5 messages2011-07-14 01:34 through 2011-07-15 13:41 UTC
Boat Hull Animation - for fun
ryan_on_the_beach2011-07-14 01:34
Hey all, added a new boat hull animation to the site, just for fun/edu
interactive boat hull <http://www.psychosnail.com/infoboathull.aspx>
Let me know if you have any comments suggestions...
Thanks
Ryan
New deck? Cal 25
Kevin Swart2011-07-14 02:20 UTC
I would like to talk with somebody that has put a new deck on their Cal
25. There has been some conversation in the past on the Cal 25 site,
but my computer crashed and I lost the password to sign in. Their
recovery system doesn't seem to be working for me.
Looking forward to some questions answered.
Offlist is preferred: kgs-one-one-three (at) gmail-dot-com
you know what to do.
Thanks!
Kevin
1970 Cal 25 #1285
Re: [Cal_Boats] New deck? Cal 25
chris1232011-07-14 15:50 UTC
If there is a chance an on list discussion is always best even if its long
and protracted as everyone learns. There may be some deck issues that may
need attention on my 29. Im sure there are others.
On Wed, Jul 13, 2011 at 10:20 PM, Kevin Swart <kg… [at] earthlink.net> wrote:
> 25. There has been some conversation in the past on the Cal 25 site, but my
> computer crashed and I lost the password to sign in. Their recovery system
> Thanks!
> Kevin
> 1970 Cal 25 #1285
Kevin Swart2011-07-15 01:58 UTC
Happy to oblige.. I just didn't want to clutter the list too much. I've
been contacted by 2 list members and responded to one but I'll repost it
here so we can all join in the fun!
To let you know where I stand I have all of the plywood out except for
trace amounts of veneer still stuck to the old deck. I've been using a
wood chisel and wallpaper scraper. I don't know how clean I should have
the fiberglass. Should it be completely bare or will the little bits of
old veneer be fine left alone. Should the glass be roughed up? I built
a new beam last year- laminating White Oak and African Mahogany
together. All grain running the same direction. Prettiest piece of
wood nobody will ever see! I made the beam between 1/4 and 3/8 thicker
than the original. I've trimmed the bulkhead to address that. Old beam
is out so I will be able to get the ends cut to the proper angle and
length with no problem. Got 2 sheets of 3/8 Sapele from Boulter
plywood. Marine grade British standard stuff. I plan on covering the
bottom of the sheets with 4 oz glass with West system clear stuff.
I figure on putting the beam in place temporarily while the epoxy sets
then removing it to glass the plywood. Will I need to varnish the epoxy
after that or can I just go with the epoxy finish?
I have a few holes to patch. There was a vent hole portside forward and
a waste drain on the deck for a head that is long gone. Have gelcoat,
resin, glass mat and cloth. Patch holes first from the inside or do it
from the outside? Been thinking about that and I think from the outside
might be the better way to go. I'd like to get the non skid pattern in
there but the flexible molds for that are just too expensive.
Heavy duty cardboard to make templates to cut the plywood.
Planning on putting a hinged mast base so I don't have to rely on a gin
pole. The mast base is sealed from inside. there was one hole I
drilled through it a couple of years ago and the one hole for the old
wire for the running light. The base appears to be in good shape and I
don't really want to open it up. See any issues with that Idea? I'm on
Oneida Lake in New York so the boat has only seen fresh water.
So I guess my questions are how clean should the fiberglass be for the
epoxy bond?
Do I need to put varnish over the epoxy finish on the underside of the deck?
I expect that I'll have more questions as I get further into the
project! I can send you pics if you like.
I do plan on properly sealing every deck penetration so this never
happens again.
Looking forward to opinions and advice.
Kevin Swart
> long and protracted as everyone learns. There may be some deck issues
> that may need attention on my 29. Im sure there are others.
> /ch
Chris Campbell2011-07-15 13:41 UTC
> I've been contacted by 2 list members and responded to one but I'll
> repost it here so we can all join in the fun!
Here are my notions about your questions. First, cleanliness of the
underside of the deck before re-coring: Seems to me that you want it
smooth so the new plywood lies well against the underside of the deck.
A bit of remaining veneer, if well secured, won't matter much unless
it's thick and causes voids between deck and new core.
Second, as to varnishing epoxy, yes, do it. Most epoxies are not UV
stable. Gougeon Bros. makes a special coating hardener that's more
durable, but they still recommend varnish protection. Of course, that's
in exterior applications, and you're talking inside and even under-deck,
but I'd be inclined to use some UV-filter spar varnish anyway. It's
amazing how much reflected UV you get on the water. I have a tiny
summer cottage on Lake Huron's Saginaw Bay, and pictures on the wall can
fade rapidly from indirect sunlight reflection. It always surprises me.
Have fun.
