3 messages2011-06-28 17:08 UTCthrough 2011-06-28 18:09 UTC
Re: [Cal_Boats] Lightning and bonded through hull sinks boat in Wisconsin.
pw… [at] aol.com2011-06-28 17:08 UTC
I think my Cal 39 may be bonded like that as well but it may just be the
chain plates to the keel. I've seen a good sized wire covered by at least
one layer of fiberglass near the chainplates but have not looked closely at
the thru hulls in some time. Hmmmmmm
Paul
In a message dated 6/28/2011 12:58:39 P.M. Eastern Daylight Time,
ch… [at] gmail.com writes:
Interestingly enough, my 78 CAL 3-29 came stock from the factory with all
thru hulls bonded and the bonding wire glassed into the hull. Not nice.
Gets who took out the gutting tools...:)
Allen Edwards2011-06-28 17:12 UTC
If you live where there is lightning you probably need some path for the
lightning to get to the water. That might go through the chainplates to the
keel, I have no idea. Good to not have the through hulls part of that path
though.
It is a complex issue given the presence of AC on a boat. You have three
competing issues, AC safety, metal safety, and lightning protection.
> Paul
> thru hulls bonded and the bonding wire glassed into the hull. Not nice. Gets
> /ch
chris1232011-06-28 18:09 UTC
Yup thats its exactly, and the three systems should not be tied together.
Like all things its simple once your understand it.
Aside from your article, which is great, Don Casey lays out the same. And
your right, no one wants to listen either, other then those lads heading
into the deep who even deploy faraday cages to protect their electronics,
when it starts to light up. In most cases the oven will do if outfitted with
such. But they rarely get hit, its the boats closer to shore that get pinged
and geographically trackable if you look at the data
On Tue, Jun 28, 2011 at 1:12 PM, Allen Edwards <
> Allen
