Re: [Cal_Boats] Cal 39 question #2
Peter -
Your furry bottom can easily shave 2 kts off your boat speed. In addition to the "fur" you likely have barnacles both on your bottom and your prop. When I first started beer can racing I was unaware of how much impact this growth could have until motoring out to a race one day and could barely make 5kts when I could usually do 6.5. After that we had the bottom cleaned weekly.
Paul
DavidOwen <wi… [at] mariposasailing.com> wrote:
>Peter,
>A two bladed prop, of the proper size is more efficient than a 3
>bladed prop of the proper size, so it is all in the details. The
>problem would be if the two bladed prop gave up some thrust area
>because there wasn't room to swing a large enough diameter prop, which
>is of course not unusual on sailboats. The three bladed prop can fit
>more surface area into a smaller diameter, even though the extra blade
>interferes with the efficiency of the other two. I think generally a
>3 blade is nice around the docks and maneuvering under power, but the
>two blade is a better choice for cruising speeds and certainly for
>sailing.
>If you know the diameter and pitch of the prop and can find the
>reduction ratio of the transmission, you will find a number of sources
>online to tell you whether it is the proper size or not. Then you can
>go ahead and diagnose if your transmission is slipping or not.
>I'm not sure that a one knot difference is unreasonable with a 10 knot
>headwind and against an opposing current. It makes a bigger
>difference than we suspect. 2600 rpm sounds high for only 3-4 knots,
>however. What is that engine rated for as max rpm?
>I don't know much about Velvet Drive transmissions, but most of them
>can be damaged by running them low on fluid. Also, a friend just had
>a very expensive repair made to his (A Freeport 36 with 50 HP Beta
>engine and velvet drive) because the shift linkage was replaced and
>improperly adjusted. Not sure that has anything to do with your
>problem, other than that I now know that they are sensitive to such
>things. Best of luck.
>Wilkie
>On Jan 2, 2011, at 8:39 PM, C. Peter Audet wrote:
>> Our Perkins 4-108 with 2 blade prop and Velvet Drive transmission
>> only manages 3.2 knots at 2600 rpm, into a light chop of 1-2 feet,
>> opposing current of less than 1 knot, wind of less than 10 knots on
>> the nose, along with a somewhat "furry" bottom. Turning 180 degrees
>> gave us 4.2 knots. I'm concerned that the transmission is wearing
>> out (1978...), I don't think it is the 2 blade prop, unless Rafael
>> confirms that he had similar performance all along, too. The
>> transmission leaks a bit and I keep topping it up regularly, but if
>> it had run on low fluid for a while could that wear things out
>> prematurely? Seems like a possibility. Any ideas?
>> Thanks,
>> Peter
