6 messages2010-11-25 13:22 UTCthrough 2010-11-26 11:41 UTC
Re: [Cal_Boats] Cal 29 Flooring
Paul2010-11-25 13:22 UTC
Chris I've not been following this thread so if this is a repeat I apologize. At the boat show this year there was a company selling essentially a vinyl overlay that looks like teak and Holly. Fairly expensive as I recall I Think around $9 - $10 per SF but if you don't have that much it may be doable. I'm not at home now but if you want the name of the company let me know and I'll look thru my bag o stuff from the show.
Paul
chris123 <ch… [at] gmail.com> wrote:
>Greets:
>Checked out the cork flooring and I dont think its a good solution.
>Was wondering if anyone has any recommendations for a suitable
>flooring substrate for a 29 other then rugs (get too dirty too fast,
>collect dog hair etc) This issue with the 29 is the curvature of the
>pan. So far the only other thing I have found on line is vinyl teak
>and holly replicate. BTW does anyone have the length of the pan info
>handy. Its one of the things I forgot to measure. Boat is in NJ and Im
>in the North.
>Many thanks
>/ch
chris1232010-11-25 13:49 UTC
No its OK..Defender and several others sell this stuff. Couple of issues
with the type based on my reading.
Issue one is that that stuff comes in 6 ft length, which requires a seam
(mechanically welded...ie: special tools) if your length is longer. Hence
the question about the pan length as I don't have that number, but seem to
recall it was closer to eight. If that is correct, its not a DIY project to
use this material type independent of vendor.
Tiles are not acceptable as you need to bond them to the floor making it
hard to remove. A floating floor system pinned at the sides with teak strips
is what I'm looking for given the shape of the 29 pan. Two lateral length of
2" hook and loop Velcro down the center, one on each side of the bilge, and
on length along each outer side, then trimmed with a teak strip should hold
the plate in place. Interesting challenge to come up with the right
material however.
The alternative is to get rid of the pooch.....but thats not really an
option...:) Actually I make more of a mess below then she does. Its just the
hair in the carpet that eventually gets to you and requires constant
cleaning. So something non absorbent, and with no or limited fiber is what
I'm looking for and it needs to be flexible enough to lie flat in the
curvature of the pan.
thanks and best regards
> Paul
Allen Edwards2010-11-25 17:32 UTC
Watch the video on this page. You can do the welding yourself
http://plasteak.com/osc/product_info.php?cPath=1_30_74&products_id=417&osCsid=6844388a7c99ce4574edcdfd0d011fb2
<http://plasteak.com/osc/product_info.php?cPath=1_30_74&products_id=417&osCsid=6844388a7c99ce4574edcdfd0d011fb2>This
like a fairly high end solution where they build it up for you from your
drawing
http://flexiteek.com/
<http://flexiteek.com/>Just a google search, no special knowledge on my
part.
> material however.
> /ch
>> Paul
chris1232010-11-26 01:43 UTC
Much nicer then the vinyl I saw at Home Depot today.....:) Think I will get
the sample kit and check it out. What will be interesting is the how thick
and pliable the material is as this will determine if a double cut is
possible. Therein lies the problem with all flooring materials as if its too
tuff an accurate double is not viable. Been there, done that, got the T
shirt.
Many thanks...
Final question, any one have experience with this product first hand....??
On Thu, Nov 25, 2010 at 12:32 PM, Allen Edwards <
RE: [Cal_Boats] Cal 29 Flooring
Husar, Charlie [USA]2010-11-26 04:45 UTC
Chris, I watched the video on seaming. The music made me think that Freddie was about to jump in with his chainsaw. Seriously, you will note that the material they used had no particular pattern or direction. I think getting an "almost invisible" seam with some wood looking veneer would be difficult, especially across, instead of with, the wood appearance pattern. Also, HH pointed out the thermal protection appears to be close to nil. Shave the dog.
Happy Thanksgiving All
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of chris123
Sent: Thursday, November 25, 2010 8:43 PM
Subject: Re: [Cal_Boats] Cal 29 Flooring
Much nicer then the vinyl I saw at Home Depot today.....:) Think I will get the sample kit and check it out. What will be interesting is the how thick and pliable the material is as this will determine if a double cut is possible. Therein lies the problem with all flooring materials as if its too tuff an accurate double is not viable. Been there, done that, got the T shirt.
Many thanks...
On Thu, Nov 25, 2010 at 12:32 PM, Allen Edwards <al… [at] paloaltophoto.com<mailto:al… [at] paloaltophoto.com>> wrote:
chris1232010-11-26 11:41 UTC
Ya know its interesting the challenges that sailboat ownership throws at
you. Not to belabor the point, but I dont think she would appreciate it....
http://picasaweb.google.com/lh/photo/inhV1h_CcYGd-Y4HOK25CA?feat=directlink
Furthermore, the seeming component may need some more study as the
installation notes speak of seaming along the holly strip, ie horizontally
not longitudinally.
Appreciate what Helen points out wrt to carpeting but prefer not to go that
route.
On Thu, Nov 25, 2010 at 11:45 PM, Husar, Charlie [USA] <
> Shave the dog.
> Cheers
> Charlie
> Behalf Of *chris123
> *Sent:* Thursday, November 25, 2010 8:43 PM
> *Subject:* Re: [Cal_Boats] Cal 29 Flooring
> shirt.
> Many thanks...
> /ch
