Re: [Cal_Boats] Bonding article
I think I've mentioned this before but in the governor's cup several years ago we were in a major lightening storm and 2 boats were struck out of 147 on the water that night. One was less than 1/2 mile from us which several of my crew saw which produced a chorus of OH SHIT!!!
A little later I got a tingle thru the wheel of our boat (a CS 30 at that time). It was painless but scared the crap out of me as I didn't know if a bigger shock was on the way. I happened to have some lightweight neoprene diving gloves on board so I put them on because I didn't have a 2 iron (even God can't hit a 2 iron).
That was a long night of squalls separated by dead calms.
Paul
Allen Edwards <al… [at] PaloAltoPhoto.com> wrote:
>I have been told to stand with your feet together and don't touch anything
>if you think you might be hit by lightning. Like the bird on the HV line or
>the lineman that clips his basket to the HV line, it isn't voltage that
>kills you it is the current and you only get current if there is a voltage
>difference. Assuming that there is a 100,000,000 volt difference between
>your masthead and your keel, you best not touch any two separated parts
>because they will for sure be at different voltages.
>I am still thinking the stainless steel rigging will direct the lightning
>away from the crew and down to the water. Perhaps this is a case against
>synthetic rigging. Although, I am still concerned about those 8 billion
>watts and what they would do to the rigging as SS isn't the conductor that
>coper is. But in any event, it isn't like we would be on a power boat with
>nothing overhead.
>Allen
>On Mon, Jan 3, 2011 at 9:05 AM, Chris <cc… [at] lsnm.org> wrote:
>> On 1/2/2011 1:56 PM, Allen Edwards wrote:
>> Not being hit by lightning is right up there with not being killed in an
>> airplane crash, not being eaten by a shark, and not being killed by
>> terrorists. My strategy on all of these is to not have them happen. If I
>> lived in Florida I would adopt a different strategy for lightning however as
>> I have read that every boat can expect to be hit at least once in its
>> lifetime. That would get me closer to the don't be killed in a bicycle
>> accident and I would actually do something, like wear a helmet and avoid
>> busy roads. The problem with lightning though seems to be that nobody knows
>> what the equivalent of a helmet really is as the article in your link points
>> out.
>> The lightning problem is actually twofold. One aspect is protecting the
>> boat from serious damage. The other is protecting the occupants of the
>> boat. When I added grounding wires to the mast & rigging of my other boat,
>> it was done in hopes that it might protect the boat, but perhaps intended a
>> bit more to keep the voltage off me and my crew, if we were struck.
>> I've been aboard our historic wooden schooner twice during very severe
>> thunderstorms--the kind where the lightning flash and the thunder boom are
>> almost simultaneous. Both were intensely nerve-wracking, but in both cases
>> I had no other option. In that case, you carry on and hope for the best.
>> Chris Campbell
