10 messages2011-05-01 00:47 UTCthrough 2011-05-03 23:01 UTC
which tool?
r good2011-05-01 00:47 UTC
removing old cast aluminum opening portlights, 5"x12". at least 3 were re-bedded with 5200. Mechanical separation required.
cheap wood chissels?
filed putty knife?
multitool?
rotary tool?
Re: [Cal_Boats] which tool?
mike2011-05-01 01:23 UTC
Reggie,
Do you have a Fein or Sonicrafter with a plunge cut attachment? That may
be able to get the majority of the crud out. You might be able to thread
a length of piano wire through and pull it like a cheese cutter to
loosen the rest. If you don't plan on saving the old ports, maybe you
can make some relief cuts so you can drive it out with a chisel. Be very
careful not to delaminate the glass. I'm sure there are a few more ideas
that will pop up here. We have a lot of folks that have
been-there-done-that.
Have fun!
Mike M.
> filed putty knife?
> multitool?
> rotary tool?
Tom Vandiver2011-05-01 08:53 UTC
Hi Reggie,
I used a heat gun, very carefully. 5200 releases at 135 degrees, then you can
get under the item to be removed with a dulled putty knife. Keep the heat gun
moving as it will burn if left too long in one spot.
We were super careful and did not damage our Sterling paint job.
Tom Vandiver
To: ca… [at] yahoogroups.com
Sent: Sat, April 30, 2011 7:47:32 PM
Subject: [Cal_Boats] which tool?
filed putty knife?
multitool?
rotary tool?
Re: which tool?
Danny2011-05-01 15:41
I used the same heat and putty knife combo and it worked just fine.
Danny
--- In Ca… [at] yahoogroups.com, Tom Vandiver <bshmarine@...> wrote:
> Hi Reggie,
> Tom Vandiver
> From: r good <my1972ih@...>
> Â
> re-bedded with 5200. Mechanical separation required.Â
> Â
> filed putty knife?
> multitool?
> rotary tool?
> Â
Evren Cakir2011-05-01 15:57 UTC
Or a heat gun. Whats that gunk u used on ur keychain?
On May 1, 2011, at 1:53 AM, Tom Vandiver <bs… [at] yahoo.com> wrote:
> Hi Reggie,
> I used a heat gun, very carefully. 5200 releases at 135 degrees, then you can get under the item to be removed with a dulled putty knife. Keep the heat gun moving as it will burn if left too long in one spot.
> Tom Vandiver
> From: r good <my… [at] hotmail.com>
> filed putty knife?
> multitool?
> rotary tool?
Chris Campbell2011-05-02 13:52 UTC
> filed putty knife?
My own approach to 5200 has usually been to invoke lots of foul and
abusive language. It works as well as anything, which is to say, hardly
at all.
The last time I had a car windshield replaces (quite a while ago,
luckily) the guy used a wire with handles at each end to cut through the
sealant. It was probably "piano wire." It worked very well, although
the bead through which it had to cut was fairly thick and was, I think,
neoprene.
Kirk Grier2011-05-02 16:44 UTC
The "piano wire" is Cut-Out Wire and Equalizer has it for sale in kits with
the starter which allows you to puncture the seal and thread the wire.
http://bit.ly/jSFkHq
http://www.equalizer.com/
HTH
Kirk
>> filed putty knife?
> My own approach to 5200 has usually been to invoke lots of foul and abusive
> language. It works as well as anything, which is to say, hardly at all.
> The last time I had a car windshield replaces (quite a while ago, luckily)
> the guy used a wire with handles at each end to cut through the sealant. It
> was probably "piano wire." It worked very well, although the bead through
> which it had to cut was fairly thick and was, I think, neoprene.
> Chris Campbell
Kirk Grier
kg… [at] kirkgrier.com
RE: [Cal_Boats] which tool?
John Boyce2011-05-02 20:30 UTC
I saw one of those tools at harbor freight
Of Chris Campbell
Sent: Monday, May 02, 2011 9:53 AM
Subject: Re: [Cal_Boats] which tool?
filed putty knife?
Husar, Charlie [USA]2011-05-03 17:16 UTC
Reggie, the wire sounds like a great idea. Have not tried it. I have found putty knives to be too flexible. I have used a pair of sharp wood chisels (at least 1" wide). Drive one in just a little, then drive the other chisel right next to it, then remove first and repeat. Pray that you are opening a bit of separation at a time without bending the frame or scratching up the fiberglas. I've destroyed some windows, and gotten others out intact. No warrantee, written or implied.
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of John Boyce
Sent: Monday, May 02, 2011 4:30 PM
Subject: RE: [Cal_Boats] which tool?
filed putty knife?
My own approach to 5200 has usually been to invoke lots of foul and abusive language. It works as well as anything, which is to say, hardly at all.
The last time I had a car windshield replaces (quite a while ago, luckily) the guy used a wire with handles at each end to cut through the sealant. It was probably "piano wire." It worked very well, although the bead through which it had to cut was fairly thick and was, I think, neoprene.
r good2011-05-03 23:01 UTC
the old windows are expendable
Date: Tue, 3 May 2011 13:16:08 -0400
filed putty knife?
