21 messages2011-03-27 20:04 UTCthrough 2011-03-28 22:48 UTC
1978 4.5 Mercury
Buddy Burnett2011-03-27 20:04 UTC
I purchased a Cal 21a few days ago and it came with a 1978 Mercury 4.5 HP
outboard. I have tried to make this motor run to no avail??? I did replace
the spark plug and replaced a fuel supply line on the motor. I had to build
a fuel line connector from the tank to the outboard itself because of the
fitting on the motor. It is a ¼ NPT. Bought new fuel hose and ball. If I
put fuel in the carburetor throat replace cowling it will start on the first
pull and run as sweet as can be for about 7 seconds. Is this the fuel pump,
filter? Any input would be greatly appreciated J
Bud
Re: 1978 4.5 Mercury
hfein12011-03-27 23:49
Get a carburetor kit or have the carburetor rebuilt. If you do it yourself pay special attention to the float needle and seat and make sure the jets are not clogged. With a repair manual it should take about 45 min to one hour to rebuild once you get it off the machine. Some carburetors only use a reed valve to pump fuel and these have a tendancy to rip or be perforated. Probably better that you learn to rebuild because generally you'll be rebuilding it on a yearly basis.
Howard
> fitting on the motor. It is a ¼" NPT. Bought new fuel hose and ball. If I
> Bud
RE: [Cal_Boats] Re: 1978 4.5 Mercury
Buddy Burnett2011-03-28 00:02 UTC
Hi Howard,
Thanks for your input J I have rebuilt more carbs than I care to remember
but I just dont think this is a carb problem??? I will keep the group
informed when I fix this motor and I will fix it J
Of hfein1
Sent: Sunday, March 27, 2011 7:49 PM
Subject: [Cal_Boats] Re: 1978 4.5 Mercury
Howard
build
first
pump,
> Bud
Re: [Cal_Boats] Re: 1978 4.5 Mercury
Allen Edwards2011-03-28 01:13 UTC
My 25 cents is on it being a carb problem. Just my 2 cents :-)
On Sun, Mar 27, 2011 at 5:02 PM, Buddy Burnett <bb… [at] comcast.net> wrote:
> Hi Howard,
> but I just don’t think this is a carb problem??? I will keep the group
> Behalf Of *hfein1
> *Sent:* Sunday, March 27, 2011 7:49 PM
> *Subject:* [Cal_Boats] Re: 1978 4.5 Mercury
> Howard
> replace
> build
> first
> pump,
> > Bud
Buddy Burnett2011-03-28 02:16 UTC
We will know tomorrow J
Allens money is on Carb gone bad J
Bud
Of Allen Edwards
Sent: Sunday, March 27, 2011 9:13 PM
Subject: Re: [Cal_Boats] Re: 1978 4.5 Mercury
Hi Howard,
Of hfein1
Howard
build
first
pump,
> Bud
The SV Emergency Exit Crew2011-03-28 02:55 UTC
Sounds right. If you can run it by wetting the throat, but it dies either your
not getting fuel into the bowl because the fuel pump is out, or not getting
fuel to the bowl because the float is stuck up, or because there's a clog
between the bowl and the throat. I had a bit of green gooey goop in a carb
orifice in my 4.5 once.
Sent: Sun, March 27, 2011 9:16:38 PM
Subject: RE: [Cal_Boats] Re: 1978 4.5 Mercury
Allen’s money is on “Carb gone bad” J
Bud
From:Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of
Allen Edwards
Hi Howard,
Thanks for your input J I have rebuilt more carbs than I care to remember but I
just don’t think this is a carb problem??? I will keep the group informed when I
hfein1
Howard
> Bud
Husar, Charlie [USA]2011-03-28 03:03 UTC
Hi, Bud. You could have a stuck pin at the fuel intake, but I'll put $5 on Allen.
I am getting ready to take 3 and a half old Johnson/Evinrude 6 engines to a fellow CAL 25 racer who is rebuilding outboards as a retirement hobby. Told him if he got a working engine out of the lot I would buy it from him. It is the dickens getting these things down a folding stairway from my attic. Seems I was younger when I put them up there. Those 6s were original equipment on the CAL 25.
Best of luck. A running engine is a joy forever (or at least for however long it does run).
Annapolis
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Buddy Burnett
Sent: Sunday, March 27, 2011 10:17 PM
We will know tomorrow :)
Allen's money is on "Carb gone bad" :)
Bud
On Sun, Mar 27, 2011 at 5:02 PM, Buddy Burnett <bb… [at] comcast.net<mailto:bb… [at] comcast.net>> wrote:
Hi Howard,
Thanks for your input :) I have rebuilt more carbs than I care to remember but I just don't think this is a carb problem??? I will keep the group informed when I fix this motor and I will fix it :)
From: Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com> [mailto:Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com>] On Behalf Of hfein1
Howard
--- In Ca… [at] yahoogroups.com<mailto:Cal_Boats%40yahoogroups.com>, "Buddy Burnett" <bburnett@...<mailto:bburnett@...>> wrote:
> Bud
Buddy Burnett2011-03-28 14:51 UTC
Charlie has put $5.00 on the carb J
Of Husar, Charlie [USA]
Sent: Sunday, March 27, 2011 11:03 PM
Allen.
long it does run).
Annapolis
Of Buddy Burnett
Bud
Of Allen Edwards
Hi Howard,
Of hfein1
Howard
build
first
pump,
> Bud
Re: [Cal_Boats] 1978 4.5 Mercury
Chris Campbell2011-03-28 18:05 UTC
> HP outboard. I have tried to make this motor run to no avail??? I did
> replace the spark plug and replaced a fuel supply line on the motor. I
> had to build a fuel line connector from the tank to the outboard
> itself because of the fitting on the motor. It is a ¼” NPT. Bought new
> fuel hose and ball. If I put fuel in the carburetor throat replace
> cowling it will start on the first pull and run as sweet as can be for
> about 7 seconds. Is this the fuel pump, filter? Any input would be
I left some modern gas in the tank for my old Johnson fishing motor over
the winter. In the spring it started starving for gas--you had to keep
pumping the fuel bulb to make it go. I finally traced it to the steel
fuel pick-up in the tank--the alcohol in the gas attracted water and
that rusted the steel. I applied epoxy as a repair and the motor is happy.
In my experience, when an engine runs when gas is dumped in the carb,
it's a sure sign of carburetor plugging. Sometimes if you start it that
way and quickly pop your hand over the carb air intake, an offending
particle gets sucked through and it will run again. This often works
for lawn mowers, which operate in a very dirty environment.
Chris Campbell2011-03-28 18:09 UTC
> $5 on Allen.
> it from him.
If he ends up with an extra carburetor from the batch, or even just the
plastic cam follower that operates the throttle valve, tell him to
quote me a price. It would be nice to have an extra carb and also to
see whether the wear on the plastic part is making my old motor unhappy.
RE: [Cal_Boats] 1978 4.5 Mercury
Buddy Burnett2011-03-28 18:20 UTC
Thanks Chris, I checked and my pickup tube is new and plastic J Also am
taking carb apart later today to rebuild J as to rule it out.
Of Chris Campbell
Sent: Monday, March 28, 2011 2:06 PM
Subject: Re: [Cal_Boats] 1978 4.5 Mercury
I left some modern gas in the tank for my old Johnson fishing motor over the
winter. In the spring it started starving for gas--you had to keep pumping
the fuel bulb to make it go. I finally traced it to the steel fuel pick-up
in the tank--the alcohol in the gas attracted water and that rusted the
In my experience, when an engine runs when gas is dumped in the carb, it's a
sure sign of carburetor plugging. Sometimes if you start it that way and
quickly pop your hand over the carb air intake, an offending particle gets
sucked through and it will run again. This often works for lawn mowers,
Chris has put a fiver on the carb J
Of Chris Campbell
Sent: Monday, March 28, 2011 2:09 PM
Allen.
plastic cam follower that operates the throttle valve, tell him to quote me
a price. It would be nice to have an extra carb and also to see whether the
Chris Campbell2011-03-28 18:43 UTC
On 3/28/2011 2:20 PM, Buddy Burnett wrote:
> Thanks Chris, I checked and my “pickup tube is new and plastic J Also
> am taking carb apart later today to rebuild J as to rule it out.
The generalized lesson is that any system that sucks gas is vulnerable
to a tiny leak that lets air in. My brother was moving to Kalamazoo and
I was nominated to follow his rented truck in the 1966 Plymouth station
wagon (a grand vehicle, by the way). But three blocks from the old house
it started losing power. It would start, run, and stall out. Rusted
fuel line. (Remember, in those days the fuel pump was on the engine and
sucked gas, unlike the new ones that are in the tank and push it.)
Chris
Allen Edwards2011-03-28 18:47 UTC
On my carb, I had to actually take the jets out before boiling out the carb
to get a really well running engine.
On Mon, Mar 28, 2011 at 11:20 AM, Buddy Burnett <bb… [at] comcast.net>wrote:
> Thanks Chris, I checked and my “pickup tube is new and plastic J Also am
> Behalf Of *Chris Campbell
> *Sent:* Monday, March 28, 2011 2:06 PM
> *Subject:* Re: [Cal_Boats] 1978 4.5 Mercury
> fitting on the motor. It is a ¼” NPT. Bought new fuel hose and ball. If I
> pumping the fuel bulb to make it go. I finally traced it to the steel fuel
> pick-up in the tank--the alcohol in the gas attracted water and that rusted
> a sure sign of carburetor plugging. Sometimes if you start it that way and
> Chris Campbell
The SV Emergency Exit Crew2011-03-28 18:51 UTC
I'd also recommend you yet some aerosol carb and throttle body cleaner (with a
little spray tube) and verify you can blow air thru all passageways..I did that
last time I had the same problem and a bit of green goop blew out one of them,
ran fine after that...
Sent: Mon, March 28, 2011 1:20:29 PM
Subject: RE: [Cal_Boats] 1978 4.5 Mercury
Thanks Chris, I checked and my “pickup tube is new and plastic J Also am taking
outboard. I have tried to make this motor run to no avail??? I did replace the
spark plug and replaced a fuel supply line on the motor. I had to build a fuel
line connector from the tank to the outboard itself because of the fitting on
the motor. It is a ¼” NPT. Bought new fuel hose and ball. If I put fuel in the
carburetor throat replace cowling it will start on the first pull and run as
sweet as can be for about 7 seconds. Is this the fuel pump, filter? Any input
winter. In the spring it started starving for gas--you had to keep pumping the
fuel bulb to make it go. I finally traced it to the steel fuel pick-up in the
tank--the alcohol in the gas attracted water and that rusted the steel. I
sucked through and it will run again. This often works for lawn mowers, which
The SV Emergency Exit Crew2011-03-28 19:02 UTC
Chris Campbell2011-03-28 19:19 UTC
On 3/28/2011 3:02 PM, The SV Emergency Exit Crew wrote:
> From experience I can sure tell you that you do not want to break the
> little plastic part that links the vertical shaft from the tiller to
> the throttle arm - the one that looks like a little crane. As far as I
> could tell its exclusive to that motor.
My very elderly (about 1967) Evinrude is all metal except for the little
plastic lever that follows the cam on the breaker plate (under the
flywheel). The throttle control---the part that you twist for
fast/slow-- rotates that breaker plate to change the ignition timing,
and the little plastic lever gizmo follows a cam that opens the
carburetor throttle when the breaker plate rotates and advances the
timing. But the little plastic gizmo has a groove worn in it so it
doesn't open the carburetor throttle as much as it should.
A picture is worth a thousand words, isn't it?
I've pondered trying to patch with epoxy just to see if it makes any
difference.
Allen Edwards2011-03-28 19:28 UTC
But that is not always enough. On my carb, that didn't do it (I tried it).
Removing everything from the carb and soaking in a gallon of parts cleaner
is what did it. Unscrewing the jets required grinding down a screwdriver to
just the right size btw.
On Mon, Mar 28, 2011 at 11:51 AM, The SV Emergency Exit Crew <
> (with a little spray tube) and verify you can blow air thru all
> passageways..I did that last time I had the same problem and a bit of green
> goop blew out one of them, ran fine after that...
> *From:* Buddy Burnett <bb… [at] comcast.net>
> *Sent:* Mon, March 28, 2011 1:20:29 PM
> *Subject:* RE: [Cal_Boats] 1978 4.5 Mercury
> Chris Campbell
Outboard Maintenance, was:Re: [Cal_Boats] 1978 4.5 Mercury
Gerald Sobel2011-03-28 21:36 UTC
My routine after sailing, is to use a vinyl bucket which attaches to a hose, submerged around the prop to flush the salt out of the cooling system. Once I get the motor running, I unhook the fuel line and let the motor run until it's out of gas. Other than having to replacing the impeller at six years, after I plugged the cooling line with a broken impeller blade and killed the motor on the way to a race (fortunately I didn't sieze the engine, I then noticed it had stop spitting water, whew!) I haven't had to do a thing to the engine. I think, if you run the fuel dry, and change the cooling system impeller every three years, you won't have to do much to maintain a 2 cycle outboard...or a 4 cycle outboard, unless you also have to periodically adjust the valve lash clearance? BTW I'm on my third outboard, a Suzuki 4, and I can't recommend it too highly. Any old codgers out there that remember the Suzuki X-6 Hustler that would blow every other bike away
in the late sixties?
Date: Monday, March 28, 2011, 11:47 AM
On my carb, I had to actually take the jets out before boiling out the carb to get a really well running engine.
On Mon, Mar 28, 2011 at 11:20 AM, Buddy Burnett <bb… [at] comcast.net> wrote:
Thanks Chris, I checked and my “pickup tube is new and plastic J Also am taking carb apart later today to rebuild J as to rule it out.
I purchased a Cal 21a few days ago and it came with a 1978 Mercury 4.5 HP outboard. I have tried to make this motor run to no avail??? I did replace the spark plug and replaced a fuel supply line on the motor. I had to build a fuel line connector from the tank to the outboard itself because of the fitting on the motor. It is a ¼” NPT. Bought new fuel hose and ball. If I put fuel in the carburetor throat replace cowling it will start on the first pull and run as sweet as can be for about 7 seconds. Is this the fuel pump, filter? Any input would be greatly appreciated J
I left some modern gas in the tank for my old Johnson fishing motor over the winter. In the spring it started starving for gas--you had to keep pumping the fuel bulb to make it go. I finally traced it to the steel fuel pick-up in the tank--the alcohol in the gas attracted water and that rusted the steel. I applied epoxy as a repair and the motor is happy.
In my experience, when an engine runs when gas is dumped in the carb, it's a sure sign of carburetor plugging. Sometimes if you start it that way and quickly pop your hand over the carb air intake, an offending particle gets sucked through and it will run again. This often works for lawn mowers, which operate in a very dirty environment.
RE: Outboard Maintenance, was:Re: [Cal_Boats] 1978 4.5 Mercury
Harleigh and/or Kathy Ewell2011-03-28 21:52 UTC
Ex- X-6 owner here.
Harleigh Ewell
Sent: Monday, March 28, 2011 5:37 PM
Subject: Outboard Maintenance, was:Re: [Cal_Boats] 1978 4.5 Mercury
My routine after sailing, is to use a vinyl bucket which attaches to a hose, submerged around the prop to flush the salt out of the cooling system. Once I get the motor running, I unhook the fuel line and let the motor run until it's out of gas. Other than having to replacing the impeller at six years, after I plugged the cooling line with a broken impeller blade and killed the motor on the way to a race (fortunately I didn't sieze the engine, I then noticed it had stop spitting water, whew!) I haven't had to do a thing to the engine. I think, if you run the fuel dry, and change the cooling system impeller every three years, you won't have to do much to maintain a 2 cycle outboard...or a 4 cycle outboard, unless you also have to periodically adjust the valve lash clearance? BTW I'm on my third outboard, a Suzuki 4, and I can't recommend it too highly. Any old codgers out there that remember the Suzuki X-6 Hustler that would blow every other bike away in the late sixties?
Re: Outboard Maintenance, was:Re: [Cal_Boats] 1978 4.5 Mercury
Allen Edwards2011-03-28 22:48 UTC
I used to borrow my friends X-6. He would take my Austin Healey (which I
still have and is older than my boat) and I would take his X-6. Fun bike.
He out a bit of nitro fuel in the gas tank once (model airplane fuel). He
was riding along and when the nitro hit the engine the thing popped a
wheelie.
I do the same routine with running the carb out of gas with my emergency
Honda generator that we keep around the house. It sits for years and then
starts right up. When I first got it, I had to clean the carb to get it to
start. I used to do the same running out of gas thing with Papoose but if
you run the engine every few weeks, it isn't necessary.
> Jerry
> --- On *Mon, 3/28/11, Allen Edwards <al… [at] PaloAltoPhoto.com>*wrote:
> Allen
> On Mon, Mar 28, 2011 at 11:20 AM, Buddy Burnett <bb… [at] comcast.net<http://mc/compose?to=bb… [at] comcast.net>
> *From:* Ca… [at] yahoogroups.com<http://mc/compose?to=Ca… [at] yahoogroups.com>[mailto:
> Ca… [at] yahoogroups.com <http://mc/compose?to=Ca… [at] yahoogroups.com>]
> *On Behalf Of *Chris Campbell
> *To:* Ca… [at] yahoogroups.com<http://mc/compose?to=Ca… [at] yahoogroups.com>
> Chris Campbell
