27 messages2011-03-04 14:21 through 2011-03-17 19:10 UTC
peeewwww smell
Compass2011-03-04 14:21
Last season I got myself a Cal 29 in very very good condition. It had been well cared for.
One problem that raised it's ugly head though was a really bad smell.
The cushions were "soaked in it" and it seemed to have permeated everything. I am not sure I could even identify what it was... head? Cigars? Mold?
I have tried the following
-Washed everything down with aggressive cleaner
-Taken out seat cushions
-Dumped gallon or so of bilge cleaner down bilge
-Ripped off the 70's carpet off the cabin walls and repainted
-Pulled out old bladder-type head storage tank and head old head lines
The boat has been on cradle for a few months during the winter (with cover, but windows open. I went up to check on it and the smell is STILL there.
Anyone got any thoughts on (a)what could be the source (b)how I can get rid of it?
My wife is reluctant to sleep on board its so bad.
Re: [Cal_Boats] peeewwww smell
Chris Campbell2011-03-04 15:10 UTC
> Cigars? Mold?
One solution for odors is an ozone generator. Fire restoration
companies have big commercial-sized units. Once I left a pot of soup on
high, then turned it down and went to a movie. Turns out I turned the
wrong electric burner down. Moisture boiled out; temp rose; pan melted
through; ingredients were charring. I got home to find a thick haze of
steam and smoke. No damage, but wow, did the house stink. The
insurance co. paid for the ozone machine for a couple days and the house
went from unlivable to no smell at all in a couple days. Ozone will
also kill off mold and mildew.
You could buy, at least for a while, little ozone generators for your
car that plugged into the cigarette lighter. I've got one at home for
120 VAC that came with a pile of junk from an auction.
You can kill odors by leaving pans of household ammonia out. You don't
get the strong ammonia smell, but it somehow absorbs or neutralizes odors.
The other comments about looking for elusive dead critters might be
helpful too.
Allen Edwards2011-03-04 16:39 UTC
My suggestion is to do as you have already done in removing everything that
can absorb water and then: Take everything out of the boat. Wash it down
inside with a solution of 4 oz bleach to 1 qt water. Wear a good gas mask.
Let it sit a few minutes. Wipe that down and hose if off. Don't put
anything back on the boat that smells and wash everything you do put back
on. This process will also make your boat faster as you will find you have
a lot of stuff you don't need to put back on.
I don't personally like using cleaners with detergent in them as stuff can
grow on any detergent residue. Make sure your engine compartment is
isolated from the living area. Once that is done, I have found the secret
is to get some air circulation. I tried a number of things on Papoose to
get the humidity down and settled on a low wattage StoDry. I wrote it all
up in an article on my web site but it is kind of rambling as I made so many
false starts before settling on a simple solution. You might find it useful,
not sure. I now keep all the hatches open an inch when gone and it has made
a huge difference. Perhaps more vents would help and perhaps your boat has
more than mine. If you open a hatch and find everything is wet, you need
more ventilation.
> well cared for.
> Mold?
> of it?
Helen Horn2011-03-04 17:48 UTC
cris is correct ozone gen..is the way to go... big blue 1st vacuum boat
complete
then install big blue ozone open all draws turn cushions on edge open all
compartment lids.. remove all head hose ....put fan at one end of big blue
close boat for 24 hrs let machine RUN,,with fan circulating air through "BIG
BLUE"
unplug machines let set for 2 hrs...then re vacuum entire boat bilges counters
ice box...high and low....Big blue adds "EXTRA oxygen molecules" to air based
smell
making them "heavier" causeing to sink to bilges..when you vacuum the smell is
GONE !! there web site www.blueairproducts.com...I have one 10" 5 bulb and
one 8" 3 bulb I treat cars and boats $250 ...I will buy you machine when
your done
or can treat your boat if your close by we are in nor cal ...thses machines are
also
use it pot grow rooms so that SKUNK smell is gone !! edward "SCENT FREE"
Oh yeah check for fuel leaks or pin holes in top of fuel tank..this can get
some wierd
smells it also get rid of mold they also have 12 volt "BALL" units that I
haven't
tried ....Good luck a great smelling boat makes a happy wife..and a sailor very
happy!!
Sent: Fri, March 4, 2011 7:10:28 AM
Subject: Re: [Cal_Boats] peeewwww smell
>smell.
>head? Cigars? Mold?
One solution for odors is an ozone generator. Fire restoration companies
have big commercial-sized units. Once I left a pot of soup on high, then
turned it down and went to a movie. Turns out I turned the wrong electric
burner down. Moisture boiled out; temp rose; pan melted through;
ingredients were charring. I got home to find a thick haze of steam and
smoke. No damage, but wow, did the house stink. The insurance co. paid for
the ozone machine for a couple days and the house went from unlivable to no
smell at all in a couple days. Ozone will also kill off mold and mildew.
You could buy, at least for a while, little ozone generators for your car
that plugged into the cigarette lighter. I've got one at home for 120 VAC
You can kill odors by leaving pans of household ammonia out. You don't get
The other comments about looking for elusive dead critters might be helpful
too.
Bob Virgalla2011-03-04 18:16 UTC
as a fellow owner of a CAL29...have you checked out the bilge aft of the keel?
Accessible just forward of the engine under the companionway stairs. I had a
similar "issue" and found this area full of foul smelling water and assorted
"items" from the engine bay. Did a pump out and clean- helped a lot.
Bob Virgalla
Cell: 203.733.5006
~~~_/)~~~
Sent: Fri, March 4, 2011 9:21:07 AM
Subject: [Cal_Boats] peeewwww smell
cared for.
it?
Yahoo! Groups Links
Randy Alcorn2011-03-04 20:22 UTC
I have to agree, I had my boat for years and never knew about the sump in the
keel. I dropped a tool one day and it fell in there. I had to add bleach to
neutralize the smell. I went to pump it out and I couldn't believe how deep it
was. I found old tools, rotted wood, wire and muck at the bottom.
Sent: Fri, March 4, 2011 10:16:37 AM
Bob Virgalla
Cell: 203.733.5006
~~~_/)~~~
cared for.
it?
Yahoo! Groups Links
mike farrell2011-03-04 23:10 UTC
Does your Cal 29 have a holding tank?
Sent: Fri, March 4, 2011 6:21:07 AM
cared for.
it?
Yahoo! Groups Links
Re: [Cal_Boats] peeewwww smell (Bob)
Gerald Sobel2011-03-05 07:54 UTC
Bob,
I have a Cal 24 and was thinking along the same thing, of looking for a hidden area that hadn't been addressed yet. In my boat there is such an area under the deck just aft the floor supporting the head, forward of the lead ballast, which served in my boat as a salt water locker. (???) When I removed my 'Catalina Illegal' head and the floor that supported it, I discovered it, filled with murky brown water. Since it didn't have a foul smell, I dipped my finger in and bravely tasted the liquid, finding it very, very salty. There was a crack in the hull from hitting an obstruction in the past, and the leak was so slow the water was evaporating as quickly as it was leaking. In fact, when I pumped it out with a tube and piston pump, I found many giant salt crystals, which I later sold on Ebay to a geologist for more than the boat cost me! (ok, I made up that story, but just the Ebay part)
Cleaning the little black spots, and areas that look soot covered, that arise from the resident below deck boat mold twice, or, at the very least,like I tend to do,once a year, is a necessary task for all boat owners. There is no way to avoid the nightly condensation below the decks which forms an ideal medium for these critters to grow (which actually more closely related to humans/animals than plants, evolution-wise).
I tried skipping this duty for a year and found my eyes and lungs burning from the irritation (irritating spores, digestive gases) these bugs create while trying to sleep below decks during a weekend long layover race, not very fun. Removing everything from the boat, then scrubbing down all the surfaces with a large sponge and two shallow pails, one with dilute bleach, and one to use to wrinse and wring out the dirty water, does the trick. It helps to have your regular crew assisting with this task. The more thorough the job, the longer the boat stays fresh and pleasant. And, of course, it helps to scrub down everything that's you've taken out of the boat to get at the surfaces, life jackets, cushions, etc.
I use a drying heater and a small ozone making ion generator to help slow the growth between cleanings to slow down the mold growth.
Date: Friday, March 4, 2011, 10:16 AM
as a fellow owner of a CAL29...have you checked out the bilge aft of the keel? Accessible just forward of the engine under the companionway stairs. I had a similar "issue" and found this area full of foul smelling water and assorted "items" from the engine bay. Did a pump out and clean- helped a lot.
Bob Virgalla
Cell: 203.733.5006
~~~_/)~~~
head old head lines
Yahoo! Groups Links
Allen Edwards2011-03-05 16:24 UTC
This is all good stuff and I completely agree with it but I want to
emphasize the importance of ventilation. As has been mentioned, the goal is
to get moisture out of the boat. More accurately, the goal is to keep
moisture from building up inside the boat. It turns out that a closed box
will suck in moisture when the vapor pressure is higher outside and hold it
in when it is not until you have 100% humidity inside. Heating the box
(cabin) just increases the amount of water that the box can hold so you
actually get more moisture. The best you can do unless you get a
dehumidifier is to keep the humidity inside the boat the same as the
humidity outside. That is done by circulating the air and having good
ventilation. That is the goal of these small mushroom shaped 90 watt
heaters with fans. The 90watt heater isn't designed to heat the space but
to set up convection currents that, along with the fan, move the air around.
Good vents so that the air can move freely inside and out of the boat helps
a lot. I started leaving my hatch covers open an inch and now everything
stays dry below. Last year, when I opened one of the hatch covers,
everything would be completely saturated dripping wet.
While it seems obvious that you want to keep the boat closed up and run a
heater, it is exactly the wrong thing to do. You can't do better than
having the air inside the boat have the same moisture as the air outside and
typically that will be a huge improvement. I base this on experiments and
measurements I did over the course of several weeks. It is all on the web
page if you are interested. Lots of information on humidity and how to
measure it there although I think that was largely a false path.
On Fri, Mar 4, 2011 at 11:54 PM, Gerald Sobel <so… [at] yahoo.com> wrote:
> Bob,
> Ebay part)
> Jerry
> --- On *Fri, 3/4/11, Bob Virgalla <vi… [at] yahoo.com>* wrote:
> From: Bob Virgalla <vi… [at] yahoo.com>
> lot.
> Bob Virgalla
> Cell: 203.733.5006
> ~~~_/)~~~
> *From:* Compass <co… [at] compassdesigns.net>
> *Sent:* Fri, March 4, 2011 9:21:07 AM
> *Subject:* [Cal_Boats] peeewwww smell
> well cared for.
> Mold?
> of it?
> Yahoo! Groups Links
RE: [Cal_Boats] peeewwww smell (contact)
john raxter2011-03-05 23:18 UTC
Here is a few thoughts nobody has mentioned.
When we first got our boat, we accidently filled the water tanks with well
water. The marina had two hose bibs at each slip, and we were not aware of
the difference. The idea was to use the well water for washing the boats,
and the city water for drinking, tanks etc. after the boat sat a month the
water was rank! Just turning on the spigots made you want to gag! It took
about three chlorine shock treatments to get the smell out of the tanks.
We also rarely used the head to its full potential. Even after replacing
the hoses we were still getting the "odor". One dark night at anchor, I
thought it was cool watching the effervescence of the raw water flush swirl
around the toilet. It soon dawned on me. There is probably more organics
that hit the holding tank (and lines) from the flush water than we put in
there. We keep the raw water turned off, and use gallon jugs with city
water (treated) as flush water.
We also combat the humidity using the "damp rid" refilible canisters. We
originally bought from West Marine, but home depot carries the same thing,
only much cheaper.
All these seem to keep the head odor at a minimum. I also second the
thought about replacing the foam in your interior cushion, unless they are
the closed cell foam, they will collect any odor in the cabin.
Tymll
john
Re: peeewwww smell
Compass2011-03-06 15:29
Thanks for all the great ideas.
I forgot to mention that I have completely ripped out the holding tank and replaced all water hoses. Also, everything I can get to has been washed down with ammonia + more.
I'll have to check that aft keel. As far as I recall, it's right under the batteries? How does one get access as I remember the hole being tiny.
Good idea on the ozone generator. I am in Vermont but will look around up here.
Barrie
Barrie North2011-03-06 15:31 UTC
Hi Allen
Yes, ventilation is huge. I install a night and day solar vent (nicro?) and
its great. Keeps air moving 24 hours a day!
Barrie
On Sat, Mar 5, 2011 at 11:24 AM, Allen Edwards <
> Allen
> On Fri, Mar 4, 2011 at 11:54 PM, Gerald Sobel <so… [at] yahoo.com>wrote:
>> Bob,
>> Ebay part)
>> Jerry
>> lot.
>> Bob Virgalla
>> Cell: 203.733.5006
>> ~~~_/)~~~
>> well cared for.
>> Mold?
>> there.
>> rid of it?
>> Yahoo! Groups Links
Re: [Cal_Boats] Re: peeewwww smell
Helen Horn2011-03-06 17:29 UTC
barrie ...the slump is in under neath your step / seat just forward of engine /
battery but behind the salon liner inside the trailing edge of keel appox 3
or 4 ft DEEP
on our Cal 29 "NOAH'S KID" helen had to put in a "WATER PUPPY" diafram type
pump mounted to engine area bulkhead and 5 ft hose with stainer as well as
filter
before the pump with a 3 way switch auto / off / manuel (ON) (the rule could NOT
pump overboard?) if your boat is on the hard and this sump full of rain
water in could be problems or mabe leave a piece of rope then let in freeze
and pull out ice cube !! We put float switch in bilge area in main salon
under neath table area ... our Cal 36 has huge "sump area' an the PO bolted
float switch and rule 500 pump to a plexy glass 2" X 7" with prop zinks (2)
which MAKES SERVICE & inspection easy ...if you have a shop vac..handy you can
suck out the slump with couple of extensions ...edward
ps I talk to 'blueairproducts.com " CEO scott has a boat and uses AIR BALLs
which have 12 volt capeableity ....so a solar charger a air ball an fan ..i
dehumityfier
smell will be gone...$$$$
Sent: Sun, March 6, 2011 7:29:15 AM
Subject: [Cal_Boats] Re: peeewwww smell
Barrie
Helen Horn2011-03-07 00:13 UTC
do you have a diesel engine and tank? sometimes that can permeate the boat,
especially if the fuel has started growing bugs, it can be nauseating. Another
thing, though most of the responders suggest bleach no soap in the cleaning mix,
I learned from a bug-expert that to effectively kill mildew, bleach does make it
look all white and gone, but it has a natural waxy coating that unless you have
some soap in that mix, doesn't totally remove it. House painters put a portion
of soap into their wash with water and bleach to get the job done for prep. And,
no matter what they say, those hoses for heads and fuels eventually do get
smelly and should be changed over time. I once found when helping clean a ranger
29 for a sale that the PO had used socks to stuff vents in cold weather. The
#@&%^idiot apparently wore them first, we had to ozone the boat. a washing with
baking soda solution is a safe cleaner, so is vinegar(not together). You can
take all fabrics and use a baking soda/soap washing machine load, then in the
rinse cycle try adding a vinegar/water to the rinse cycle to remove residues.
Keep a fan running fresh air through the boat while you work. Helen
cared for.
it?
Chris Campbell2011-03-07 02:35 UTC
> cushions, etc.
Hydrogen peroxide is also a mold-killer and may be less smelly and
annoying to use. You can also use vinegar. I used it successfully on
my other boat, which has a rough overhead (unfinished roving that the
previous owner painted with a trowel or something long ago). I hate
using bleach because I'm lying on my back to do this, and all thge
clothing and anything else within drip range gets bleached. Vinegar
cleaned it up well and inhibited regrowth.
I've found the ads for small ozone generators that i had saved, and will
bring them in tomorrow.
RE: [Cal_Boats] Re: peeewwww smell
Drew Ratchelous2011-03-07 17:07 UTC
the keel sump on cal-29 #498 would slowly accumulate water , probably from hatch leaks. It smelled so bad we thought it was the head at first. The smell was very sulfur like. Most likely anaerobic conditions deep in the keel fostered growth of organisms that produce hydrogen sulfide. Pumping it out and a splash of bleach solved the problem.
drew new haven ct
Date: Sun, 6 Mar 2011 15:29:15 +0000
Barrie
Barrie North2011-03-13 03:50 UTC
Hey all
How the heck have you managed to pump out that second sump just for'ed the
engine. The opening is tiny! Do I have to remove something to get at it?
Barrie
Helen Horn2011-03-14 02:51 UTC
If this is a cal 29, the sump is pretty deep. I put in a separate water pump
(water puppy) mounted on the port side which goes back to an exit at the stern.
Barrie North2011-03-16 14:51 UTC
Thanks Helen
How big is the actual opening just under the batteries in your boat?
Barrie
> pump (water puppy) mounted on the port side which goes back to an exit at
> the stern. From the pump to the bottom of the keel is about 6 inches of
> tubing, hose-clamped to a screw top water filter with a screen, the top is
> clear so I can see debris(not allowed in bilge)hose-clamped to the rest of
> the tubing going down to a brass or bronze strainer fitting that almost
> holds itself down. You can use a bright light to see where you actually
> locate it(don't cut the tubing short until you actually pump it out). You
> can still leave your float switch in the higher sump, but put in a three way
> "auto, off, manual to get the last drop. If you can find a way to stiffen
> the tubing, you can probably skip the strainer, or find some other type of
> strainer tip. I would put some bilge cleaner in there first and let it soak,
> then use a wet/dry shop vac and stick tubing down there till it hits bottom,
> using an adapter to accommodate the smaller tubing or ducttape to shrink
> down to the tube size, and clean it out thoroughly before I hooked up the
> new system so you don't plug up with garbage or smelly stuff. . You need to
> be sure your pump can "lift" the 3+ feet of water. Helen
Mark Alan Stahnke (MAS Consulting)2011-03-16 15:34 UTC
Same issue here Cal 2-29 bilge is deep over 4" and hard to get to under 2 batteries. I drilled a 2" hole between them so I could shine a light and drop a vac hose along with by accident, a craftsman 3/8" socket wrench which was recovered along with a bunch of other rusted metal by magnet.
What I do with that rancid bilge water is vac it (wet/dry) out into one gallon milk containers and take it to a chem depository. Or If its not a fuel or oil spill, take it home and down the cleanout.
Then I put a gallon of white vinegar into the bilge from the engine area so it cleans that area as well. Then if its a really bad grime I flood the bilge up to the top let it set over night. Sample the water for sheen and contamination if its clean pump it out if not I will vac it into containers again and repeat the process. When I am satisfied with the results I will add either simple green or Orange-sol to get rid of the vinegar smell. If you don't have oil or fuel leaks this should last a long time. If your problem is simply rain water stagnation flood bilge with salt water and a little bleech pump out.
I have used this process for bilge full of diesel spill and discovered that the bio/cleaners do not work as well as 1.99 per gallon vinegar.
Mark
Sent: Wednesday, March 16, 2011 7:51 AM
Subject: Re: [Cal_Boats] Re: peeewwww smell
Thanks Helen
Barrie
On Sun, Mar 13, 2011 at 10:51 PM, Helen Horn <he… [at] sbcglobal.net> wrote:
If this is a cal 29, the sump is pretty deep. I put in a separate water pump (water puppy) mounted on the port side which goes back to an exit at the stern. From the pump to the bottom of the keel is about 6 inches of tubing, hose-clamped to a screw top water filter with a screen, the top is clear so I can see debris(not allowed in bilge)hose-clamped to the rest of the tubing going down to a brass or bronze strainer fitting that almost holds itself down. You can use a bright light to see where you actually locate it(don't cut the tubing short until you actually pump it out). You can still leave your float switch in the higher sump, but put in a three way "auto, off, manual to get the last drop. If you can find a way to stiffen the tubing, you can probably skip the strainer, or find some other type of strainer tip. I would put some bilge cleaner in there first and let it soak, then use a wet/dry shop vac and stick tubing down there till it hits bottom, using an adapter to accommodate the smaller tubing or ducttape to shrink down to the tube size, and clean it out thoroughly before I hooked up the new system so you don't plug up with garbage or smelly stuff. . You need to be sure your pump can "lift" the 3+ feet of water. Helen
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5956 (20110315) __________
http://www.eset.com
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5958 (20110316) __________
http://www.eset.com
Chris Campbell2011-03-16 17:43 UTC
My Cal 20 doesn't have enough of a bilge sump so this is a mystery
problem for me, but I'm wondering if one longer-term solution isn't
glassing over the deep, inaccessible bilge sump. You could dry it out,
insert a carved chunk of styrofoam to fit, and use that to lay some
roving & epoxy over.
Sometimes it's helpful to have a sump area where water can collect
without making a mess in the cabin, but if the thing is too
inaccessible, maybe downsizing it is a better plan.
mike farrell2011-03-16 20:20 UTC
I cleaned an old British Seagull brass fuel tank that had a 10/1 fuel mix
evaporate over an 8 year period and red wine vinegar was what did the job. In
the carb too. Took about 3 refills but it did the job with no trama to the
tank.
My Best, Mike
Sent: Wed, March 16, 2011 8:34:05 AM
Mark
>From: Barrie North
>Thanks Helen
>Barrie
>http://www.eset.com
http://www.eset.com
mike farrell2011-03-16 20:25 UTC
I put a piece of foam in my cal20 o/b well. It's not class legal but
offshore it takes a lot of water out that I don't have to account for.
Mike Farrell Cal 20 #61 Coyote
Sent: Wed, March 16, 2011 10:43:32 AM
My Cal 20 doesn't have enough of a bilge sump so this is a mystery problem for
me, but I'm wondering if one longer-term solution isn't glassing over the deep,
inaccessible bilge sump. You could dry it out, insert a carved chunk of
styrofoam to fit, and use that to lay some roving & epoxy over.
Sometimes it's helpful to have a sump area where water can collect without
making a mess in the cabin, but if the thing is too inaccessible, maybe
Barrie North2011-03-17 01:02 UTC
Awesome tips Mark!
Barrie
On Wed, Mar 16, 2011 at 11:34 AM, Mark Alan Stahnke (MAS Consulting) <
> Mark
Mark Alan Stahnke (MAS Consulting)2011-03-17 02:07 UTC
I could use it for water ballast on a windy day or the hot ticket would be to cut some access through the salon floor
with a storage box set into the keel. Thinking hold a lot of beer on ice. Mark
Sent: Wednesday, March 16, 2011 10:43 AM
My Cal 20 doesn't have enough of a bilge sump so this is a mystery problem for me, but I'm wondering if one longer-term solution isn't glassing over the deep, inaccessible bilge sump. You could dry it out, insert a carved chunk of styrofoam to fit, and use that to lay some roving & epoxy over.
Sometimes it's helpful to have a sump area where water can collect without making a mess in the cabin, but if the thing is too inaccessible, maybe downsizing it is a better plan.
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5960 (20110316) __________
http://www.eset.com
Chris Campbell2011-03-17 12:59 UTC
> ice. Mark
From what I've read about the odors and crud lurking in those spaces,
wouldn't it be kinda like keeping your beer on ice in the toilet bowl?
Helen Horn2011-03-17 19:10 UTC
mine actually went side to side almost to the risers about the battery
compartment, about 3 or so inches front to back( i don't know if the previous
owner perhaps cut the floor pan a little bigger, he had the batteries installed
in the side mini compartments either side of the engine trough)..after I did the
pump and tubing, I put in a few of those plastic/poly floor squares like west
marine sells for airspacing or deckwalk and cut a notch for the tubing before
installing the batteries, that way you can catch most debris before it has a
chance to get into that sump. It works great. I got a cheap version of those
pinch-together tiles years ago in boxes of 10 for 12 dollars, cut to fit and use
them everywhere for air: under dishes, food, etc. in the cabinets behind the
galley, under the v-berth cushions, just wish I had bought more, cant find any
more.
and for those little metal things, that are ferrous, I keep a small fridge
magnet on a string with a stick attached that floats if I drop it, in my tools.
away from electronics. I also keep a big magnet block contractors use to clean
nails from driveways etc. about an inch thick, 2x4 inches with an eye on top.
Helen
Sent: Wed, March 16, 2011 7:51:37 AM
Thanks Helen
Barrie
