Black Dashed Lines (Again)
The Weather Channel did get back to me, and Allen gets the kewpie doll (unless he wants a stuffed teddy bear instead).
From: Tim [mailto:ti… [at] theweatherchannel.uservoice.com]
Sent: Wednesday, November 02, 2011 5:04 PM
To: Husar, Charlie [USA] (ASE)
Subject: Re: Black Dashed Lines
~~~ Reply above this line ~~~
The dashed black lines are "surface troughs." This type of boundary is an elongated area of low pressure that typically marks changes in wind direction and/or humidity. Temperature changes are usually modest with surface troughs.
Thanks for contacting us.
[Description: Image removed by sender. Kudos_sm_4b60b2]Give Tim kudos!<http://smtp.uservoice.com/wf/click?c=30xesndpxh8umw7wtXhiPEk0u7liN8w86v3ERGsznpaAP01C%2BtICb7JyL7IhWHYhKBVKDOXAc6XSnCeQiGyNzFVWJoTDjoB%2F7gxRM47rejyJUy3BZkRkD6EdY5wmMTsEnb%2FWcOnXLg4TX1P82E3V9SvoikkYYVzScsteQ04lwfA2%2FSsDbr0JuUqUoTyDfqOJS9yGF3vOGB1gqkky%2Bmk9yq5lbYTcqtFWbyKCxSwekVl1OnG2EnR2AU1rZXS7SojkHzJgDA3AV5lbDFTlDL8ILt1icbMlmlbfS41IfLGmf%2FDlj%2Fv%2FB9oIuEG00RsVmCFirCcb0t2eIGy%2BKwtckedBj0saXO1wNQtGb3zVZVfgOPI%3D&rp=C2YSM00rc0pbTk7jiak7THqgPXZPiVl1bRYXWL6DwmoMkkWBTJ%2FJ%2BMbWTmp7eLk75HHgdMiVsGytb419mShIIS8TWQlrfsAmWMxhHTiWthijTTtoloJZWq0qx4c%2BUUjp&up=WMLztlB6QyiGaIjT5SJci3ZBQ2%2B8mtilZJDzMQyZYsco6%2BuPgdQYgZVCqiNaih0KL9GVwvG9iiMfyicoKw0xRXa8UjnRXwa1IEpqrdHW0sUcrgjdIW%2BuydIm%2FZbiWLB6&u=GZgu6pkvS4a40ifjGIc3Pw%2Fh0> Kudos help us rate how well we're supporting you.
On October 29, 2011 at 02:59AM Charlie Husar <hu… [at] bah.com<mailto:hu… [at] bah.com>> wrote:
What do the black dashed lines (look like fronts) on the national weather map mean? I know the reds and blues, but the black lines are not explained.
Thanks
This email notification was intended for hu… [at] bah.com.
[Description: Image removed by sender.]
