Through Hull Damage 2-29
3 messages2011-05-31 15:21 through 2011-06-01 04:10
James2011-05-31 15:21
I ran over a King Crab float and lead....nicely brushed over the hull and keel and I went off without being hung up. I was on a broad reach running at hull speed. Soon Salt water was coming in from somewhere. We were able to get the engines started and head up-wind towards port 5 hour away....pumps worked and soon the water was out and the leak halted. Tried to sail again, salt water immediately. We were over on Port pretty hard, and in following the thru-hulls, isolated it to the speed indicator which has a small paddle wheel up next to the head 3/4" intake under the forward setee. Anybody damaged one of these things before an can I remove the paddle sensor while in the water to see if indeed my assumptions were correct?
Re: [Cal_Boats] Through Hull Damage 2-29
PAUL FREDRICK2011-06-01 03:46 UTC
mines a Raymarine and it came new with a plug so i could untread the wheel sensor and push the almost identical unit in its place to plug the hole minus the wheel and wire of course. then just thread the cap to surcure it. ths is done to clean the wheel unit and works very well also recall a friend of mine haveing the same setup 13 years ago so i feel this is not a new design so as long as you have the plug for yours or can look it up to see if you can buy it you should be good. Or if the waters not too cold jump in and take a look or use a rubber ball and string to plug hole. So if the back of your unit inside the haul has a threaded ring the answer should be yes its removable. but have a back up if you take it apart it may be facured and only staying togeather while its threaded and in worse case fall apart in your hands and not go back togeather but not very likly the case. good luck in any case. From: James <ja… [at] mac.com> To: Ca… [at] yahoogroups.com Sent: Tue, May 31, 2011 8:21:42 AM Subject: [Cal_Boats] Through Hull Damage 2-29 I ran over a King Crab float and lead....nicely brushed over the hull and keel and I went off without being hung up. I was on a broad reach running at hull speed. Soon Salt water was coming in from somewhere. We were able to get the engines started and head up-wind towards port 5 hour away....pumps worked and soon the water was out and the leak halted. Tried to sail again, salt water immediately. We were over on Port pretty hard, and in following the thru-hulls, isolated it to the speed indicator which has a small paddle wheel up next to the head 3/4" intake under the forward setee. Anybody damaged one of these things before an can I remove the paddle sensor while in the water to see if indeed my assumptions were correct?
Re: Through Hull Damage 2-29
James2011-06-01 04:10
Thanks everybody. I'm a bit more confident pulling the plug with all of your expertise. One of my friends suggested I place a toilet plunger over the exterior. Oh! Here's one for the learning department. Yours truly placed the forward sub branch panel and fluxgate compass in the same setee environment as this thru-hull. It looks as though my re-wiring project has a phase 2. --- In Ca… [at] yahoogroups.com, "James" <jamesbibb@...> wrote: > > I ran over a King Crab float and lead....nicely brushed over the hull and keel and I went off without being hung up. I was on a broad reach running at hull speed. > > Soon Salt water was coming in from somewhere. We were able to get the engines started and head up-wind towards port 5 hour away....pumps worked and soon the water was out and the leak halted. > > Tried to sail again, salt water immediately. We were over on Port pretty hard, and in following the thru-hulls, isolated it to the speed indicator which has a small paddle wheel up next to the head 3/4" intake under the forward setee. > > Anybody damaged one of these things before an can I remove the paddle sensor while in the water to see if indeed my assumptions were correct? >
