Cal 40
Cal 40
2 messages2010-05-05 20:34 UTCthrough 2011-04-01 15:29 UTC
Cal 40
Rich Beliveau2010-05-05 20:34 UTC
There's a cal 46 anchored off of the channel 5 bridge in the Florida Keys named Blew Moon if anyones interested. Tried to get thier attention but had no luck. Rich On May 5, 2010, at 4:30 PM, Wayne Gillikin <wa… [at] yahoo.com> wrote: glue that is holding the boat together. Which web site? Regards, Wayne ________________________________ From: "pw… [at] aol.com" To: Ca… [at] yahoogroups.com Sent: Wed, May 5, 2010 4:24:11 PM Subject: Re: [Cal_Boats] Vinyl & Glue Removed . . . more fun begins Well > done, Paul! Damned impressive job. Thanks but I think the the demo is going to be the easy part. Making it look good is going to be the hard part . . . I see lots of sanding in my future. > >Question, > was all the glue you removed with the brush dry? Did you have any glue > that was gummy? If so how did you remove the gummy glue? > Thankfully it was all dry and crusty. Probably when I wipe it all down with acetone I'll make it gummy again with my luck. Hey, did you ever get your website up and running? Paul > > > > > > > ________________________________ From: "pw… [at] aol.com" > >To: > Ca… [at] yahoogroups.com >Cc: > mr… [at] efni.com >Sent: Wed, May > 5, 2010 3:59:29 PM >Subject: > [Cal_Boats] Vinyl & Glue Removed . . . more fun begins > >Well, all the vinyl is gone and most of the glue taken off with an angle > grinder with one bad ass wire brush attached. I was smart enough to > mask off the areas where I didn't want residue with masking tape and cheap > drop cloths which saved me a lot of cleanup. > > >I also wore appropriate safety gear . . .LUKE . . . I AM YOUR FATHER . . > . at least that's what I felt like ;-) > >The clean spot in the middle is after one pass of the grinder > > >My next step is to wash down the walls with acetone and get as much > remaining residue off as I can. Then I hope to fair it with West > Systems 410, the light micro-ballons. > >Here is the question of the day . . . am I now going to be getting > condensation on these "walls" and the underside of the decks? If so, was > the foam backed vinyl that was there preventing it before or just > absorbing it? > >Donald if you're reading this, did your wife ever have the chance to look > into insulation values of paints or fillers with the microballoons? > >The one thing that has really struck me about this job so far is how > inaccessible the genny track bolts, the stanchion base bolts and basically > anything bolted to the side decks are. Without basically destroying the > interior of the boat they are basically not accessible which explains why I > have 2 stanchion bases that are cracked and probably 3 others that > wobble! > >Paul West >Adventure Kwest >'80 Cal 39 > > > --0-1510881450-1273091413=:72635 Content-Type: multipart/related; boundary="0-1916493419-1273091413=:72635" --0-1916493419-1273091413=:72635 Content-Type: text/html; charset=us-ascii If the glue on your boat is the same as the glue on my boat it will completely ignore the acetone. I removed all the crusty glue on my boat with a stiff wire brush on a hang drill. However, when the brush got into the gooey stuff it got gummed up and nothing except paint remover will get it off. Could be the glue that is holding the boat together. Which web site? Regards, Wayne From: "pw… [at] aol.com" <pw… [at] aol.com> To: Ca… [at] yahoogroups.com Sent: Wed, May 5, 2010 4:24:11 PM Subject: Re: [Cal_Boats] Vinyl & Glue Removed . . . more fun begins Well done, Paul! Damned impressive job. Thanks but I think the the demo is going to be the easy part. Making it look good is going to be the hard part . . . I see lots of sanding in my future. Question, was all the glue you removed with the brush dry? Did you have any glue that was gummy? If so how did you remove the gummy glue? Thankfully it was all dry and crusty. Probably when I wipe it all down with acetone I'll make it gummy again with my luck. Hey, did you ever get your website up and running? Paul From: "pw… [at] aol.com" <pw… [at] aol.com> To: Ca… [at] yahoogroups.com Cc: mrtn
CAL 40
r good2011-04-01 15:29 UTC
http://talkofthedock.com/boat-reviews/used-sail/264-cal-40-review-of-a-classic
