5 messages2011-05-26 22:29 through 2011-05-27 00:53 UTC
Alternator Wiring
James2011-05-26 22:29
I'm slowly going through the engine and the alternator replacement is the current project.
It's a 2-29 with a Farymann...original engine panel....has anybody replaced the original motorola 35 amp and if so, where did the leads go?
I ended up with new positive to the house battery positive...negative to the engine ground and there I sit wondering about the other items...
Anybody have a schematic of the wiring for this type of improvement?
James
Re: [Cal_Boats] Alternator Wiring
Bob Virgalla2011-05-26 22:34 UTC
The other two are
AC output to the tach
DC input to the internal regulator. This line is on the on side of the key switch and can be tested accordingly.
For peace of mind you can always ohm out the other wire. Connects to the back of the tach.
Hope this helps.
Bob Virgalla
Cell:203.733.5006
~~~~_/)~~~~
> Thanks,
> James
> Yahoo! Groups Links
Frans Sell2011-05-26 23:32 UTC
Here's a diagram of my old Farymann setup. I've re-powered since then, but this
is what it looked like a few years ago.
Hope this helps,
Frans
Cal-29
Seattle, WA
Sent: Thu, May 26, 2011 3:29:51 PM
Subject: [Cal_Boats] Alternator Wiring
current project.
James
Re: Alternator Wiring
James2011-05-26 23:38
Thanks Fran....graphic a little fuzzy...what is the "blue wire" coming off of the alternator connection to....ignition?
> Hope this helps,
> Frans
> Cal-29
> Seattle, WA
> From: James <jamesbibb@...>
> current project.
> Thanks,
> James
Re: [Cal_Boats] Re: Alternator Wiring
Frans Sell2011-05-27 00:53 UTC
the blue wire goes from the alternator to the external regulator, then a wire
goes from there to the ignition switch, in my case it was brown.
You can click view "large" to see a little better.
Hope this helps,
Frans
Sent: Thu, May 26, 2011 4:38:40 PM
Subject: [Cal_Boats] Re: Alternator Wiring
> Hope this helps,
> Frans
> Cal-29
> Seattle, WA
> current project.
> Thanks,
> James
