2 messages2010-11-29 16:42 UTCthrough 2010-11-29 16:50 UTC
Handrails (was pan measurements)
pw… [at] aol.com2010-11-29 16:42 UTC
I would caution that the measurements for our boats can vary a little. A
"production" boat is not necessarily a "precision" boat
That's for sure. Hell, I've only seen a few Cal 39's with my same floor
plan!
BTW removed all my exterior handrails last week on those 65 deg days we had
and will need to replace a couple of them as I had to cut one off of the
last bolt as the head broke off and there was not enough below to grab onto
with anything. If I remember correctly I think I had 5 or 6 heads break
off. Good news is that there didn't appear to be any major leaks into the
deck. I reamed out all the wood that I could with a dremel tool and filled
all holes with epoxy. Am attempting to do this with all holes in the deck
before Christmas. Still have to do the dorades, the companionway cover and
4 mast base blocks.
Hoping for good weather till Christmas!!
Paul West
Adventure Kwest
'80 Cal 39
RE: [Cal_Boats] Handrails (Paul)
Husar, Charlie [USA]2010-11-29 16:50 UTC
Frost on the pumpkin this morning, Paul. Hope you can get that epoxy to set up. Maybe a heater inside the boat will set things up a little faster.
Sent: Monday, November 29, 2010 11:42 AM
Subject: [Cal_Boats] Handrails (was pan measurements)
I would caution that the measurements for our boats can vary a little. A "production" boat is not necessarily a "precision" boat
That's for sure. Hell, I've only seen a few Cal 39's with my same floor plan!
BTW removed all my exterior handrails last week on those 65 deg days we had and will need to replace a couple of them as I had to cut one off of the last bolt as the head broke off and there was not enough below to grab onto with anything. If I remember correctly I think I had 5 or 6 heads break off. Good news is that there didn't appear to be any major leaks into the deck. I reamed out all the wood that I could with a dremel tool and filled all holes with epoxy. Am attempting to do this with all holes in the deck before Christmas. Still have to do the dorades, the companionway cover and 4 mast base blocks.
Paul West
Adventure Kwest
'80 Cal 39
