Reggie, headstay diameter
3 messages2011-06-14 03:24 UTCthrough 2011-06-14 05:02 UTC
Helen Horn2011-06-14 03:24 UTC
We got to the papers, the headstay specs have been typed in as 9/32, 1x19 Stainless Steel, 42 feet and 1/4 inch. (I would slightly question this 1/4 as to an inch or a 1/4 of a foot? ) (since I wasn't the one who actually read the info) also says" Marine eye and 1/2 inch threaded shank. all dimensions center of eye to eye or end of threaded shank". Hopefully this helps. Helen
Re: [Cal_Boats] Reggie, headstay diameter
Helen Horn2011-06-14 03:49 UTC
in addition, after I doublechecked sailboat data .com. it looks like everythings the same, but as I see mistaken info here and there, I would question. i.e. it looks like the cc36 has a single spreader rig (in the pics) and our c36 has a doublespreader rig, which you can't see in the photo. according to this, our booms are 16.30 feet. I know ours is that dimension. No specs on the clevis pins. The weight is 12000 vs 11200, the water and fuel tanks are different to accomodate cruising. HH From: Helen Horn <he… [at] sbcglobal.net> To: Ca… [at] yahoogroups.com Sent: Mon, June 13, 2011 8:24:00 PM Subject: [Cal_Boats] Reggie, headstay diameter We got to the papers, the headstay specs have been typed in as 9/32, 1x19 Stainless Steel, 42 feet and 1/4 inch. (I would slightly question this 1/4 as to an inch or a 1/4 of a foot? ) (since I wasn't the one who actually read the info) also says" Marine eye and 1/2 inch threaded shank. all dimensions center of eye to eye or end of threaded shank". Hopefully this helps. Helen
RE: [Cal_Boats] Reggie, headstay diameter
r good2011-06-14 05:02 UTC
Yes, CC36 is single spreader rig. I was told the CC uses the heavier CAL 40 mast section. To: Ca… [at] yahoogroups.com From: he… [at] sbcglobal.net Date: Mon, 13 Jun 2011 20:49:28 -0700 Subject: Re: [Cal_Boats] Reggie, headstay diameter in addition, after I doublechecked sailboat data .com. it looks like everythings the same, but as I see mistaken info here and there, I would question. i.e. it looks like the cc36 has a single spreader rig (in the pics) and our c36 has a doublespreader rig, which you can't see in the photo. according to this, our booms are 16.30 feet. I know ours is that dimension. No specs on the clevis pins. The weight is 12000 vs 11200, the water and fuel tanks are different to accomodate cruising. HH From: Helen Horn <he… [at] sbcglobal.net> To: Ca… [at] yahoogroups.com Sent: Mon, June 13, 2011 8:24:00 PM Subject: [Cal_Boats] Reggie, headstay diameter We got to the papers, the headstay specs have been typed in as 9/32, 1x19 Stainless Steel, 42 feet and 1/4 inch. (I would slightly question this 1/4 as to an inch or a 1/4 of a foot? ) (since I wasn't the one who actually read the info) also says" Marine eye and 1/2 inch threaded shank. all dimensions center of eye to eye or end of threaded shank". Hopefully this helps. Helen
