5 messages2011-06-17 18:43 UTCthrough 2011-06-18 04:03 UTC
Re: [Cal_Boats] Holdimg tank
Lene Symes2011-06-17 18:43 UTC
Jeff,
I installed a rectangular 24 g tank under the v-berth platform of our CC 36 - bought the tank and other fittings from Maritime Sanitation in Seattle, I think a Ronco. It barely fits. I used the same setup as others have written about - head empties directly into the tank, discharge line Y-s to both a deck pump-out fitting and a hand-pump-to-seacock for overboard discharge offshore.
All fittings are on top of the tank - this is very important, as otherwise you have no chance of avoiding pools of sewage in the lines, which dramatically shortens their useful lives. Often spaces and shapes force you to run lines so that sewage sits in them anyway - if possible it's best to use rigid PVC for any such places.
I also have odor problems in the locker containing most of the hose (the head is a Lavac, which needs a big loop of 1.5" hose, so all of that went into the stbd locker next to the head), either hose or hand pump needs replacing, fortunately the locker tends to contain the smell. Otherwise the system has worked well for 5 years.
In my opinion, 1.5 in sani-hose is the most evil material devised by man.
Best of luck,
Bill Symes
S/V Sara E.
--- On Fri, 6/17/11, David Wilkie Owen <dw… [at] me.com> wrote:
Subject: Re: [Cal_Boats] Holdimg tank
Date: Friday, June 17, 2011, 12:52 PM
Jeff,
Well, I just was getting ready to send this and realized that you do not have a 29 and so many of my comments are overly specific to that model. If you go to Ronco's marine tank web page you can browse the dimensions of the tanks and try and figure out which one will work for you. Ask them for a discount when you order the tank, as I believe they probably still show retail prices on their web-catalog. I suggest you build a cardboard mock-up of any tank you want to consider and test that for fit before you order. Ronco will guide you through the placement of your hose fittings. http://www.ronco-plastics.com/newRonco/installation.php
I fit a 16 gallon tank from Ronco under the V-berth directly in front of the water tank
without doing any modifications to the v-berth deck. It was adequate.
Another Cal 29 owner, our own beloved Alfred Poor, fit a 25 gallon Ronco tank into the same space with easy modifications to the opening in the v-berth deck -- I hope I recall this properly. Alfred no longer owns the 29, but I believe he still monitors this list.My complaint was that the hoses were necessarily long and even the most expensive ones will become saturated and smell after a while. I plumbed a small hand pump mounted under the deck to port of the water tank so I could pump it out when off-shore. The pump was a source of odor in short order -- I am fanatical about head odors, so was unhappy with it. A purpose built for waste pump would have been better, but I have friends with those and they still get odorous after a while. I also plumbed a Y-valve into the discharge side hose but later decided it
wasn't necessary -- when hand-pumping the waste out, the deck fitting is screwed in so why would that be a problem?
After changing out all of the hoses a couple of times I decided to build a gravity tank that sits up behind the head. It only holds 15 gallons because I couldn't find a tank that fit the space very well. I've had some problems with that installation as well, but have figured it all out. If the waste sits in the tank very long it tends to plug up the discharge hose with enough solids that gravity is insufficient to drain it. I experimented with putting a little pressure into the tank (my inflatable hand pump just happens to fit the vent fitting on the tank) and that gets it started and out it goes. That is also very inconvenient as I won't discharge the tank unless I am well off-shore which means often rougher water and perching on the deck with the pump. A macerator discharge pump would solve this, of course, or maybe even a valve in the vent line that I could close to pressurize the tank. I would never
want to put too much pressure into the tank, however, for fear of blowing a hose off into the interior of the boat. I saw that happen to a friends boat out at the Islands one nice weekend. Ended their trip abruptly.
Another related issue to both of the above installations was that the brand of head that I had did not block waste seeping back into the toilet bowl, especially when the tank started getting full. I currently use an electric macerating head, which seems to prevent that from happening, but I also have noticed that many of the heads have a locking pump handle to prevent this as well.
Another of my boat friends installed a large rectangular tank under his settees and added a macerator pump for discharging it off-shore. It seems to work great but I don't see enough space on the 29 to do this.
So I am restless with my current system and am
getting myself geared up to either install the 25 gallon tank under the V-berth with rigid plumbing back to the head s!
ide of the front bulkhead and a macerator pump for discharge, or I am going to build my own epoxy tank that fits the shape of the hull and sits behind the head with either a gravity or macerator discharge option. Still thinking about this.
I like the idea of the tank under the v-berth because I waste that space otherwise as it's too hard to get to.
Hope these thoughts help you figure this out.
Wilkie
On Jun 17, 2011, at 6:58 AM, Jeff wrote:
Good morning
I have gotten to the point with my project Cal were I have to start thinking about a holding tank.
When I purchased the boat, it did not have a holding tank - the head was connected straight to a thru hull.
The rest of used water from shower, sink etc just flowed to the sump, and got pumped out when the float switch was triggered.
Anyway, I'd like suggestions as far as holding tank sources and advise on size, placement and what is required to go to the tank, if some or all the drain connections.
As usual, the group's help is always appreciated!
Best regards
Jeff
'72 Cal 33
Helen Horn2011-06-17 19:34 UTC
Jeff
Oh yeah!! use a HEAT GUN on the 11/2" sani-hose...(we've tried boilwater 5mins
in mincowave) also work gloves work off THE ROLL your tape messurments
seem to be too small when installing. Heat the inside hose,these hoses are only
good
for two years and should be changed or will stink (another reason not to put
tank in V-birth) also david and bill have great in sites ....solar fan in head
area helps to remove stink...edward (helen)
Sent: Fri, June 17, 2011 11:43:57 AM
Jeff,
any such places.
5 years.
Best of luck,
Bill Symes
S/V Sara E.
>From: David Wilkie Owen <dw… [at] me.com>
>Jeff,
>water tank without doing any modifications to the v-berth deck. It was
>adequate.
>but later decided it wasn't necessary -- when hand-pumping the waste out, the
>! After changing out all of the hoses a couple of times I decided to build a
>line that I could close to pressurize the tank. I would never want to put too
>well.
>So I am restless with my current system and am getting myself geared up to
>the head s! ide of the front bulkhead and a macerator pump for discharge, or I
>Wilkie
>Good morning
>connections.
>Best regards
>Jeff
>'72 Cal 33
Michael Kennedy2011-06-17 20:34 UTC
Remember that putting a gallon or two of vinegar into the holding tank
at the end of the season, or every couple of months if you have a long
season like California, will help a lot with the smell of a holding
tank. You can buy cheap vinegar in 5 gallon jugs. Just pour it down
the deck pump out fitting after flushing the tank. A lot of the bad
smell is actually marine growth in the salt water, not the sewage.
Mike Kennedy
On Jun 17, 2011, at 11:43 AM, Lene Symes wrote:
> Jeff,
> man.
> Best of luck,
> Bill Symes
> S/V Sara E.
> Jeff,
> front of the water tank without doing any modifications to the v-
> list.
> side hose but later decided it wasn't necessary -- when hand-pumping
> problem?
> abruptly.
> 29 to do this.
> plumbing back to the head s! ide of the front bulkhead and a
> about this.
> Wilkie
> Good morning
> Best regards
> Jeff
> '72 Cal 33
Chris Campbell2011-06-17 20:53 UTC
Vinegar also serves well to clean mildew and mold off surfaces and as a
general cleaning agent. I've used it in the interior on the overhead,
which gets moldy. Unlike bleach, it doesn't ruin clothing. It's the
best thing I've found for removing mineral build-up on the hull at
season's end. I used to polish away with an abrasive cleaner/polish,
thinking it was dull gelcoat. Then I tried vinegar and it just melts
away. I recommended it to a guy in the boat barn where my other boat
winters over and he was impressed too.
Jeff2011-06-18 04:03 UTC
Thanks to all for the feedback, I have a clear idea of were I want to go with the holding tank project!
Also appreciate the photos.
Best regards
Jeff
'72 Call 33
