2 messages2011-01-28 23:41 UTCthrough 2011-01-29 03:34 UTC
mastplate with tabernacle revisited
Adam Thorp2011-01-28 23:41 UTC
Hi all,
I am planning on running my lines to the cockpit, but am having difficulty
deciding on my next move.
I bought two plates from garhauer. The pictures attached show a size
comparison of the two plates next to the tabernacle.
Option 1 is to bolt the smaller plate with six holes to the side of the
tabernacle, as in picture SI851334-800. This is the easier route as I
already have the hardware and don't have to remove the mast or lift the
tabernacle joint off the deck. Concern with this option is the four mounting
bolts shearing off in extreme conditions.
Option 2 is to return the hardward and find a mast plate that suits the
tabernacle better. It will be a bit more work but probably a cleaner
solution in the end. The area just aft of the mast is cluttered and the
rearward tabs on the deckplate probably won't fit.
I would like to go with option 1 if stress isn't a concern... but I can't
find that stress without knowing the load induced by the haylards. What
kinds of load are we dealing with?
Notes...... The bolts holding the tabernacle down are not stainless.. and
are rusting, so I would get to replace those if I go with option 2 . And
also the boat is a cal28.
Thanks all!
Adam
Re: [Cal_Boats] mastplate with tabernacle revisited [3 Attachments]
Allen Edwards2011-01-29 03:34 UTC
Return the plates and send Garhauer a drawing of exactly what you want and
they will make it for you. They made me some custom 1 1/4 jib track with
all custom hole spacing, a threaded hole, all for $20 a foot. They made me
a custom stainless mounting plate for a standup block for $20. In both
cases I just sent them a drawing and I got back exactly what I wanted.
On Fri, Jan 28, 2011 at 3:41 PM, Adam Thorp <th… [at] gmail.com> wrote:
> [Attachment(s) <#12dcf02231ff7229_TopText> from Adam Thorp included
> below]
> Hi all,
> Thanks all!
> Adam
