5 messages2011-04-15 17:26 UTCthrough 2011-04-15 20:24 UTC
New Bilge Pump uses Wave Energy
ti… [at] ch2m.com2011-04-15 17:26 UTC
If you have not seen this device check it out, If you have one, can you report if it really works?
Very cool idea.
[http://email.jamestowndistributors.com/emails/Images/Week4308/jdheader.gif]<http://mailer.jamestowndistributors.com/t?r=1942&c=2548500&l=58813&ctl=3604984:C81C49D45511C48EB77A1150A3474BCAF0D6C8E7B49CBABD&>
[http://email.jamestowndistributors.com/emails/Images/week1409/menubar_email.png]
[http://www.jamestowndistributors.com/userportal/images/email/041411.png]<http://mailer.jamestowndistributors.com/t?r=1942&c=2548500&l=58813&ctl=3604983:C81C49D45511C48EB77A1150A3474BCAF0D6C8E7B49CBABD&>
Drainman Features
* Pumps up to 660 gallons per day
* Easy to install
* Self Priming
* Max Suction length is 26 feet
* Powered through kinetic energy
* Requires no wiring!
JD Videos
[http://www.jamestowndistributors.com/userportal/images/email/041411_vid.png]<http://mailer.jamestowndistributors.com/t?r=1942&c=2548500&l=58813&ctl=3604985:C81C49D45511C48EB77A1150A3474BCAF0D6C8E7B49CBABD&>
Drainman Demonstration<http://mailer.jamestowndistributors.com/t?r=1942&c=2548500&l=58813&ctl=3604985:C81C49D45511C48EB77A1150A3474BCAF0D6C8E7B49CBABD&>
Please Unsubscribe Me<http://whatcounts.com/bin/listunsub?id=C81C49D45511C48EB77A1150A3474BCAF0D6C8E7B49CBABD>
Jamestown Distributors
17 Peckham Drive
Bristol, RI 02809
800-497-0010
Re: [Cal_Boats] New Bilge Pump uses Wave Energy
Helen Horn2011-04-15 18:30 UTC
Timm, doesn't 26 feet max sound like most of it is in the cockpit length or bow
length, plus the distance to the pump piece, and then what, through a hole (eek)
in something to get it into the bilge, by then the last 15 (max) feet will be
threaded through more holes, and create a lift as well, not clearly addressed by
the ad?? I also would want a secondary parallel on the mooring as the stitching
on that tether (or glue?) could be a weak spot. It might work on a dinghy under
tow? Just my opinion, it looks like a toy right now, maybe R & D could improve
it. It relies on regular frequent surges that may not be at some moorings or in
some conditions. A solar charger to a battery to bilge pump would be more
consistent and almost as green.(and cost less?). Helen
Sent: Fri, April 15, 2011 10:26:42 AM
Subject: [Cal_Boats] New Bilge Pump uses Wave Energy
if it really works?
Very cool idea.
Drainman Features
* Easy to install
* Self Priming
JD Videos
17 Peckham Drive
Bristol, RI 02809
800-497-0010
mike2011-04-15 18:32 UTC
It's such a simple mechanism I don't see how it couldn't work as long as
that line is the one that gets tensioned. Neat idea! I hope the inventor
makes enough to keep his boat in good shape.
Mike M.
> Very cool idea.
> Drainman - Nature Powered Bilge Pump
> Drainman Features
> * Easy to install
> * Self Priming
> * */Requires no wiring!/*
> JD Videos
> jdtv
> *Please Unsubscribe Me
> <http://whatcounts.com/bin/listunsub?id=C81C49D45511C48EB77A1150A3474BCAF0D6C8E7B49CBABD>*
> *Jamestown Distributors
> 17 Peckham Drive
> Bristol, RI 02809
> 800-497-0010 ***
chris1232011-04-15 18:47 UTC
I like the simplicity as well, however restricting your bilge pump output
capacity to wave action along sounds kinda dangerous to me. I would prefer
to have the bilge pump electrified and perhaps this system for 69.00 as a
backup. I would not trust my boats bilge to this device alone.
> Mike M.
RE: [Cal_Boats] New Bilge Pump uses Wave Energy
Drew Ratchelous2011-04-15 20:24 UTC
my friend uses a wave pump in his wooden boat in south west harbor maine, works very well once the seams have swelled up after launch. He hangs it off the stern and adjusts the height so the float is in mid stroke so any movement of wave or boat works the pump.
drew new haven ct
http://www.securefixdirect.com/wave-pump-1122-p.asp
Date: Fri, 15 Apr 2011 11:26:42 -0600
Very cool idea.
Drainman Features
Easy to install
Self Priming
Requires no wiring!
JD Videos
17 Peckham Drive
Bristol, RI 02809
800-497-0010
