6 messages2010-11-13 01:33 UTCthrough 2010-12-05 22:44
What is this line called
Allen Edwards2010-11-13 01:33 UTC
I have a control line that adjusts the twist of a jib without moving the jib
car. Of course, moving the car is the normal way of doing this. We use it
when we are sailing off the wind. I have drawn a sketch of what it looks
like. It is the blue line in the sketch. It goes to a winch but you could
also get mechanical advantage through some blocks.
I don't know what to call it.
Here are some things I have considered and the problem with them:
1) Downhaul -- line that pulls down the tack, not the clew
2) Barberhauler -- line that pulls the clew outboard although sometimes used
to describe an inhauler, which we also have.
3) Inhauler -- line that pulls the clew inboard.
4) Twing -- line that pulls the spinnaker pole down thus lowering the clew.
5) Fairlead -- the jib car.
By the way, this is 10 times easier to adjust than a line that moves the jib
car.
Anyone know what the correct name would be for this line?
Re: [Cal_Boats] What is this line called [1 Attachment]
Allen Edwards2010-11-13 01:44 UTC
By the way, the sketch doesn't really show how I control it. I should have
just attached a photo, which I now have. I get a 2:1 advantage right at the
start which makes it a little easier to control.
On Fri, Nov 12, 2010 at 5:33 PM, Allen Edwards <
al… [at] paloaltophoto.com> wrote:
> [Attachment(s) <#12c42de2680f48b7_TopText> from Allen Edwards included
> below]
> jib car. Of course, moving the car is the normal way of doing this. We use
> it when we are sailing off the wind. I have drawn a sketch of what it looks
> used to describe an inhauler, which we also have.
> jib car.
> Allen
RE: [Cal_Boats] What is this line called [1 Attachment]
Husar, Charlie [USA]2010-11-13 13:46 UTC
Allen, I would call anything that pulls the jib sheet out or in or down (or up?) a Barberhauler. Not sure on that. One correction - the twinger pulls the spinnaker sheet down. The pole height is controlled separately.
Downhaul needs a modifier such as "jib" (could also be a cunningham). I use the term downhaul for spin pole control as well.
When things get hectic, I call everything "That!" or "The Green (insert desired color) One!". After all, colorful words are permitted in these situations.
Sent: Friday, November 12, 2010 8:34 PM
Subject: [Cal_Boats] What is this line called [1 Attachment]
[Attachment(s) from Allen Edwards included below]
I have a control line that adjusts the twist of a jib without moving the jib car. Of course, moving the car is the normal way of doing this. We use it when we are sailing off the wind. I have drawn a sketch of what it looks like. It is the blue line in the sketch. It goes to a winch but you could also get mechanical advantage through some blocks.
2) Barberhauler -- line that pulls the clew outboard although sometimes used to describe an inhauler, which we also have.
By the way, this is 10 times easier to adjust than a line that moves the jib car.
1 of 1 Photo(s)
[http://xa.yimg.com/kq/groups/16485695/tn/532939133]<http://groups.yahoo.com/group/Cal_Boats/attachments/folder/506671899/item/532939133/view>
downhaul_twing.png<http://groups.yahoo.com/group/Cal_Boats/attachments/folder/506671899/item/532939133/view>
mike farrell2010-11-13 14:45 UTC
Some sailors object to the term "Barberhauler" for a line ending with a
block thru which a jib sheet passes if it hauls IN on the sheet.
Barberhauler(term) was first used to define a control that hauled th jib sheet
OUT to the rail as on a reach. In hauler is perhaps a better mterm but I first
encountered Barberhaulers on Illiamna Cal 20 #315 on San Francisco Bay in 1972.
They were used to pull the jib lead IN. I call them "Barberhaulers" now. I also
use twings at times on Spinnaker sheets when singlehanding as it gives more
control when needed.
My Best, Mike
Sent: Sat, November 13, 2010 5:46:50 AM
Subject: RE: [Cal_Boats] What is this line called
Allen Edwards
car.
Allen Edwards2010-11-13 15:02 UTC
I just read a site that distinguished between a Barber in hauler and a
Barber out hauler. I have seen inhaulers called both inhaulers or
Barberhaulers, this is the first I have seen a reference to a Barber out
hauler. Since I also use a separate inhauler I was afraid that
Barberhauler might be confusing as to which I was talking about just
because some people, like Mike, call inhaulers Barberhaulers. But as I now
see Barberhaulers are used to control the sail off the wind and that is what
I am doing, so sounds good.
On Sat, Nov 13, 2010 at 5:46 AM, Husar, Charlie [USA] <hu… [at] bah.com
> the spinnaker *sheet *down. The pole height is controlled separately.
> situations.
> Cheers
> Charlie
> Behalf Of *Allen Edwards
> *Sent:* Friday, November 12, 2010 8:34 PM
> *Subject:* [Cal_Boats] What is this line called [1 Attachment]
> jib car.
> Allen
Re: What is this line called
Allen2010-12-05 22:44
This is still an active question on Papoose. I have ruled out Barberhauler because we have an inhauler and that presents some ambiguity as was pointed out, people call inhaulers Barberhaulers now. Some people specifically object to calling a line that pulls down a Barberhauler and I could find no reference that used the term that way.
The two active choices are:
1) Choker is used by Bill Gladstone as in:
"If you carry a high clewed Reacher or Jib Top the exact lead position depends on the wind angle. Set the sheet lead well aft, and rig a choker to pull the sheet down. Adjust the choker so the sail luffs evenly from top to bottom. This arrangement is better than a fixed lead, as it allows easy adjustment as wind angle and wind speed change." I found no other references to this name but this is a pretty good reference so carries a lot of weight.
2) Twing is used in some web posts such as this one:
http://pages.suddenlink.net/arlyn/sailing/extenders.html
Again, if anyone knows someone who has an accepted name for such a control I am all ears.
> Allen
> On Sat, Nov 13, 2010 at 5:46 AM, Husar, Charlie [USA] <husar_charlie@...
> > situations.
> > Cheers
> > Charlie
> > jib car.
> > Allen
