Re: [Cal_Boats] replacing antenna wiring (correction+)
(delete the word "Not". Meant to type now but it reads better without it).
Another point is that if you care about range, you can put a 6dB antenna on
the stern (8 ft high) and that would be a very good setup. I happen to have
a lot of them and didn't use it on my boat as I don't really care that much
about range. I do just fine with my home made stern mounted antenna.
On Fri, Dec 3, 2010 at 8:13 PM, Allen Edwards <al… [at] gmail.com>wrote:
> I found the old post from a year ago. It comes from Al Waschka. I copied
> it below. Note that with a 3dB antenna on the rail, not the masthead, the
> range would be 44.4 miles. Not, the CG is going to have a better antenna
> than that so the range would be more.
> Allen
> AREPS is a well-respected tool generated by/for the Navy for predicting
> radio communications range, particularly at VHF/UHF and over water. I
> modeled a path with one end at either 10 feet above the water (rail-mount)
> or at 50 feet (masthead), and calculated the range to a receiving antenna at
> 10 feet, 50 feet, or 150 feet (USCG base). I did this for 25 watts, using
> the specified receive sensitivity for an Icom M304 (0.22uV). I assumed 3 dB
> coax loss for 50 and 150 feet (better quality coax on the USCG tower) 1 dB
> loss for the rail mount, and 3 dB gain antennas on both ends. The results
> were not what I expected:
> Antenna 1 = 10’
> Power = 25W
> Range to 10’ receiver – 29.8 miles
> Range to 50’ receiver – 33.1 miles
> Range to 150’ receiver – 44.4 miles
> Antenna 1 = 50’
> Power = 25W
> Range to 10’ receiver – 31.6 miles
> Range to 50’ receiver – 37.3 miles
> Range to 150’ receiver – 48.7 miles
> The improvement of masthead mounting is way less than I expected. My
> current antenna is a masthead-mounted ½ wave, but given this data, I’m not
> sure I’d go to the trouble for a new installation.
> On Fri, Dec 3, 2010 at 6:20 PM, scott <ss… [at] yahoo.com> wrote:
>> http://en.wikipedia.org/wiki/VHF
>> --- On Fri, 12/3/10, Allen Edwards <al… [at] PaloAltoPhoto.com<allen.edwards%40PaloAltoPhoto.com>>
>> wrote:
>> > From: Allen Edwards <al… [at] PaloAltoPhoto.com<allen.edwards%40PaloAltoPhoto.com>
>> > Subject: Re: [Cal_Boats] replacing antenna wiring
>> > To: Ca… [at] yahoogroups.com <Cal_Boats%40yahoogroups.com>
>> > Date: Friday, December 3, 2010, 2:22 PM
>> > The VSWR of your antenna will be so much higher
>> > than the connector that there is no reason to worry about
>> > the connector if it makes it easier on your
>> > installation.
>> > An even easier solution is to mount the antanna
>> > on the stern pulpit. There was a thread on this some time
>> > ago and the conclusion was that range goes from something
>> > like 43 miles to 40 miles by mounting the antenna on the
>> > stern instead of on top of the mast. I don't remember
>> > the exact numbers. Also, if you mount on top of the mast
>> > make sure you have an antenna that is about 3 feet long as
>> > if you have one 18 inches, you will only be able to talk to
>> > the moon. Actually, you can probably reach the race
>> > committee but you won't get 40 miles out of a 1/4 wave
>> > antenna on top of the mast. You need a 1/2 wave one.
>> > Allen
>> > On Fri, Dec 3, 2010
>> > at 2:00 PM, Chris <cc… [at] lsnm.org <ccampbell%40lsnm.org>>
>> > wrote:
>> > On 12/3/2010 11:54 AM, Adam Thorp wrote:
>> > Greetings,
>> > I'm going to be rewiring the antenna
>> > on my cal28 this
>> > weekend and am looking for any advice.
>> > I read Allen's advice and will disagree slightly.
>> > On my other boat, I installed a bulkhead feed-through
>> > just like the
>> > one Allen showed. I did that because the mast gets
>> > unstepped and
>> > stepped again each year when the boat is hauled in the
>> > fall and
>> > launched in the spring. It'sa more convenient to
>> > just unscrew a
>> > PL-259 fitting. However, the arrangement requires two
>> > connectors
>> > plus the feed-through, and my understanding is that any
>> > disruptions
>> > in the coax will likely make the standing-wave ratio
>> > (SWR) worse. It
>> > has to do with the transmitted wave bouncing back
>> > instead of being
>> > radiated off the antenna. This diminishes your
>> > transmitted power.
>> > On my boat, I opted for convenience and not for maximum
>> > radiation.
>> > I don't have an SWR meter that will measure at VHF
>> > frequencies so I
>> > don't really know how much effect the connector
>> > arrangement has.
>> > But be aware that, at least in the abstract, you're
>> > better off with
>> > no discontinuities in your coax. Also be aware that I
>> > disregarded
>> > my own warning.
>> > One way to avoid that would be to make a little
>> > walking-cane-shaped
>> > deck fitting, basically the bottom half of a sink drain
>> > trap. Your
>> > coax would come down from the mast, turn upward into
>> > the fitting (to
>> > make a drip loop), then turn down inside the fitting
>> > through the
>> > deck. You could add some sealer, but the
>> > fitting's mouth would face
>> > downward so water would not be inclined to enter unless
>> > under
>> > pressure.
>> > By the way, the feed-through device is long enough to
>> > allow you to
>> > add a little wooden donut inside, under it. My
>> > boat's deck is not
>> > cored there, and is relatively thin, so I made the
>> > donut to make the
>> > mounting more substantial. Donut is varnished &
>> > looks spiffy.
>> > Chris Campbell
