12 messages2011-02-28 20:47 through 2011-03-08 23:43
Manufacturer of opening portlights on '78 Cal 34?
reveraterraa2011-02-28 20:47
Does anyone know the original manufacturer of the forward portlights on a 1978 Cal 34 Mk III? I'm looking to replace the gasket, and maybe a few other parts. Thanks.
Re: [Cal_Boats] Manufacturer of opening portlights on '78 Cal 34?
Helen Horn2011-02-28 21:24 UTC
you might take some vaseoline and Q tip ... it brought our old gaskets back
(1968 & 1974) edward
Sent: Mon, February 28, 2011 12:47:50 PM
Subject: [Cal_Boats] Manufacturer of opening portlights on '78 Cal 34?
Thanks.
Re: Manufacturer of opening portlights on '78 Cal 34?
reveraterraa2011-02-28 21:56
I've tried that. All the summertime mold and wintertime ice has warped the gaskets beyond repair.
> From: reveraterraa <kbablinskas@...>
> Thanks.
Allen Edwards2011-03-01 02:00 UTC
I used silkaflex. Worked like a charm. Can't open it though...
> back (1968 & 1974) edward
> *From:* reveraterraa <kb… [at] gmail.com>
> *Sent:* Mon, February 28, 2011 12:47:50 PM
> *Subject:* [Cal_Boats] Manufacturer of opening portlights on '78 Cal 34?
> parts. Thanks.
Wayne Gillikin2011-03-07 19:29 UTC
Is the gasket material a round (cord stock) shape and looks to be made of
neoprene?
Sent: Mon, February 28, 2011 3:47:50 PM
Thanks.
Helen Horn2011-03-07 19:40 UTC
try VALSOLINE they will "come back" edward 1974 cal ...they are dried out
Sent: Mon, March 7, 2011 11:29:06 AM
Subject: Re: [Cal_Boats] Manufacturer of opening portlights on '78 Cal 34?
neoprene?
Thanks.
reveraterraa2011-03-07 22:23
It's actually a rubbery material with an L-shaped cross section.
> neoprene?
> Thanks.
reveraterraa2011-03-07 22:29
The gaskets have a one-inch gap in them because the previous owner cut them too short. Vaseline may be a temporary solution, but I'd like to get new ones to fill that gap.
> From: Wayne Gillikin <waynegillikin@...>
> neoprene?
> Thanks.
Re: [Cal_Boats] Re: Manufacturer of opening portlights on '78 Cal 34?
Helen Horn2011-03-08 00:14 UTC
You can get a profile probably from the view of the end cut, depending upon
where you go for parts, I found a catalog for such rubber moldings which we were
seeking for our 29, at the KKMI chandlery a year or so ago in their binders of
brochures. maybe WM has the catalogs also, and Svendsen's in Alameda? Are your
opening ports metal as in the 29s? Our 36 has white plastic Grey Marine
ports.(have to replace completely as they crumble after time).
(we tried the vaseline on the metal type with the rubber and it softened them up
so well they seal just fine but they were the original and properly cut.) HH
Sent: Mon, March 7, 2011 2:29:09 PM
Subject: [Cal_Boats] Re: Manufacturer of opening portlights on '78 Cal 34?
fill that gap.
> neoprene?
> Thanks.
reveraterraa2011-03-08 23:35
I bet I have the same ports as the Cal 36. There is one in our harbor and I took a peak at it the other day and noticed the same crumbling similarities. In that case, I may just seal the troublesome ports shut and try out the vaseline on the other ones. I plan to replace them next year anyway.
Thanks for the help and happy sailing.
> fill that gap.
> > From: Wayne Gillikin <waynegillikin@>
> > neoprene?
> > From: reveraterraa <kbablinskas@>
> > Thanks.
RE: [Cal_Boats] Re: Manufacturer of opening portlights on '78 Cal 34?
r good2011-03-08 23:39 UTC
perko aluminum?
Date: Tue, 8 Mar 2011 23:35:33 +0000
> fill that gap.
> > neoprene?
> > Thanks.
reveraterraa2011-03-08 23:43
Naw, they are plastic of some kind. I break off pieces every time I throw the dinghy in the water...
--- In Ca… [at] yahoogroups.com, r good <my1972ih@...> wrote:
> perko aluminum?
> From: kbablinskas@...
> > fill that gap.
> > > neoprene?
> > > Thanks.
