Lightening and bonding
Allen Edwards2010-12-23 05:29 UTC
I am still looking for references from list members for my bonding writeup.
One if the things people talk about bonding for is lightening.
I have a wood mast so lightening would have to go down my stanchions.
I did a rough calculation. The power that would be dissipated would
be 5 billion watts. That would last just long enough to vaporize my
rigging with the energy of up to 10% of a stick of dynamite. I am not
going to worry about bonding for lightening.
I do think I have a handle on the source of bonding confusion. To
prevent electrocution you want to make the voltage difference between
any two pieces of metal you might touch at the same time zero. One
way to insure that this is the case is to bond them all together with
a wire. To prevent electrolysis, you want to make sure that current
cannot travel between any two pieces of metal. You do this by making
the resistance between them high, so you don't want them electrically
connected (no bonding).
You need to ask yourself if you want to protect your boat or your
crew. Perhaps a better question is, is there a way to do both.
Re: [Cal_Boats] Lightening and bonding
Chris2010-12-23 14:43 UTC
> writeup.
I've got more at home, but in my collection of boating articles here at
work, I've got:
--a CG pamphlet; it recommends bonding for lightning protection, to
prevent side flashes.
--a Practical Sailor article from Dec., 1993 that discusses lightning
strikes as RF, not DC, events. It says that side-flashing is caused by
various resistances and reactances; what would be OK for DC is not for
RF. They say bonding "may" help prevent side flashes. They conclude
that "you'll have to keep a watch on electro-chemical corrosion which
can sometimes be speeded up by inter-connecting these systems."
--a PS follow up in the June 1, 1994 issue. It discusses grounding
systems and endorses bonding to perhaps prevent side flashes. They cite
a study showing the boats with lightning protection systems had hull
damage less commonly than unprotected boats (7% vs 19% in salt water;
40% vs 75% in fresh water).
--in April, 2010 a place called Bay Yacht Sales (www.bayacht.com) had
posted three articles on lightning protection, one of which cited the PS
article on RF behavior. I didn't find 'em online today but you could
contact the firm.
--at home, I've got some pamphlets from Florida Sea Grant, which did a
lot of work on lightning protection for boats. Try their web site.
My other boat has a wood mast. It's also got a bronze sail track, and
more importantly, lying directly under that is a thick 1" bronze plate,
running top to bottom, that covers two grooves for wiring. I have
grounded the shrouds, forestay, and the bronze plate. My theory is that
more conductors are better. There is a companionway directly under the
deck-stepped mast, so I do have some turns in the conductors but I tried
to maximize the radius on each. I also used multiple conductors on the
theory that if the lightning disapproved of one, it might like the
other. They all run to a keel bolt on an exterior iron ballast keel.
Re: Lightening and bonding
Allen Edwards2010-12-23 20:07 UTC
I put together a page with several references on lightning. I have not read
all of these yet but will put them out there for comment. I put the material
on my site as so many of the references I found were to dead sites. This
way the material will stay around as long as I do (and I don't care after
that).
http://l-36.com/lightning/lightning.php
