4 messages2011-06-12 15:00 UTCthrough 2011-06-12 15:38 UTC
exhaust back pressure
Bob Connell2011-06-12 15:00 UTC
Not sure if we have exhaust specialists but: My new engine this is being
installed has a 2" high rise exhaust elbow. 22 inches away the exhaust
hose would enter my wet muffler that is 1 1/2 inch diameter input and exit.
Re: [Cal_Boats] exhaust back pressure
Allen Edwards2011-06-12 15:13 UTC
No exhaust expert here buy what problem are you having that would make you
want to change anything? I think a 400 HP engine can work with a 2 inch
exhaust hose. Add some water and you might need a larger hose but why
bother.
I had my exhaust system replaced professionally and would get an engine full
of water after that. Let me tell you, it is very difficult to start an
engine that is full of water. I re-ran the exhaust hose to the highest
point in the transom and all is well. I had to learn more than I wanted
about exhausts before I did that. It is important that the volume of the
exhaust hose after the muffler be less than the capacity of the muffler.
Bigger is not always better.
> From that exit today there is then a gooseneck (length of hose @ 6 ft) to
> get well above the waterline and then to the stainless fitting out the
> transom. That fitting is 1 5/8 inches.
> Question: should I replace the muffler with 2 inch input/exit rather than
> reduce the short run of hose from 2 to 1.5? If I replace everything with 2
> " but reduce it at the transom to 1 5/8 inches, is the whole reduction thing
> for naught? Or must I replace the stainless fitting in the transom too and
> if so where would I find something like that? Thanks.
> Bob Connell
> "Jollygood!", Cal 31, #59
> Shilshole Bay, WA
Frans Sell2011-06-12 15:15 UTC
Hello Bob,
I reduced mine before it entered the muffler. I reduced whatever metric size exhaust hose to a 1 1/2".
Works great, however my engine is smaller than yours.
Frans
On Jun 12, 2011, at 8:00 AM, Bob Connell <jo… [at] yahoo.com> wrote:
> Not sure if we have exhaust specialists but: My new engine this is being installed has a 2" high rise exhaust elbow. 22 inches away the exhaust hose would enter my wet muffler that is 1 1/2 inch diameter input and exit.
Allen Edwards2011-06-12 15:38 UTC
May I suggest reading this before changing anything
http://viewer.zmags.com/publication/066ba269#/066ba269/49
> Bob Connell
> Shilshole Bay, WA
