4 messages2011-12-06 03:32 through 2011-12-09 17:04 UTC
Westerbeke w30 Glow plugs
dasiel2011-12-06 03:32
Hi I have a Cal 34III with a Westerbeke w30 and I need to replace the glow plugs. I am having a hard time finding something comparable here in the states all website I find send me to UK. Does anybody no of a plug that I can use as a substitute and is easy found here?
Thanks
Dissel
Re: [Cal_Boats] Westerbeke w30 Glow plugs
Jake Tanley2011-12-07 13:55 UTC
Did you check Torresen Marine?
http://shop.torresen.com/marine_diesel_direct/Westerbeke/
--- On Tue, 12/6/11, dasiel <di… [at] hotmail.com> wrote:
Subject: [Cal_Boats] Westerbeke w30 Glow plugs
Date: Tuesday, December 6, 2011, 3:32 AM
Thanks
Dissel
Re: Westerbeke w30 Glow plugs
Danny2011-12-08 14:14
I have the same engine and concern. I wrote Westerbeke directly and this was their reply":
"Hello Danny,
The W30 was last produced in 1981. The base engine used for that model went out of production about the same time.This was the British Leyland 1.5 litre diesel.
Internal parts for the engine are becoming difficult to find as many are now no longer produced by British Leyland.
The Westerbeke Distributor in Portland "Cook Engine Company" tel. (503) 289-8466 can check the availability of engine parts for you and advise you.
To the best of my knowledge the engine was used to power many British taxi cabs. I do not know if it was used in tractors or the like, but I would presume it most likely was.
Kind Regards,
Westerbeke Corp."
Footnote: The aforementioend Cook Engine Company disavows any ability to get pats for our engines. Might be time to talk with Joe.
Danny
> Thanks
> Dissel
Sv… [at] optonline.net2011-12-09 17:04 UTC
I had a 1977 Cal 34 III with same engine. I was having problems with glow plugs as well. However before I replaced them I checked the wiring... One of the wires had come apart at a splice so no power was getting to the plugs. Respliced and all worked great. I would check the power supply to the glow plugs if you have not done so already.
Good Luck
Greg
Date: Monday, December 5, 2011 10:32 pm
> Thanks
> Dissel
