16 messages2010-11-26 03:40 UTCthrough 2010-12-02 13:41 UTC
29 floor
Helen Horn2010-11-26 03:40 UTC
the laminate sells in several lengths, has good edges, comes in two stiffnesses,
but its more or less formica. You could make yourself a false floor with ribs
and half inch ply and come up flush with the pan and the table mount, or lower
if you are taller and put anything on it you want but it could be flattened out
that way. Would add at least 30 pounds to the boat, but a big air space for
insulation. a long piano hinge down the center so you can get it in and out, in
line with the bumpout of the settee jog. I think I ate too much pumpkin pie.
sorry, I get carried away. HH
Re: [Cal_Boats] 29 floor
chris1232010-11-26 11:44 UTC
Cute....sure it was the pumpkin.....perhaps the fermented apple juice.
Anywho....have a great holiday.
> stiffnesses, but its more or less formica. You could make yourself a false
> floor with ribs and half inch ply and come up flush with the pan and the
> table mount, or lower if you are taller and put anything on it you want but
> it could be flattened out that way. Would add at least 30 pounds to the
> boat, but a big air space for insulation. a long piano hinge down the
> center so you can get it in and out, in line with the bumpout of the settee
> jog. I think I ate too much pumpkin pie. sorry, I get carried away. HH
Helen Horn2010-11-26 22:15 UTC
Chris, if you are really into the teak and holly laminate, you could take one of
those multi-tools and cut the ends you would join into staggered edges to match
the different ends so it would look
like laid-down planking. a lot like repairing an old oak floor or similar. you
would cut on the outside of the line on one sheet and have a pattern to mark and
then cut the second sheet end to interlock the other piece. you'd want to be
sure you cut the wood so it didn't splinter. If you used a wood veneer, you
could razor cut on both layers at once. Better yet, just buy veneer from a
supplier in each wood you want and rip strips to glue down in random lengths to
make your own pattern on whatever you want for a base? thin mahogany ply for
instance? new idea can go from here. More pie, anybody? HH
Sent: Fri, November 26, 2010 3:44:02 AM
Subject: Re: [Cal_Boats] 29 floor
chris1232010-11-26 23:15 UTC
One more piece please Helen....and don't hold the whipping cream please...:)
I gave that method some thought and to be honest its far too much work to do
it properly. Basically you would need a 1/4" to 3/8 sheet of marine ply,
steam bend it to shape of the 29 pan, then start to scarf in the boards. Six
weeks later you have a floor and if anyone scratches it they go overboard.
So in order to avoid the complications of search and rescue and the
potential pending law suite, decided against that method.
More cider please? Many thanks
Re: [Cal_Boats] 29 floor(Chris H)
david dobbs2010-11-27 03:57 UTC
Chris,
I did some work on this issue too. I was advised to buy 1/4" teak & holly plywood, cut it to fit and score the back with a circular saw, 1/8" deep.(In the long direction, multiple times.) This will allow one to be able to bend the plywood enough to glue it in the necessary curved position. I haven't tried this, maybe Helen can comment?
Dave D.
Date: Friday, November 26, 2010, 5:15 PM
I gave that method some thought and to be honest its far too much work to do it properly. Basically you would need a 1/4" to 3/8 sheet of marine ply, steam bend it to shape of the 29 pan, then start to scarf in the boards. Six weeks later you have a floor and if anyone scratches it they go overboard.
So in order to avoid the complications of search and rescue and the potential pending law suite, decided against that method.
Allen Edwards2010-11-27 06:06 UTC
My cabin top is made of 6 layers of 1/4 inch plywood and it is curved. I
don't know how that curve compares to what you need but it was curved
without any saw cuts so I would think something like this would certainly
work. I think wood would be warmer than vinyl.
Of course, you could also do away with the plywood and just get a bunch of
teak and holly or just teak and do it the old fashioned way.
By the way, I put teak and holly plywood on the cabin sole on Papoose. It
is not varnished. I don't understand why people varnish teak and holly.
What I wanted was something that would give good grip when wet and it does.
Varnish it and it will be slippery when wet. The whole reason you use teak
and holly is that it doesn't need any finish and the holly will stay white
if it gets wet. Other white woods turn black when they get wet. So people
take this traditional material carefully selected to be able to get wet and
varnish it. Looks great varnished but it doesn't work well that way. There
used to be an expression in race car circles "if it don't go, chrome it"
Maybe in boats it is "if it don't go, varnish it". To each their own but
just throwing this out to point out you don't need to varnish it. Plus, if
it gets scratched, doesn't really matter. You can see a picture that shows
some of the cockpit sole on Papoose on this page:
http://l-36.com/papoose.php
On Fri, Nov 26, 2010 at 7:57 PM, david dobbs <tm… [at] yahoo.com> wrote:
> Chris,
> Dave D.
> --- On *Fri, 11/26/10, chris123 <ch… [at] gmail.com>* wrote:
> From: chris123 <ch… [at] gmail.com>
> please...:)
> /ch
Re: [Cal_Boats] 29 floor(Allen)
david dobbs2010-11-27 07:08 UTC
Allen,
You are right on that. I would want a surface with good footing when wet. I knew that about holly, the only light wood that won't turn black when wet.
Dave D.
--- On Sat, 11/27/10, Allen Edwards <al… [at] PaloAltoPhoto.com> wrote:
Subject: Re: [Cal_Boats] 29 floor(Chris H)
Date: Saturday, November 27, 2010, 12:06 AM
My cabin top is made of 6 layers of 1/4 inch plywood and it is curved. I don't know how that curve compares to what you need but it was curved without any saw cuts so I would think something like this would certainly work. I think wood would be warmer than vinyl.
Of course, you could also do away with the plywood and just get a bunch of teak and holly or just teak and do it the old fashioned way.
By the way, I put teak and holly plywood on the cabin sole on Papoose. It is not varnished. I don't understand why people varnish teak and holly. What I wanted was something that would give good grip when wet and it does. Varnish it and it will be slippery when wet. The whole reason you use teak and holly is that it doesn't need any finish and the holly will stay white if it gets wet. Other white woods turn black when they get wet. So people take this traditional material carefully selected to be able to get wet and varnish it. Looks great varnished but it doesn't work well that way. There used to be an expression in race car circles "if it don't go, chrome it" Maybe in boats it is "if it don't go, varnish it". To each their own but just throwing this out to point out you don't need to varnish it. Plus, if it gets scratched, doesn't really matter. You can see a picture that shows some of the cockpit sole on Papoose on this page:
Chris,
Dave D.
Allen Edwards2010-11-27 07:34 UTC
If you decide to go the plywood route perhaps the way I did mine would help.
First I had an old floor made of 12 inch plywood boards. You don't have
that but some scrap plywood pieces may be available. I screwed them
together or cut them until I got the sections I wanted for my new floor.
You might even be able to use cardboard for this step. Next I got some
cheap plywood and cut it to shape using the boards as a template and made
sure everything fit. I cut what was too big and made notes on what was too
small. Only then did I cut the real wood. In my case, I glued teak to the
edges. I would not bother if I did it again. One piece was too big by 2x
the teak edging so I cut that down and all was good. Having read all the
posts in this thread, I would go the teak and holly 1/4 or 3/8 plywood route
if I could buy some at a good price. I bought mine and had it shipped. You
can find the vendor on my web site. It saved a lot of money but for one
piece if you can find it locally that might be cheaper. When I bought mine,
there wasn't any of any thickness in California. The problem with
this instillation is how to hold it down. Perhaps gluing some runners and
then screwing the plywood to the runners would work. You might need thicker
plywood for that though. You also might lose an inch of headroom. I went
to great lenghts to avoid any screws in mine and it really hasn't worked
out that well. If I had just decided to screw it all down to begin with, I
think I would have been happier in the long run. After a while, I wouldn't
even notice the screws. But at this point I don't notice the lose boards
that much...
On Fri, Nov 26, 2010 at 11:08 PM, david dobbs <tm… [at] yahoo.com> wrote:
> Allen,
> Dave D.
> --- On *Sat, 11/27/10, Allen Edwards <al… [at] PaloAltoPhoto.com>*wrote:
> Allen
> On Fri, Nov 26, 2010 at 7:57 PM, david dobbs <tm… [at] yahoo.com<http://us.mc1113.mail.yahoo.com/mc/compose?to=tm… [at] yahoo.com>
> > wrote:
> Chris,
> Dave D.
> --- On *Fri, 11/26/10, chris123 <ch… [at] gmail.com<http://us.mc1113.mail.yahoo.com/mc/compose?to=ch… [at] gmail.com>
> >* wrote:
> From: chris123 <ch… [at] gmail.com<http://us.mc1113.mail.yahoo.com/mc/compose?to=ch… [at] gmail.com>
> To: Ca… [at] yahoogroups.com<http://us.mc1113.mail.yahoo.com/mc/compose?to=Ca… [at] yahoogroups.com>
> please...:)
> /ch
Helen Horn2010-11-27 08:44 UTC
yes, this grooving of the back of the wood panels is called "easing". they use
this to make many rounded forms; staircase wraps, oldfashioned camper shells.
you do have to be sure your sawblade depth doesn't change. test it first, very
challenging, and the finished product relies on the remaining veneer to hold it
together on the face side. it could be fragile if it flexes..HH
Sent: Fri, November 26, 2010 7:57:12 PM
Chris,
Dave D.
>/ch
Helen Horn2010-11-27 08:56 UTC
Actually, I didn't have that much pie, but I meant to suggest the backing ply
could be eased as in the other reply, meaning very shallow easing cuts on the
1/4 or 3/8, and securing it to the floor pan, then apply the wood strips with a
good glue like smiths tropical which can handle weather, or a pva type glue.then
you can seal it really good to protect from scratches and stains. did you get
floor measurements yet? going to the boat in the morning, can get them for you.
HH
Sent: Fri, November 26, 2010 3:15:50 PM
chris1232010-11-27 13:52 UTC
Length, width and depth (that is at the center point to get curvature angle)
would be marvelous. Many thanks.
Cutting the back of the board to get it to bend would not be a good practice
for this kind of thing as even though its marine ply, the cuts would open
the core to water penetration.
If this method were used, if you steamed the substrate to form and cut it to
length, then you would only need two battens on either side, port and
starboard at the base of the settee's to hold the plate in place,
effectively creating a floating floor system, further secure by a simple
strip of velcro down the center, which may or may not be needed. Whats nice
is the entire thing come out as needed and no adhesive would be required.
Its a lot of work however. You would need to build a plug mold of the pan,
steam the substrate in place then each strip would have to cut individual on
one side to get the appropriate angle with no two angles being the same.
Good ideas but far too much work. Investigation vinyl ....;)
> ply could be eased as in the other reply, meaning very shallow easing cuts
> on the 1/4 or 3/8, and securing it to the floor pan, then apply the wood
> strips with a good glue like smiths tropical which can handle weather, or a
> pva type glue.then you can seal it really good to protect from scratches and
> stains. did you get floor measurements yet? going to the boat in the
> morning, can get them for you. HH
> *From:* chris123 <ch… [at] gmail.com>
> *Sent:* Fri, November 26, 2010 3:15:50 PM
> *Subject:* Re: [Cal_Boats] 29 floor
> please...:)
> /ch
chris1232010-11-27 14:01 UTC
Helen suggested the same and it could work. The only change I would make if
going this route is once the floor is in place sitting in that well curved
pan of the 29 (approx 4" drop at the center if not more...working from
memory) I would cross brace the plate across the top to hold the shape. Then
flip it over and epoxy the back side to prevent water penetration into the
core of the board. Its marine ply yes, but still subject to water
absorption. So a good layer of epoxy on the backside of the board which
would require a slight cut every 1/2" or so to get it to bend, would prevent
any water from getting in.
The trouble here is that it would have to be done all inside the boat, Then
again careful measurements would have to be taken to see if you can even
slip a panel that large into the cabin from the companion way....food for
thought. Thats what winters for...I guess.
Many thanks
On Fri, Nov 26, 2010 at 10:57 PM, david dobbs <tm… [at] yahoo.com> wrote:
> Chris,
> Dave D.
DavidOwen2010-11-27 16:40 UTC
1/4" plywood will follow the curve of a Cal 29 floor without any
kerfing or easing. 1/2" plywood will not. 3/8" marine ply will
follow the curvature without easing, but only after it completely
breaks up inside (Loud, sharp cracking sounds) during that process. I
learned these things the hard way while re-building the bilge and keel
area of my 2-29. I ended up laminating two sheets of 1/4" marine ply
for the base, and laminating 1/4" of teak/holly veneer for the
surface. A much better way to do it -- when you laminate two surfaces
into a curve you lock the curve in and it becomes very stiff and
strong. Much stronger than the original 1/2" ply idea, which would
have gone on trying to straighten itself back to flat for most of
eternity.
If you are fastening teak and holly plywood to the original fiberglass
sole, just rough it up really good and after fitting the plywood
perfectly (I used a rosin paper template transferred to a 1/8" cheapo
door skin, then transferred to the teak/holly veneer ply) and glue it
down with slightly thickened epoxy.
I taped and covered the teak and holly side very carefully in case any
epoxy spooged out and needed wiping up. I used about a dozen 60 lb.
bags of sand to weight the plywood down over night while the epoxy set
up. Look at the photos in the 1975 Cal 2-29 "Mariposa" album on the
group page.
Adding 1/4" of plywood to the original glass floor pan will stiffen it
up somewhat and you will have less oil-canning as you walk about the
cabin.
One thing: the teak and holly that I ordered is actually pretty
soft. When my crew tossed a spare halyard down below, the shackle
made a deep dent. Subsequent wounds are pretty prominent. I am used
to the patine of age and sort of like it, but it didn't take long for
it to look old enough to be original equipment.
HTH...
Wilkie
> "easing". they use this to make many rounded forms; staircase wraps,
> oldfashioned camper shells. you do have to be sure your sawblade
> depth doesn't change. test it first, very challenging, and the
> finished product relies on the remaining veneer to hold it together
> From: david dobbs <tm… [at] yahoo.com>
> Chris,
> comment?
> Dave D.
> please...:)
> /ch
Allen Edwards2010-11-27 17:39 UTC
Let me add a couple of ideas. One is that you don't need to have the floor
be all one piece. My floor is 7 pieces for example. You can section it off
so that you can remove the pieces, build it out of the boat, etc. Second is
that you can make these pieces flat, making for a horizontal walking surface
and some sloped side pieces at the edge that go up a couple of inches.
Doing a rough calculation assuming your pan is 4 feet wide (I have no idea
what it is) and assuming it goes up 4 inches on the edge. If you make your
floor out of 3 pieces 16" wide with the center one being your walking area
and level with no bend, it would be off the pan by 1/2 inch in the center.
Same on the side pieces, maximum clearance 1/2 inch. I made a sketch ;-)
Then your curving would consist of cutting curved support pieces for under
the flat boards, much easier. You could use 1/2 inch ply with occasional
bracing, maybe at 16 inches.
On Sat, Nov 27, 2010 at 8:40 AM, DavidOwen <wi… [at] mariposasailing.com>wrote:
> 1/4" plywood will follow the curve of a Cal 29 floor without any kerfing or
> easing. 1/2" plywood will not. 3/8" marine ply will follow the curvature
> without easing, but only after it completely breaks up inside (Loud, sharp
> cracking sounds) during that process. I learned these things the hard way
> while re-building the bilge and keel area of my 2-29. I ended up laminating
> two sheets of 1/4" marine ply for the base, and laminating 1/4" of
> teak/holly veneer for the surface. A much better way to do it -- when you
> laminate two surfaces into a curve you lock the curve in and it becomes very
> stiff and strong. Much stronger than the original 1/2" ply idea, which
> would have gone on trying to straighten itself back to flat for most of
> eternity.
> sole, just rough it up really good and after fitting the plywood perfectly
> (I used a rosin paper template transferred to a 1/8" cheapo door skin, then
> transferred to the teak/holly veneer ply) and glue it down with slightly
> thickened epoxy.
> epoxy spooged out and needed wiping up. I used about a dozen 60 lb. bags of
> sand to weight the plywood down over night while the epoxy set up. Look at
> the photos in the 1975 Cal 2-29 "Mariposa" album on the group page.
> Adding 1/4" of plywood to the original glass floor pan will stiffen it up
> somewhat and you will have less oil-canning as you walk about the cabin.
> One thing: the teak and holly that I ordered is actually pretty soft.
> When my crew tossed a spare halyard down below, the shackle made a deep
> dent. Subsequent wounds are pretty prominent. I am used to the patine of
> age and sort of like it, but it didn't take long for it to look old enough
> HTH...
> Wilkie
> use this to make many rounded forms; staircase wraps, oldfashioned camper
> shells. you do have to be sure your sawblade depth doesn't change. test it
> first, very challenging, and the finished product relies on the remaining
> veneer to hold it together on the face side. it could be fragile if it
> flexes..HH
> *From:* david dobbs <tm… [at] yahoo.com>
> *Sent:* Fri, November 26, 2010 7:57:12 PM
> *Subject:* Re: [Cal_Boats] 29 floor(Chris H)
> Chris,
> Dave D.
> please...:)
> /ch
RE: [Cal_Boats] 29 floor(Chris H)
r good2010-12-02 12:17 UTC
"Look at the photos in the 1975 Cal 2-29 "Mariposa" album on the group page"
only if you wish to risk death by drooling.
reggie
Date: Sat, 27 Nov 2010 08:40:33 -0800
1/4" plywood will follow the curve of a Cal 29 floor without any kerfing or easing. 1/2" plywood will not. 3/8" marine ply will follow the curvature without easing, but only after it completely breaks up inside (Loud, sharp cracking sounds) during that process. I learned these things the hard way while re-building the bilge and keel area of my 2-29. I ended up laminating two sheets of 1/4" marine ply for the base, and laminating 1/4" of teak/holly veneer for the surface. A much better way to do it -- when you laminate two surfaces into a curve you lock the curve in and it becomes very stiff and strong. Much stronger than the original 1/2" ply idea, which would have gone on trying to straighten itself back to flat for most of eternity.
If you are fastening teak and holly plywood to the original fiberglass sole, just rough it up really good and after fitting the plywood perfectly (I used a rosin paper template transferred to a 1/8" cheapo door skin, then transferred to the teak/holly veneer ply) and glue it down with slightly thickened epoxy.
I taped and covered the teak and holly side very carefully in case any epoxy spooged out and needed wiping up. I used about a dozen 60 lb. bags of sand to weight the plywood down over night while the epoxy set up. Look at the photos in the 1975 Cal 2-29 "Mariposa" album on the group page.
Adding 1/4" of plywood to the original glass floor pan will stiffen it up somewhat and you will have less oil-canning as you walk about the cabin.
One thing: the teak and holly that I ordered is actually pretty soft. When my crew tossed a spare halyard down below, the shackle made a deep dent. Subsequent wounds are pretty prominent. I am used to the patine of age and sort of like it, but it didn't take long for it to look old enough to be original equipment.
HTH...
Wilkie
yes, this grooving of the back of the wood panels is called "easing". they use this to make many rounded forms; staircase wraps, oldfashioned camper shells. you do have to be sure your sawblade depth doesn't change. test it first, very challenging, and the finished product relies on the remaining veneer to hold it together on the face side. it could be fragile if it flexes..HH
Chris,
Dave D.
Jeff Raethke2010-12-02 13:41 UTC
Thanks for the early morning laugh, Reggie. Mariposa is beautiful. I'm in Wisconsin feeding my cows, looking out at frozen, snow covered ground. Talk of boats and sailing this time of year is more important than you may realize
By the way, I really enjoyed reading your daily travails of your summer cruise up the coast. It helped inspire my short cruise of the Mississippi this summer.
Best Regards
Jeff
> reggie
> From: wi… [at] mariposasailing.com
> HTH...
> Wilkie
> Chris,
> Dave D.
> /ch
