13 messages2011-02-01 21:10 UTCthrough 2011-02-02 01:59 UTC
tech stuff
chris1232011-02-01 21:10 UTC
Greets:
Looking at implementing a low power ships computer that is permanently
fixed to the boat. There are lots of low powered units now available
running typcially between 3-8watts. So my existing battery banks can
handle the load. The only thing I have not figured out is how to
replace my wired gps bus, the currently feeds, the laptop, VHF and
Raymarine control head. The netbook has been sorted and I can feed
data into it via wifi, so I am free of the cables. Both the controll
head (RM) and VHF (Uniden) take GPS and AIS inputs but want them
wired. Any ideas how I can get there from the black box Im working on.
eg: http://www.linuxuser.co.uk/reviews/sheevaplug-esata-plug-computer-review/
Re: [Cal_Boats] tech stuff
Allen Edwards2011-02-01 21:36 UTC
What are you thinking of for a display? I assume it will be daylight
viewable. Maybe I am missing something. Are you going to have a netbook
for the readout? I am afraid I am confused. I think I need another beer.
On Tue, Feb 1, 2011 at 1:10 PM, chris123 <ch… [at] gmail.com>wrote:
> Greets:
> eg:
> /ch
chris1232011-02-01 21:48 UTC
There are several low power units coming onto the market all running about
3- 8watts. The display will be via vlc so its can be anything, alternatively
wifi, again it can be anything..not the issue.
The slickest unit is this one: http://www.fit-pc.com/trimslice/
The current gps bus is all hard wired. Simple data cable set from garmin
that feeds a terminal trip. NMEA out and NMEA in. This can be duplicated for
AIS. Now the tricky part is both the VHF and Raymariine Controller accept
data inputs (IN and OUT) but via wire. I'd like to get rid of the wire.
Clueless on how to do that.
Garmin cable set: https://buy.garmin.com/shop/shop.do?pID=519
Allen Edwards2011-02-01 22:05 UTC
Money no object?
http://www.amazon.com/Gefen-EXT-WRS232-Wireless-RS232-Extender/dp/B002QPWE56/ref=sr_1_1?ie=UTF8&s=electronics&qid=1296597827&sr=1-1
<http://www.amazon.com/Gefen-EXT-WRS232-Wireless-RS232-Extender/dp/B002QPWE56/ref=sr_1_1?ie=UTF8&s=electronics&qid=1296597827&sr=1-1>I
can't find a reasonable solution. I would go with wire. More reliable,
cheap, low power.
If you don't know about this place, you should:
http://www.monoprice.com/home/index.asp
<http://www.monoprice.com/home/index.asp>Allen
> /ch
chris1232011-02-01 22:22 UTC
wireless serial ports...too nuvea..for me..>:) The other reference is good.
What I'm working on is having a basic ship computer that is extremely low
power and records ships data and rebroadcasts its as needed. Simple data
controller done in hardware. but of course no one wants to play nice.
wires that gauge tend to corrode really fast. The new low voltage units are
basically SOC's.
Allen Edwards2011-02-01 22:44 UTC
You think the wires will corrode faster than the electronics will fail?
Not in my world.
> good.
> basically SOC's.
> /ch
chris1232011-02-01 22:50 UTC
just justifying the fun.....at 99 bucks a unit, they are redundant. The fun
is in building this stuff, you know....:)
mike2011-02-01 23:10 UTC
Chris,
How about tying in all your NMEA data with a Noland NM42U Multiplexer
<http://www.navstore.com/detail.aspx?ID=1259> (NMEA in and USB out) run
a USB cable to one of those itty bitty Linux servers
<http://www.excito.com/bubba/products/overview.html> set up to broadcast
WIFI?
Of course the devil is in the details, but do you think this would work?
MIke M.
Cal-40
/Celtic Naut
> The fun is in building this stuff, you know....:)
> /ch
Allen Edwards2011-02-01 23:10 UTC
But if you use wire you won't have to have all that fun. Paraphrase of a
line from American Graffiti, my favorite movie.
Just remember this: All fun projects take a boat week. There are 12 boat
weeks per year.
> /ch
chris1232011-02-02 00:22 UTC
solid as your heartbeat if you do it on Linux. most of these units run
Linux....thanks...the multiplexer is the ticket. I dont know anything about
marine electronics other then its a captive market that I dislike
sooooooooo...:)
there are lots of models available. I only found out about this around noon,
the head is spinning with idea what can be done here.
http://www.thinq.co.uk/2011/2/1/new-it-announces-dreamplug-arm-box/
What you want is a unit where the OS is open source. Not all are, then
connect with the usb over serial port, and the fun begins. You cannot brick
these devices, but make a backup of the OS before you start to something off
unit. At least then you can start over.
Best of luck...if you need some help just ping me.
chris1232011-02-02 00:36 UTC
Just for fun. Apple is going to release the next gen of IPADs in a few
months/weeks meaning the current wifi models will be around 200 bucks on
ebay. Configure your plug computer to run as wifi station ie: to broadcast.
IPADS connect to remote devices via wifi....you navigator will love you.
Its going to get even better as you bring more data comes on line. What
would be nice for my needs is engine data and dump it to a log file every
time the engine is started. Alarm the temp and oil pressure and you got a
pretty good setup. The thing is these things are so cheap you can carry four
spares for the price of an A-4 water pump that died and toasted my engine.
Had it been alarmed by any means would have saved the cost of repowering
which I wanted to do but not in year 1 of ownership.
Best of luck
./ch
On Tue, Feb 1, 2011 at 6:10 PM, mike <mi… [at] wahini.org> wrote:
> Chris,
> How about tying in all your NMEA data with a Noland NM42U Multiplexer<http://www.navstore.com/detail.aspx?ID=1259>(NMEA in and USB out) run a USB cable to one of those itty
> bitty Linux servers <http://www.excito.com/bubba/products/overview.html>set up to broadcast WIFI?
> MIke M.
> Cal-40
> *Celtic Naut
> /ch
chris1232011-02-02 00:48 UTC
Now if you really want to do an integration exercise, hook it up to spots
newest of devices...:)
http://www.findmespot.ca/en/spotnews/index.php?option=com_content&view=article&id=345:new-year-new-spot-product-spot-connect&catid=21:spot-updates&Itemid=1
Keep an eye on your boat while your gone as well.
Man you really could have fun with this stuff...I smell an IPO coming soon
from somewhere based on a user paid service fee..:) At least thats how it
used to be....alas Im too old to play this game again.
How many more weeks till we can go sailing and get back to basics..???
Allen Edwards2011-02-02 01:59 UTC
I hope everyone knows about this app for Android and iPhones. It turns your
phone into a chart plotter with GPS location for $10 or $E10
http://www.navionics.com/NavionicsMobile.asp
<http://www.navionics.com/NavionicsMobile.asp>I have it on my Nexus 1 and
had one on my old iPhone. Works great and does not need network
connectivity to work. The version I have covers the entire US west coast.
There are versions for other regions.
> /ch
