3 messages2011-04-12 17:44 UTCthrough 2011-04-12 17:58 UTC
Re: [Cal_Boats] Cutter Rig on Cal 39?
pw… [at] aol.com2011-04-12 17:44 UTC
I've seen them on a lot of boats too but don't recall if they were ocean
going or not and don't know if they'll withstand 6" of green water over the
deck. I have 2 more dorades aft so I still have some ventilation.
Paul
In a message dated 4/12/2011 1:23:57 P.M. Eastern Daylight Time,
ch… [at] gmail.com writes:
Ive seen them on many boat, the solar nicro ones. They are quite
substantial if and can be turned on and off from the inside in terms of air
movement. However, you will get much better air flow with the dorades based on the
size of the openings. I would stick with them. Actually at some point, I
would like to add two to my 29 which lacks good air flow when everything is
closed up. I know it doesn't make sense but that's when you need good flow
rate to keep things fresh. The solar powered one is excellent in the head
however where it sits.
chris1232011-04-12 17:51 UTC
I was referring to blue water boats. Best to call the company.
My buddy had two on his Erickson 35 and he travelled some 7K miles single
handed down the Eastern Seaboard from Lake Ontario to Rio D via the St.
Lawrence and the Canadian maritimes to Florida, Cuba etc, and then off to
Honduras and back a couple of times. Lots of bad weather and he never
reported any issues with them. They lasted three years, then the battery had
to be replaced. However, in terms of air flow and exchange, the dorades IMHO
do a better job while under way in terms of airflow.
> Paul
> on the size of the openings. I would stick with them. Actually at some
> point, I would like to add two to my 29 which lacks good air flow when
> everything is closed up. I know it doesn't make sense but that's when you
> need good flow rate to keep things fresh. The solar powered one is excellent
> in the head however where it sits.
> /ch
pw… [at] aol.com2011-04-12 17:58 UTC
Oh, sorry, thanks for the clarification, that is good to know.
Now I just need to determine how I would rig the tracks for the staysail
for the cutter rig and if I need to remove them for that and how or if they
will interfere with the hand rails..
Paul
In a message dated 4/12/2011 1:51:32 P.M. Eastern Daylight Time,
Honduras and back a couple of times. Lots of bad weather and he never reported
any issues with them. They lasted three years, then the battery had to be
replaced. However, in terms of air flow and exchange, the dorades IMHO do a
On Tue, Apr 12, 2011 at 1:44 PM, <_p… [at] aol.com_
Paul
_c… [at] gmail.com_ (mailto:ch… [at] gmail.com) writes:
