4 messages2010-12-28 04:00 UTCthrough 2010-12-28 12:34 UTC
bonding, 29 cal, backsplash
Helen Horn2010-12-28 04:00 UTC
what year is your 3-2? We dont have one backsplash on our 74 29, let alone any
particle board. our counters run right to the wooden cabinet trimming. then, as
far as glassed in copper, ours has copper wire, solid, the size of a ground wire
in romex, connected to throughhulls, and it runs under interior cabinetry, like
the settee. now I will look real hard for whatever else it's connected to. Helen
,,,Thanks Allen for your effort at giving us real information.
Re: [Cal_Boats] bonding, 29 cal, backsplash
chris1232010-12-28 04:27 UTC
78 Cal 3-29 towards the end of production years. Other things that are
noticeable are the same throttle cable and transmission cable were used as
on the 34 probably as they are way way to long and come down the binnacle
then run to the stern, then run back under the engine and then come forward
over the engine to make them functional. These are originals for sure as Ive
replaced the throttle cable in the winter and moved it off the pedestal as a
temp repair. Other items are the use of pine or cedar "boards" to stabilize
the backslash particle board over the sink and ice box. The rest is pretty
good.
The bonding wire has been covered extensively by glass mat and extrudes only
where needed and attached to a metal component. So they took great effort to
put this system in place in comparison to other issues. Hence its a source
of perplexity that I still have not resolved.
Drawing is here to see the 3-29 mods. Interestingly enough mine does not
have the extending dish rack and garbage rack as indicated in the drawing.
Its the first drawing showing the 2-39 option in the set found here:
https://docs.google.com/viewer?a=v&pid=explorer&chrome=true&srcid=0B5RAU5vfTL5JODIzODEwNjAtODA3ZC00NGFjLTk2YzMtZjY1OTEyN2RkNzAz&hl=en
> any particle board. our counters run right to the wooden cabinet trimming.
> then, as far as glassed in copper, ours has copper wire, solid, the size of
> a ground wire in romex, connected to throughhulls, and it runs under
> interior cabinetry, like the settee. now I will look real hard for whatever
> else it's connected to. Helen ,,,Thanks Allen for your effort at giving us
> real information.
Helen Horn2010-12-28 06:14 UTC
there is the whole lofting of the 29, great! But, it looks just like my 74 29
(basic with tiller) in the galley and settee,etc. the face of my cabinets at the
back of the countertop start right at the counter surface. I also can't see in
the drawings a dishrack or extension, it looks like the stove cavity on the
right and after the bulkhead on the left is the counter for the sink that comes
in the better equipped 2 and 3-29s. where is it indicated that it could go? into
the quarterberth? I will look at these on a different screen tomorrow, maybe
mine's too small. Is the embedded copper under the "furniture" or in the bilge
compartment? HH
Sent: Mon, December 27, 2010 8:27:39 PM
Subject: Re: [Cal_Boats] bonding, 29 cal, backsplash
noticeable are the same throttle cable and transmission cable were used as on
the 34 probably as they are way way to long and come down the binnacle then run
to the stern, then run back under the engine and then come forward over the
engine to make them functional. These are originals for sure as Ive replaced the
throttle cable in the winter and moved it off the pedestal as a temp repair.
Other items are the use of pine or cedar "boards" to stabilize the backslash
particle board over the sink and ice box. The rest is pretty good.
where needed and attached to a metal component. So they took great effort to put
this system in place in comparison to other issues. Hence its a source of
Drawing is here to see the 3-29 mods. Interestingly enough mine does not have
chris1232010-12-28 12:34 UTC
if you view it on line then the first drawing is of the 3-29 option.
