Re: [Cal_Boats] Re: peeewwww smell
My Cal 39 has a sump as well but it is only about 12" deeper than the
bilge. I was talking to my yard owner about it and he said some people have
installed a drain plug in the bottom of them that is removed with a large
screw driver and is somewhat flush with the keel. Obviously this only helps
if you haul out every so often but it makes it easy to flush out your bilge.
By the wya, my sump "water" smelled like the toe jam of a sumo wrestler who
had not showered a month after walking thru a hog pen barefoot on a rainy
day in August.
Paul West
Adventure Kwest
'80 Cal 39
In a message dated 3/7/2011 12:07:55 P.M. Eastern Standard Time,
cr… [at] hotmail.com writes:
the keel sump on cal-29 #498 would slowly accumulate water , probably from
hatch leaks. It smelled so bad we thought it was the head at first. The
smell was very sulfur like. Most likely anaerobic conditions deep in the keel
fostered growth of organisms that produce hydrogen sulfide. Pumping it
out and a splash of bleach solved the problem.
drew new haven ct
Date: Sun, 6 Mar 2011 15:29:15 +0000
Subject: [Cal_Boats] Re: peeewwww smell
Thanks for all the great ideas.
I forgot to mention that I have completely ripped out the holding tank and
replaced all water hoses. Also, everything I can get to has been washed
down with ammonia + more.
I'll have to check that aft keel. As far as I recall, it's right under the
batteries? How does one get access as I remember the hole being tiny.
Good idea on the ozone generator. I am in Vermont but will look around up
here.
Barrie
