CAL 29 Bilge Drain
CAL 29 Bilge Drain
2 messages2011-05-16 18:35 UTCthrough 2011-05-16 19:04 UTC
CAL 29 Bilge Drain
chris1232011-05-16 18:35 UTC
Greets: Was wondering what would be the best location to add a bilge drain plug on the 3-29. The interior is different then the 2-29 as you only have access to the forward and very shallow bilge. The deeper bilge at the rear of the keel is very difficult to access as there is no independent access cover to it. You have at max 3" to play with in front of the engine pan. -- /ch
Re: CAL 29 Bilge Drain
chris1232011-05-16 19:04 UTC
More correctly referred too as a Garboard Plug On Mon, May 16, 2011 at 2:35 PM, chris123 <ch… [at] gmail.com> wrote: > Greets: > > Was wondering what would be the best location to add a bilge drain > plug on the 3-29. The interior is different then the 2-29 as you only > have access to the forward and very shallow bilge. The deeper bilge at > the rear of the keel is very difficult to access as there is no > independent access cover to it. You have at max 3" to play with in > front of the engine pan. > > -- > /ch > -- /ch
