8 messages2011-01-21 16:13 UTCthrough 2011-01-21 22:12 UTC
hexadecimal issues
Chris2011-01-21 16:13 UTC
Some miscreant, probably Charlie, injected "hexadecimal" calculations
into our civilized discourse the other day.
Lo and behold, I was on the Spaceweather website and came across info on
a "NanoSail-D" space device, some sort of satellite or space explorer or
data gatherer. So there's your sailing content--"sail." In space.
And it transmits a signal that ham operators or anybody with >400 mhz FM
receivers can get. There was an explanation of how to decode the data
and it involved hexadecimal notation, as follows:
Solar sail "NanoSail-D" data transmission
> The values in each field are coded in a 'Little Endian by Pairs'
> fashion, also known as
> Middle Endian. In this coding, each pair of ASCII characters form a
> byte and those bytes are written from MSB to LSB. For example, the
> Ejection Time field in the beacon example of Section 1 is decoded as
> follows:
> Raw in Hex Raw in Dec Computation Value
> C8 A1 01 -> 200 161 1 -> 200*160 + 161*162 +
> 1*164 -> 106952
> Ejection Time in the example packet is 106952 seconds
Sorry; I couldn't resist.
RE: [Cal_Boats] hexadecimal issues (Chris)
Husar, Charlie [USA]2011-01-21 16:17 UTC
Chris, why didn't you say so before.
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Chris
Sent: Friday, January 21, 2011 11:13 AM
Subject: [Cal_Boats] hexadecimal issues
The values in each field are coded in a 'Little Endian by Pairs' fashion, also known as
Middle Endian. In this coding, each pair of ASCII characters form a byte and those bytes are written from MSB to LSB. For example, the Ejection Time field in the beacon example of Section 1 is decoded as follows:
C8 A1 01 -> 200 161 1 -> 200*160 + 161*162 + 1*164 -> 106952
RE: [Cal_Boats] hexadecimal issues (Chris Again)
Husar, Charlie [USA]2011-01-21 16:32 UTC
I freely admit to being a miscreant, but George is miscreant.
On 01/14/2011 03:06 PM, Elwers, George A. wrote:
You're just using the wrong units of measurement.
For instance, my friend says he's 40. Of course, that hexadecimal. In base ten he's 64.
Some miscreant, probably Charlie, injected "hexadecimal" calculations into our civilized discourse the other day.
Lo and behold, I was on the Spaceweather website and came across info on a "NanoSail-D" space device, some sort of satellite or space explorer or data gatherer. So there's your sailing content--"sail." In space. And it transmits a signal that ham operators or anybody with >400 mhz FM receivers can get. There was an explanation of how to decode the data and it involved hexadecimal notation, as follows:
Husar, Charlie [USA]2011-01-21 16:38 UTC
I meant to say that George is "miscreanter".
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Husar, Charlie [USA]
Sent: Friday, January 21, 2011 11:32 AM
Subject: RE: [Cal_Boats] hexadecimal issues (Chris Again)
Elwers, George A.2011-01-21 16:42 UTC
I thought it made me more of a dweeb, but miscreant is ok, too. I guess they're not mutually exclusive.
George
Sent: Fri 1/21/2011 8:32 AM
Re: [Cal_Boats] hexadecimal issues
Allen Edwards2011-01-21 17:09 UTC
Wow, and all along I thought C8 A1 01 was 13271297. You learn something
every day.
> The values in each field are coded in a ‘Little Endian by Pairs’ fashion,
> also known as
> -> 106952
> Chris Campbell
Re: [Cal_Boats] hexadecimal issues (Chris Again)
Chris2011-01-21 17:19 UTC
How is that expressed in hexadecimal terms?
Husar, Charlie [USA]2011-01-21 22:12 UTC
Allen, this is why software engineers walk around with their fingers doing "Hook-em Horns" signs while twisting their hands back and forth. Endians are, at a minimum, confusing.
Sent: Friday, January 21, 2011 12:10 PM
Subject: Re: [Cal_Boats] hexadecimal issues
Wow, and all along I thought C8 A1 01 was 13271297. You learn something every day.
On Fri, Jan 21, 2011 at 8:13 AM, Chris <cc… [at] lsnm.org<mailto:cc… [at] lsnm.org>> wrote:
