7 messages2011-01-02 17:03 UTCthrough 2011-01-03 02:35 UTC
Re: Cal 29 Drains
Stephen Freeman2011-01-02 17:03 UTC
Hello all: I put two new 1 1/2 drains at the forward end of the
cockpit. The pipes go straight down, but the only place to put a
through hull and a valve was in the lockers on the forward end of the
pilot berths port and starboard. As straight as possible is best for
drainage.
I found that they work great because we took a beam wave in to the
cockpit that filled it to the companionway. But it drain in about a
half a minute.
At first I used flexible hose but found that somehow I got a leak it
one hoses just above the water line so I replaced both with PVC pipe.
Steve
Re: Cal 29 Drains
Alfred Poor2011-01-02 17:42 UTC
Chris inquired:
"However I would like to add an additional port and starboard drain at
the front of the cockpit to increase the flow rate and was wondering
what is the best way to both construct and route these additional
drains."
I vaguely recall Brian Cleverly posting on this very topic (but not for a
Cal 29). As I recall, he built up fiberglass pipes around a form; maybe he
used a cardboard tube wrapped in plastic? Does anyone have an archive on
those posts? I suspect it predated the Yahoo! list by one or two hosts.
.Ah. I found mention of this on his site. Here's the link:
http://www.anzam.com/images/fuji/project/work_begins/welcome.htm
"I made the tubes from 3 alternating layers each of 9oz cloth and 18oz
Biaxial with mat.
Spiral wound on a form, each layer laid in opposite direction to the
preceeding one and have a wall thickness of 1/4". Pix are here
<http://www.anzam.com/images/fuji/project/work_begins/fiberglass_tube_48inch
.jpg> , and here
<http://www.anzam.com/images/fuji/project/work_begins/fiberglass_tube_2_5id.
jpg> .
"These have been fitted with an initial bonding fillet of putty consisting
of epoxy + milled glass + chopped strands + silica. Once that fillet has
cured I will be glassing the tubes to the top of the cockpit sole, the
underside of the cockpit, the inside of the hull, and the outside of the
hull.
These are *not* cross-connected, each one goes straight down. The fwd ones
shown here
<http://www.anzam.com/images/fuji/project/work_begins/forward_cockpit_drains
.jpg> .
"Why not cross-connected ?
"Because when you most need the cockpit to drain quickly, the low side drain
of a cross-
connected system can not drain correctly until the boat is close to
upright...
"You may not be able to wait that long. A straight-thru system starts
draining immediately."
Chris, if you need to make a curved pipe, I'd try using either an inflatable
or foam plastic (such as a swimming tube) insert which should make ultimate
removable possible.
I'm gratified to know that a few gray cells are still functioning.
Alfred Poor
Re: [Cal_Boats] Re: Cal 29 Drains
Allen Edwards2011-01-02 18:47 UTC
My 2 cents is that the PCV will crack and your boat will sink.
My cockpit drains use this stuff
http://www.westmarine.com/webapp/wcs/stores/servlet/ProductDisplay?productId=19371&catalogId=10001&langId=-1&storeId=11151&storeNum=10111&subdeptNum=10640&classNum=10641
<http://www.westmarine.com/webapp/wcs/stores/servlet/ProductDisplay?productId=19371&catalogId=10001&langId=-1&storeId=11151&storeNum=10111&subdeptNum=10640&classNum=10641>I
left it in there a bit over 50 years and then replaced it with more of the
same stuff.
> drainage.
> half a minute.
> Steve
chris1232011-01-02 19:28 UTC
On Sun, Jan 2, 2011 at 12:42 PM, Alfred Poor <ap… [at] verizon.net> wrote:
Comment in line.....
> …Ah… I found mention of this on his site. Here’s the link:
Thanks....excellent reference........furthermore...good thing I asked this
questions. This may sound dumb but I would have thought the strategy would
be to exit the water via the transom and additional drain ports added. I
would not have thought that exiting the water, under the water line, as this
system clearly is, is efficient. Is this the standard on blue water vessels?
Remain clueless....so much to learn...;)
Allen Edwards2011-01-02 19:42 UTC
Another 2 cents. My cockpit drains are at the aft of the cockpit and the
two drains are directly below very much under the water line. In fact, the
top of the drains are under the water line when I sail, a real pain but that
is another story. While the cockpit drains and the through hulls are lined
up almost perfectly, they are not connected that way, they are crossed. The
port cockpit drain exits the starboard through hull. It is set up this way
to avoid sinking the boat when healing enough to put both under the water
line. The idea being that on an extreme heal, when the port cockpit drain
is under the water line, the starboard through hull will be out of the
water. Not everyone does it this way and I am not actually sure how
important it is. Most of the L-36s do it that way but not all.
You might find my project interesting but in any even there are some
pictures posted that make it clear.
http://l-36.com/drain.php
<http://l-36.com/drain.php>Allen
> /ch
DavidOwen2011-01-03 02:28 UTC
Stephan,
I like your additional drain scheme, but am worried that you are using
PVC instead of hose. If your hose was leaking, it was because of a
bad hose-clamp or such. The hull flexes as you sail (or motor) and
the PVC will eventually degrade and split or crack.
You could wrap it with fiberglass and make it more crack-proof, but
then you have a rigid connection into the hull which will make a hard
spot. I would highly recommend that you go back to the hose and just
make sure you use high quality clamps and double them. If you use
really heavy hose and cut the hose a bit long, you will have a bit of
tension to help keep it in place as well.
Wilkie
> drainage.
> half a minute.
> Steve
DavidOwen2011-01-03 02:35 UTC
Alfred,
I saw those "turbo-drains" installed in Brian's boat. They were hell
for stout and well thought out as is Brian's way of doing everything.
They were also located aft very near the transom where there is
minimal, or close to zero, flex in the hull. I think Brian might well
have been reluctant to install them at the front of the cockpit where
there is more hull to flex. That's my feeling, certainly. They use
hose for a reason.
Wilkie
On Jan 2, 2011, at 9:42 AM, Alfred Poor wrote:
> Chris inquired:
> “However I would like to add an additional port and starboard drain at
> drains.”
> for a Cal 29). As I recall, he built up fiberglass pipes around a
> form; maybe he used a cardboard tube wrapped in plastic? Does anyone
> have an archive on those posts? I suspect it predated the Yahoo!
> “I made the tubes from 3 alternating layers each of 9oz cloth and
> 18oz Biaxial with mat.
> preceeding one and have a wall thickness of 1/4". Pix are here, and
> here.
> “These have been fitted with an initial bonding fillet of putty
> consisting of epoxy + milled glass + chopped strands + silica. Once
> that fillet has cured I will be glassing the tubes to the top of the
> cockpit sole, the underside of the cockpit, the inside of the hull,
> and the outside of the hull.
> fwd ones shown here.
> “Why not cross-connected ?
> “Because when you most need the cockpit to drain quickly, the low
> side drain of a cross-
> upright...
> “You may not be able to wait that long. A straight-thru system
> starts draining immediately.”
> Chris, if you need to make a curved pipe, I’d try using either an
> inflatable or foam plastic (such as a swimming tube) insert which
> should make ultimate removable possible.
> I’m gratified to know that a few gray cells are still functioning.
> Alfred Poor
> 1973 Tartan 34C #288 “Jambalaya”
