12 messages2011-01-18 05:45 through 2011-01-19 01:01 UTC
12 volt system "lights"
ryanclark1222011-01-18 05:45
Hi, I'm the proud owner of a cal pt 27 in washington. I have a question about the cabin lights running on a 12v system. Every time i turn my cabin lights on it only lasts for a few minutes then i burn a fuse? To any one that knows or has delt with this problem before, I need the advice.
Re: [Cal_Boats] 12 volt system "lights"
Allen Edwards2011-01-18 06:45 UTC
What size fuse?
Re: 12 volt system "lights"
ryanclark1222011-01-18 19:25
its a 3 amp fuse, not sure if thats the right size thats just what was there
Re: [Cal_Boats] Re: 12 volt system "lights" (Ryan)
Michael D2011-01-18 19:41 UTC
Ryan,
I won't bother with accepted symbols, just words.... Assume you have lights
that are rated for 120 watts. Current is measured in amps.
Watts = Current * Voltage
120 = Current * 12
120/12 = Current
10 = Current
With a 3 amp fuse, the maximum amount of watts you can use without blowing the
fuse would be about 35 watts. How many total watts does your cabin lights
require? I'm guessing someone installed the 3 amp fuse because they couldn't
read/see or that was the only thing available at the time.
--Michael--
Sent: Tue, January 18, 2011 2:25:01 PM
Subject: [Cal_Boats] Re: 12 volt system "lights"
RE: [Cal_Boats] Re: 12 volt system "lights"
Husar, Charlie [USA]2011-01-18 19:51 UTC
Also the question of whether the fuses are slo-blows. It sounds like they are and may be under-amped. Do you have an ammeter indication of current drain when you flip on the switch?
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of ryanclark122
Sent: Tuesday, January 18, 2011 2:25 PM
Yahoo! Groups Links
yar!2011-01-18 20:23
thanks, im learning something new every day! im not sure what watt those lights are. With that formula i can figure it out, thank you for the info and your time.
--- In Ca… [at] yahoogroups.com, Michael D <mddfl@...> wrote:
> Ryan,
> 120 = Current * 12
> 120/12 = Current
> 10 = Current
> --Michael--
> From: ryanclark122 <ryanclark122@...>
yar!2011-01-18 20:33
yeah i think they are it happens slowly, Im leaning towards them being under amped now. Ill try some different fuses and see if that fixes the problem. thanks for the advice
--- In Ca… [at] yahoogroups.com, "Husar, Charlie [USA]" <husar_charlie@...> wrote:
> Cheers
> Charlie
> -----Original Message-----
> Yahoo! Groups Links
Allen Edwards2011-01-18 20:34 UTC
Each bulb is probably an amp. My guess is you should fuse for the wire gauge
which may be much higher. Or you could just put in a 5amp fuse.
d_… [at] yahoo.com2011-01-18 21:44 UTC
Or, as long as your at it you could start putting in led replaacement bulbs.
Sent via DROID on Verizon Wireless
Sent: Tue, Jan 18, 2011 20:34:21 GMT+00:00
Subject: Re: [Cal_Boats] Re: 12 volt system "lights"
Chris2011-01-18 21:58 UTC
> bulbs.
Great idea. That solves two problems--fuse blowing and battery life.
But before doing that, maybe it would be a good idea to remove all but
one bulb from the circuit, using the original fuse. See if it blows.
If not, add another bulb. Still OK? Then it's probably a simple over
load from too much wattage (too much current). If it blows on one bulb
or two, then it's not the bulbs causing the overload, but some sort of
not-quite-short circuit--some high resistance short.
Allen Edwards2011-01-19 00:52 UTC
If you have more than two bulbs then your fuse is too small. Those standard
12 volt bulbs are 1 amp each. The fuse blows at 3 amps so 3 bulbs should
blow it although it might take some time to blow. I don't know your wire
size but my cabin lamp fuse is 15 amps. My wire is #10.
> bulbs.
> But before doing that, maybe it would be a good idea to remove all but one
> bulb from the circuit, using the original fuse. See if it blows. If not,
> add another bulb. Still OK? Then it's probably a simple over load from too
> much wattage (too much current). If it blows on one bulb or two, then it's
> not the bulbs causing the overload, but some sort of not-quite-short
> Chris Campbell
Donald Dutton2011-01-19 01:01 UTC
My cabin lights are on a 15 amp circuit breaker and I have 5 on each circuit
plus one or two small fans as well. Wires are 14 gauge except the fans that are
12 gauge. Rarely are they all on at once, but it has occurred on either circuit
at one time or another without any problem at all.
Should you increase the fuse amperage and still have problems, than you probably
have a worn wire somewhere that is shorting the circuit, but your first course
of action is a larger fuse or circuit breaker.
"Twenty Years from now, you will be more disappointed by the things you didn't
do than by the things you did do. So throw off the bowlines. Sail away from the
safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover."
........Mark Twain
Sent: Tue, January 18, 2011 4:52:26 PM
If you have more than two bulbs then your fuse is too small. Those standard 12
volt bulbs are 1 amp each. The fuse blows at 3 amps so 3 bulbs should blow it
although it might take some time to blow. I don't know your wire size but my
>>replaacement bulbs.
>Chris Campbell
