Cal sailors:
<SNIP>
> prized '86 Mustang?
> Chris Campbell
Helen Horn2010-11-23 05:11 UTC
Years ago a car fanatic owned a beautiful El Camino, he cleaned it with
kerosene, then washed and waxed it. The first time I saw the process, all I
could think of was the danger. Lucky for me, my cals are too big to hurtle
through space (and california has a 55 mph trailer law). Maybe after you clean
it up you can put some "glass wax" type stuff to rub off when you reach your
destination. Some boats that are near airports or dirty cities get black spots
that are really hard to remove also. Messes up the nonskid especially. HH
Sent: Mon, November 22, 2010 6:03:53 AM
Cal sailors:
prized '86 Mustang?
Allen Edwards2010-11-23 05:33 UTC
I have sanded my car and that will work on some kinds of paints. It wasn't
60 grit though, it was 1500 grit at most, maybe finer.
> clean it up you can put some "glass wax" type stuff to rub off when you
> reach your destination. Some boats that are near airports or dirty cities
> get black spots that are really hard to remove also. Messes up the nonskid
> especially. HH
> *From:* Chris <cc… [at] lsnm.org>
> *Sent:* Mon, November 22, 2010 6:03:53 AM
> *Subject:* [Cal_Boats] blood & bugs on paint
> Cal sailors:
> prized '86 Mustang?
> Chris Campbell
RE: [Cal_Boats] Re: blood & bugs on paint
Husar, Charlie [USA]2010-11-23 05:40 UTC
By the time Chris is done putting on and grinding off everything that has been suggested, there won't be much left of the car. Chris, I suggest you short-circuit the experiments and just go right to 10 molar HCl. When the smoke clears, those damn stains will sure be gone.
Sent: Monday, November 22, 2010 11:49 PM
80 grit 'll gitter
Cheers,
Timm Lessley
(503) 863-4019
Steel wool!
--- In Ca… [at] yahoogroups.com</mc/compose?to=Cal_Boats%40yahoogroups.com>, Chris <ccampbell@...> wrote:
> Cal sailors:
<SNIP>
> prized '86 Mustang?
> Chris Campbell
Chris2010-11-23 13:57 UTC
> on to are scraperite blades (http://www.scraperite.com/). They might
> give you a truer edge than sharpened wood.
> my car for bugs and other derbis also. Pretty simple idea but
> basically a razor shaped blade made in various denistys of plastic for
> applications exactly like this. Also did a dream job removing the
> vinyl graphics that the previous owner of my 28-2 applied 10+ years ago.
I recall now seeing a mention of those in some boating magazine...the
idea sounded far-fetched. But now I'll seek some out and save my finger
nails.
Allen Edwards2010-11-23 17:08 UTC
Did anyone point out that using your finger nail might remove the blood
stains? I use that method every time I wash my car.
> to are scraperite blades (http://www.scraperite.com/). They might give
> for bugs and other derbis also. Pretty simple idea but basically a razor
> shaped blade made in various denistys of plastic for applications exactly
> like this. Also did a dream job removing the vinyl graphics that the
> I recall now seeing a mention of those in some boating magazine...the idea
> sounded far-fetched. But now I'll seek some out and save my finger nails.
> Chris Campbell
Chris2010-11-23 17:21 UTC
> blood stains? I use that method every time I wash my car.
Actually, I suggested that I had done that but it's a pain because of
all the little spatters.
But the further question, Allen, is why you need to get blood off every
time you wash your car. I think I'll stay out of your way.
Allen Edwards2010-11-23 19:53 UTC
Well... actually it is my boat that I have to get blood off of every time I
wash it. My crew is accident prone and my boat has a constant stream of
crew safety improvements going on.
> Actually, I suggested that I had done that but it's a pain because of all
> Chris Campbell
Chris2010-11-23 20:04 UTC
> time I wash it. My crew is accident prone and my boat has a constant
> stream of crew safety improvements going on.
Get a younger crew so you don't have a bunch of old farts gulping Plavix
and aspirin and bleeding all over. A couple years ago I stubbed my toe
on mast-stepping day and kept leaving a trail of blood. Finally had to
beg a band-aid from a powerboater (I can be humble when necessary).
After that, I added a small collection of first aid items on the Cal 20,
and haven't needed one since. It's kinda like putting on the foul
weather gear to prevent rain. And when I got one year post-stents, they
decided I don't need the Plavix any more so I'm better at retaining
blood anyway.
John Boyce2010-11-23 21:37 UTC
I previously worked at a plant that belched iron powders out the vents.
Every car became contaminated to the extent that steel wool was normally
used to clean the windshields. The one thing that seemed to work on the
painted surfaces was Mother's brand cleaners. This stuff had a clay
component and brought a smooth finish to even the worst vehicle.
Good Luck
John B
Cal22 #650
Of Allen Edwards
Sent: Tuesday, November 23, 2010 12:33 AM
to hurtle through space (and california has a 55 mph trailer law). Maybe
after you clean it up you can put some "glass wax" type stuff to rub off
when you reach your destination. Some boats that are near airports or dirty
cities get black spots that are really hard to remove also. Messes up the
Cal sailors:
prized '86 Mustang?
chris1232010-11-23 23:00 UTC
Thats ok on a modern cars. Did a stint in auto for a while and the painting
systems have changed significantly from when Chris C's car was painted.
Modern paints are a two component system, color and clear coat over a primed
body shell. Its a system with the clear coat being the inhibitor of stuff
getting to the paint.
On Chris C's vintage model it would have been a one part system with the
paint being a high gloss finish. Once this is subject to air from movement,
UV from the sun and micro grit again from moving, the gloss quickly wears
off as its a skin on the paint as it dries. Hence in the old days you waxed
after your removed the old stuff. (sailing content: same procedure for
topsides)
So once stuff gets into the porous paint its in there pretty good as it no
longer surface debris. Rather the organic liquids have penetrated the paint
layer similar to tanin and other stuff in the water that gets into haze
paint. On boat paint an acid wash will get that stuff out. On a car, it gets
a bit tricky.
Best regards
On Tue, Nov 23, 2010 at 12:08 PM, Allen Edwards <
> Allen
>> car for bugs and other derbis also. Pretty simple idea but basically a
>> razor shaped blade made in various denistys of plastic for applications
>> exactly like this. Also did a dream job removing the vinyl graphics that
>> Chris Campbell
