6 messages2011-05-10 19:04 through 2011-05-10 20:32 UTC
Need mast spec for cal 34 III
dasiel2011-05-10 19:04
Hi I need the specs for the mast of a 1979 Cal 34 III.
Any help would be appreciated I have been able to find the sail plan but not the mast. I also found a line and tech drawing for a Cal 34 but not for the later Cal 34 III
thanks
Re: [Cal_Boats] Need mast spec for cal 34 III
Allen Edwards2011-05-10 19:15 UTC
What happened to the old mast? Did it sink?
> thanks
Re: Need mast spec for cal 34 III
dasiel2011-05-10 19:17
Yes it did it in the bottom of the Gulf
> Allen
> > thanks
Re: [Cal_Boats] Re: Need mast spec for cal 34 III
Michael Kennedy2011-05-10 20:24 UTC
I'd think the sail plan would give you most of the specs. My Cal 34
was single spreader and the III version probably has a mast two feet
or so taller. Any rigging shop could give you the details on the mast.
A new one would probably be a smaller section, which is good.
Did you have a survey ? Rigging is suspect on any boat that old unless
it has been replaced.
Mike Kennedy
> > Allen
> plan but
> but not for
> > > thanks
RE: [Cal_Boats] Need mast spec for cal 34 III
John Boyce2011-05-10 20:24 UTC
Contact these people there is a chance that they made the original section.
http://www.lefiell.com/frameset.html
Of dasiel
Sent: Tuesday, May 10, 2011 3:04 PM
Subject: [Cal_Boats] Need mast spec for cal 34 III
later Cal 34 III
thanks
Allen Edwards2011-05-10 20:32 UTC
I am not sure if I were you I would trust dimensions off the web but I have
checked these on three sites and they all agree. One is the PHRF, one
sailboat data, and my site. As far as I know, these are independent
although you never know.
Here is mine
http://l-36.com/boat_dimensions.php?match=cal+34
<http://l-36.com/boat_dimensions.php?match=cal+34>Allen
> Mike Kennedy
> > > Allen
> > plan but
> > but not for
> > > > thanks
> Yahoo! Groups Links
