17 messages2012-01-23 00:27 UTCthrough 2012-01-29 22:34 UTC
Cal 36 parts
Michael Robinson2012-01-23 00:27 UTC
Is anyone interested in a tiller yoke and rudder post head? Will fit Cal 36 and probably Cal 40
Mike Robinson
Holiday
Re: [Cal_Boats] Cal 36 parts [2 Attachments]
Fred Haas2012-01-23 01:04 UTC
Mike, If it will fit the 3-30, I'm interested. Mine has an incredible
amount of slop in it. I will be able to get to the boat in the next
day or so and take measurements. What is the distance between the
tangs, and the diameter of the rudder post?
Fred Haas
3-30 Nemesis
Tacoma
On Jan 22, 2012, at 4:27 PM, Michael Robinson wrote:
> [Attachment(s) from Michael Robinson included below]
> Mike Robinson
> Holiday
Adam Thorp2012-01-23 17:51 UTC
Mike,
I too, am interested. The tiller head/yoke on my cal 28 has too much slope
in it as well. If Fred does not take it/buy it, I would jump at the chance.
Adam
> amount of slop in it. I will be able to get to the boat in the next day or
> so and take measurements. What is the distance between the tangs, and the
> Fred Haas
> 3-30 Nemesis
> Tacoma
> Mike Robinson
> Holiday
RE: [Cal_Boats] Cal 36 parts
r good2012-01-23 18:26 UTC
I found that there was not enough rise in my tiller handle to keep the head/yoke engaged. I noted no play when the tiller was in its lowest position. Solution? new tiller with higher rise to suit my height so head/yoke stayed fully engaged. cheap and pretty!
Date: Mon, 23 Jan 2012 09:51:26 -0800
Subject: Re: [Cal_Boats] Cal 36 parts
Mike,
I too, am interested. The tiller head/yoke on my cal 28 has too much slope in it as well. If Fred does not take it/buy it, I would jump at the chance.
Adam
Mike, If it will fit the 3-30, I'm interested. Mine has an incredible amount of slop in it. I will be able to get to the boat in the next day or so and take measurements. What is the distance between the tangs, and the diameter of the rudder post?
Fred Haas
3-30 Nemesis
Tacoma
Mike Robinson
Holiday
Husar, Charlie [USA] (ASE)2012-01-23 19:05 UTC
Several items related to the size of rudder tubes and slop in the tiller.
First, I'm sure the 36/40 collar will not fit the 28 and I doubt it will fit the 30. Rudder tube is fatter on the bigger boats.
Second, numerous methods have been proposed to take the slop out of a tiller/rudder.
Some have put holes in the sides of the fiberglas tube, and injected epoxy (with some lubrication into the column. I know a guy who did this on his 25 and thus learned that his steel rudder post was just a weeee bit crooked. It took us several days to get the damned thing out.
Some have mounted oilite (or roller) bearings top (and in cases the bottom) in the tube column. Effective, but not trivial. As far as the oilites (I think that was the name of the material) go, as Barlow (or was it Barient?) used to be able to attest, the iolite material can swell when greased. They tried this bearing surface inside winches instead of rollers, and had to recall them all. I had some. The more you lubricate them the tighter they got.
One can get vertical play out of the rudder by putting discs of plastic above the rudder underneath, and/below the rudder cap above. I make them from mylar using two different sized hole saws. The one between the hull and rudder is useful in preventing scraping as well as shimming out the play.
My favorite trick is to wrap a piece of plastic from a smooth sided 2 liter soda bottle most of the way around the rudder post with some grease on it as I push the rudder up into place. It slides on up into the tube. Use two if you have to. Takes out a lot of play.
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Adam Thorp
Sent: Monday, January 23, 2012 12:51 PM
Mike,
Adam
Fred Haas
3-30 Nemesis
Tacoma
Mike Robinson
Holiday
Adam Thorp2012-01-23 20:08 UTC
Charlie,
The suggestions you have made seem to be to fix any slop associated with
the rudder shaft. My rudder shaft is well constrained in 5 of its 6 degrees
of freedom. It can rotate and only rotate.
All of the sloppiness in my tiller arrangement is a result of the
interaction between the two parts pictured above. I suppose the proper
terms are tiller yoke and tiller post?
The tiller 'yoke' is simply two flat bronze bars (NOT like the picture).
Two through bolts into the tiller and a third bolt serves as the axle
connection to the tiller post. That axle has a lot of slop in it and so I
drilled out the bore a bit and machined a stainless sleeve. It has helped
quite a bit but I am still getting unwanted deflection in the tiller yoke.
Adam
On Mon, Jan 23, 2012 at 11:05 AM, Husar, Charlie [USA] (ASE) <
> First, I’m sure the 36/40 collar will not fit the 28 and I doubt it will
> fit the 30. Rudder tube is fatter on the bigger boats.****
> tiller/rudder.****
> crooked. It took us several days to get the damned thing out.****
> them the tighter they got.****
> play.****
> Use two if you have to. Takes out a lot of play.****
> Cheers****
> Charlie****
> Behalf Of *Adam Thorp
> *Sent:* Monday, January 23, 2012 12:51 PM
> *Subject:* Re: [Cal_Boats] Cal 36 parts****
> Mike,****
> Thanks,****
> Adam****
> On Sun, Jan 22, 2012 at 5:04 PM, Fred Haas < > wrote:****
> diameter of the rudder post?****
> Fred Haas****
> 3-30 Nemesis****
> Tacoma****
> On Jan 22, 2012, at 4:27 PM, Michael Robinson wrote:****
> Mike Robinson
> Holiday****
Helen Horn2012-01-24 05:02 UTC
Mike and Dianne, I hope the Moody is a step up, other than larger, but your plans sound like a nice jump into the next part of your life. We have a cal 36 in Redwood City(soon to be hauled out for bottom paint) and if it doesn't work for the other boats, we could use it. But the big question, who did your nice railings and bow pulpit for Holiday? We have to replace our bow pulpit completely(did you already tell us in an earlier mail?) We like the gate positions also. Just got her into Latitude and now she's going?? tell the new owners about the cal list and hopefully they will be in on a future Caltopia. Helen and Edward (hull#60)
To: Cal boats List <ca… [at] yahoogroups.com>
Sent: Sunday, January 22, 2012 4:27 PM
Subject: [Cal_Boats] Cal 36 parts [2 Attachments]
Mike Robinson
Holiday
Michael Robinson2012-01-24 18:00 UTC
Hello Helen and Edward,
We are excited about the adventure. The Moody is a very nice boat (photos attached)
The rudder/tiller parts are no charge, still available. Need someone to pick them up or pay pastage.
Holiday hand rails: I love them. Metal Magic in Oakland (Craig) made them. The bow pulpit was a single tube version on the boat when I purchased. Craig at Metal Magic added the second rail. He did make up a bow pulpit for Richardd Clopton, Cal 40 XL.
Craig is very good and easy to work with. The gates and stanchions are Garhauer.
I remember your 36 purchase, did you sell your Cal 29??
Cheers,
Mike
Date: Mon, 23 Jan 2012 21:02:39 -0800
Mike Robinson
Holiday
Re: [Cal_Boats] Cal 36 parts [3 Attachments]
Helen Horn2012-01-24 19:12 UTC
yes, we sold our 29 Noah's Kid to a friend to whom we sold a catalina 22 before he got tsunamied in Santa Cruz, didn't get destroyed but took a beating. He works in Sausalito, and has sailing friends there so he bought the 29 and the friends are helping him sail it there and he probably saves a few nights of commuting back and forth during the week to Santa Cruz. It was hard to part with, but the larger boat was what we were working toward, and the 36 turns on the dime like the 29, we love it, but are still working on it, putting in new fuel tank, refinishing the interior(ceiling boards revarnishing) and upholstery. We are helping the potential new owner of the 30 we bought to sell (for the canvas maker who had to move back to socal to care for elderly parents) do a haulout and survey in Berkeley:sailing up Thursday, hauling Friday, plus bottom paint. So, Edward will be in Oakland on Wednesday, probably too late into Berkeley on Thursday, and then any
time on the weekend. What would be best for you for him to come pick up the pieces? His number is 650-771-1945. Thank you..have you gotten any bites on Holiday? Helen
Sent: Tuesday, January 24, 2012 10:00 AM
Subject: RE: [Cal_Boats] Cal 36 parts [3 Attachments]
Cheers,
Mike
Mike Robinson
Holiday
Michael Robinson2012-01-24 19:19 UTC
Helen,
Sorry for the confusion. Charlie Husar had already laid claim to the parts. I misunderstood an email. My apologies.
Mike Robinson
(916) 705-3200
Date: Tue, 24 Jan 2012 11:12:47 -0800
yes, we sold our 29 Noah's Kid to a friend to whom we sold a catalina 22 before he got tsunamied in Santa Cruz, didn't get destroyed but took a beating. He works in Sausalito, and has sailing friends there so he bought the 29 and the friends are helping him sail it there and he probably saves a few nights of commuting back and forth during the week to Santa Cruz. It was hard to part with, but the larger boat was what we were working toward, and the 36 turns on the dime like the 29, we love it, but are still working on it, putting in new fuel tank, refinishing the interior(ceiling boards revarnishing) and upholstery. We are helping the potential new owner of the 30 we bought to sell (for the canvas maker who had to move back to socal to care for elderly parents) do a haulout and survey in Berkeley:sailing up Thursday, hauling Friday, plus bottom paint. So, Edward will be in Oakland on Wednesday, probably too late into Berkeley on Thursday, and then any time on the weekend. What would be best for you for him to come pick up the pieces? His number is 650-771-1945. Thank you..have you gotten any bites on Holiday? Helen
Cheers,
Mike
Mike Robinson
Holiday
r good2012-01-24 19:31 UTC
he wants the whole 36 to add to his collection!
To: ca… [at] yahoogroups.com
Date: Tue, 24 Jan 2012 19:19:26 +0000
Helen,
Mike Robinson
(916) 705-3200
Cheers,
Mike
Mike Robinson
Holiday
Fred Haas2012-01-24 19:39 UTC
Mike,
The width of the casting that my tiller head slips over is 1 7/8".
The outside diameter of the rudder head casting is 3 1/4". If these
are consistent with your pieces I'd sure like to get them. My
challenge is that the I.D. of the tang on the rudder casting is worn
so that I have almost 6" of endplay on the tiller before the rudder
moves. I have thought about attempting to crush the ends of the tang
to close the 1/16" or so gap, or possibly taking the two pieces to a
machine shop and having them built up and remachined. What does the
group think? Another question, is my rudder likely to sink or float
if I remove the head casting to deal with this challenge?
Fred Haas
3-30 Nemesis
Tacoma
> Mike Robinson
> Holiday
Helen Horn2012-01-25 01:43 UTC
Thanks anyway, some of those replies were confusing to us also, so we thought we had better not delay a response. It's good of you to share these things (irreplaceable parts) rather than toss them. Helen
Sent: Tuesday, January 24, 2012 11:19 AM
Helen,
Mike Robinson
(916) 705-3200
Cheers,
Mike
Mike Robinson
Holiday
Fred Haas2012-01-25 15:41 UTC
Mike, I was able to get to Nemesis yesterday. The width of the casting at
the pivot point on my rudder head is 1 7/8" The distance between the tangs
on the tier bracket is enough wider that have 4-6" play at the end of the
tiller. While I could't get at the rudder post itself, the width of the top
casting at he top of the post is 3 1/4". If these dimensions are consistent
with your pieces, I'd sure like to have them.
Fred Haas
3-30 Nemesis
Tacoma
On Tue, Jan 24, 2012 at 10:00 AM, Michael Robinson <
mi… [at] hotmail.com> wrote:
> [Attachment(s) <#13510e06d8526f47_TopText> from Michael Robinson
> included below]
> attached)
> Garhauer.
> Cheers,
> *Mike*
> From: he… [at] sbcglobal.net
> *From:* Michael Robinson <mi… [at] hotmail.com>
> *To:* Cal boats List <ca… [at] yahoogroups.com>
> *Sent:* Sunday, January 22, 2012 4:27 PM
> *Subject:* [Cal_Boats] Cal 36 parts [2 Attachments]
> Mike Robinson
> Holiday
Michael Robinson2012-01-25 16:18 UTC
I'm sorry Fred, Charlie Husar in Annapolis claimed the parts.
They are on the way to him. I'm not sure if he has an immediate need or not, might want to check with him.
Mike
Date: Wed, 25 Jan 2012 07:41:24 -0800
Mike, I was able to get to Nemesis yesterday. The width of the casting at the pivot point on my rudder head is 1 7/8" The distance between the tangs on the tier bracket is enough wider that have 4-6" play at the end of the tiller. While I could't get at the rudder post itself, the width of the top casting at he top of the post is 3 1/4". If these dimensions are consistent with your pieces, I'd sure like to have them.
Fred Haas
3-30 Nemesis
Tacoma
On Tue, Jan 24, 2012 at 10:00 AM, Michael Robinson <mi… [at] hotmail.com> wrote:
Cheers,
Mike
Mike Robinson
Holiday
Husar, Charlie [USA] (ASE)2012-01-29 20:33 UTC
Fred, I now have the parts from Mike. The interior width of the fork is 2-1/2 inches, and the OD of the rudder tube is 3-1/2". I got the parts from Mike with hopes to use them on a CAL 40. Looks like they will work.
Take Care
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Fred Haas
Sent: Tuesday, January 24, 2012 2:39 PM
Mike,
The width of the casting that my tiller head slips over is 1 7/8". The outside diameter of the rudder head casting is 3 1/4". If these are consistent with your pieces I'd sure like to get them. My challenge is that the I.D. of the tang on the rudder casting is worn so that I have almost 6" of endplay on the tiller before the rudder moves. I have thought about attempting to crush the ends of the tang to close the 1/16" or so gap, or possibly taking the two pieces to a machine shop and having them built up and remachined. What does the group think? Another question, is my rudder likely to sink or float if I remove the head casting to deal with this challenge?
Fred Haas
3-30 Nemesis
Tacoma
Mike Robinson
Holiday
Fred Haas2012-01-29 22:34 UTC
Use them in good health!
Fred Haas
3-30 Nemesis
Tacoma
> fork is 2-1/2 inches, and the OD of the rudder tube is 3-1/2”. I
> Take Care
> Charlie
> Mike,
> challenge?
> Fred Haas
> 3-30 Nemesis
> Tacoma
> Mike Robinson
> Holiday
