running light combinations
7 messages2011-05-23 13:07 UTCthrough 2011-05-25 02:13 UTC
r good2011-05-23 13:07 UTC
does anyone know if it is specifically prohibited to run a masthead tricolor at the same time as deck level running lights? Reggie
Re: [Cal_Boats] running light combinations
Wayne Gillikin2011-05-23 14:14 UTC
According to COLREGS: Sailing Vessel Underway Rule 25 Required lights: side (112.5 degrees) and stern (135 degrees) Other: Lights: Red over Green (all around) at or near top of mast Note: Small sailing vessels (less than 20 meters in length) may combine sidelights and sternlight in one lantern placed at or near the top of the mast. The optional red over green lights may not be shown with such a lantern. I read this to say that the 112.5 degree sidelights and the 135 degree sternlight can EITHER be high or low but not both. Regards, Wayne From: r good <my… [at] hotmail.com> To: ca… [at] yahoogroups.com Sent: Mon, May 23, 2011 9:07:27 AM Subject: [Cal_Boats] running light combinations does anyone know if it is specifically prohibited to run a masthead tricolor at the same time as deck level running lights? Reggie
RE: [Cal_Boats] running light combinations
Harleigh and/or Kathy Ewell2011-05-23 14:14 UTC
I believe that it is. Further, the tricolor may not be used while under power. Harleigh Ewell Cal 31 From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of r good Sent: Monday, May 23, 2011 9:07 AM To: ca… [at] yahoogroups.com Subject: [Cal_Boats] running light combinations does anyone know if it is specifically prohibited to run a masthead tricolor at the same time as deck level running lights? Reggie
Wayne Gillikin2011-05-23 15:41 UTC
look here: http://www.colregs.info/the-collisions-regulations/part-c-lights-and-shapes/rule-25-sailing-vessels-underway-and-vessels-under-oars/ From: r good <my… [at] hotmail.com> To: ca… [at] yahoogroups.com Sent: Mon, May 23, 2011 9:07:27 AM Subject: [Cal_Boats] running light combinations does anyone know if it is specifically prohibited to run a masthead tricolor at the same time as deck level running lights? Reggie
Mark Alan Stahnke (MAS Consulting)2011-05-23 18:11 UTC
Your white steamer light has to be above color while motoring. However, you can use the 360 white on top for steamer and stern with color below on bow. Mark CAL 2-29 with both tri and deck ----- Original Message ----- From: Wayne Gillikin To: Ca… [at] yahoogroups.com Sent: Monday, May 23, 2011 8:41 AM Subject: Re: [Cal_Boats] running light combinations look here: http://www.colregs.info/the-collisions-regulations/part-c-lights-and-shapes/rule-25-sailing-vessels-underway-and-vessels-under-oars/ ------------------------------------------------------------------------------ From: r good <my… [at] hotmail.com> To: ca… [at] yahoogroups.com Sent: Mon, May 23, 2011 9:07:27 AM Subject: [Cal_Boats] running light combinations does anyone know if it is specifically prohibited to run a masthead tricolor at the same time as deck level running lights? Reggie __________ Information from ESET NOD32 Antivirus, version of virus signature database 6145 (20110523) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com __________ Information from ESET NOD32 Antivirus, version of virus signature database 6145 (20110523) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com
Harleigh and/or Kathy Ewell2011-05-24 14:13 UTC
I assume that you would have to disable any low stern light in this configuration. Harleigh Ewell From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Mark Alan Stahnke (MAS Consulting) Sent: Monday, May 23, 2011 2:12 PM To: Ca… [at] yahoogroups.com Subject: Re: [Cal_Boats] running light combinations  Your white steamer light has to be above color while motoring. However, you can use the 360 white on top for steamer and stern with color below on bow. Mark CAL 2-29 with both tri and deck From: Wayne Gillikin <mailto:wa… [at] yahoo.com> To: Ca… [at] yahoogroups.com Sent: Monday, May 23, 2011 8:41 AM Subject: Re: [Cal_Boats] running light combinations look here: http://www.colregs.info/the-collisions-regulations/part-c-lights-and-shapes/rule-25-sailing-vessels-underway-and-vessels-under-oars/ _____ From: r good <my… [at] hotmail.com> To: ca… [at] yahoogroups.com Sent: Mon, May 23, 2011 9:07:27 AM Subject: [Cal_Boats] running light combinations does anyone know if it is specifically prohibited to run a masthead tricolor at the same time as deck level running lights? Reggie __________ Information from ESET NOD32 Antivirus, version of virus signature database 6145 (20110523) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com __________ Information from ESET NOD32 Antivirus, version of virus signature database 6145 (20110523) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com
Mark Alan Stahnke (MAS Consulting)2011-05-25 02:13 UTC
I did cut the wires to the stern lighton transom. However, not sure if there is a problem with a transom mounted stern light and 360 mast head as long as the color is below the steamer (360)....better check the regs on this for boat size and light config. I chose to keep it simple. 360 mast head white and bow colors for motor and tri color for sail. This eliminates using the original steamer and stern lights. It makes two easy choices sail or power. Mark San Pedro, CAL2-29 ----- Original Message ----- From: Harleigh and/or Kathy Ewell To: Ca… [at] yahoogroups.com Sent: Tuesday, May 24, 2011 7:13 AM Subject: RE: [Cal_Boats] running light combinations I assume that you would have to disable any low stern light in this configuration. Harleigh Ewell From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Mark Alan Stahnke (MAS Consulting) Sent: Monday, May 23, 2011 2:12 PM To: Ca… [at] yahoogroups.com Subject: Re: [Cal_Boats] running light combinations  Your white steamer light has to be above color while motoring. However, you can use the 360 white on top for steamer and stern with color below on bow. Mark CAL 2-29 with both tri and deck ----- Original Message ----- From: Wayne Gillikin To: Ca… [at] yahoogroups.com Sent: Monday, May 23, 2011 8:41 AM Subject: Re: [Cal_Boats] running light combinations look here: http://www.colregs.info/the-collisions-regulations/part-c-lights-and-shapes/rule-25-sailing-vessels-underway-and-vessels-under-oars/ ---------------------------------------------------------------------------- From: r good <my… [at] hotmail.com> To: ca… [at] yahoogroups.com Sent: Mon, May 23, 2011 9:07:27 AM Subject: [Cal_Boats] running light combinations does anyone know if it is specifically prohibited to run a masthead tricolor at the same time as deck level running lights? Reggie __________ Information from ESET NOD32 Antivirus, version of virus signature database 6145 (20110523) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com __________ Information from ESET NOD32 Antivirus, version of virus signature database 6145 (20110523) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com __________ Information from ESET NOD32 Antivirus, version of virus signature database 6148 (20110524) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com __________ Information from ESET NOD32 Antivirus, version of virus signature database 6149 (20110524) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com
