15 messages2012-02-03 19:28 through 2012-02-04 03:52 UTC
Vire engine, transmission slips?
vegasrigger2012-02-03 19:28
Hello Group!
I was hoping you might offer me a bit of guidance.
When I put my engine into forward gear and throttle up, the rpms come way up, then over about 4 seconds the engine begins to load up and the boat starts to make way.
At first I suspected that the prop was cavitating, but the more I examine, the more I think it is the transmission slipping.
What to do?
Thanks!
Darcy
Cal 27 PT
Re: [Cal_Boats] Vire engine, transmission slips?
scott cyphers2012-02-03 19:31 UTC
Is it a Hurth transmission? Sounds just like what I had. Reverse worked fine forward not so much. I ended up buying a new transmission from Joe Demers. Everything is great now.
Scott
74 cal29
Hatikvah
--- On Fri, 2/3/12, vegasrigger <da… [at] gmail.com> wrote:
Subject: [Cal_Boats] Vire engine, transmission slips?
Date: Friday, February 3, 2012, 11:28 AM
Hello Group!
What to do?
Thanks!
Darcy
Cal 27 PT
Re: Vire engine, transmission slips?
vegasrigger2012-02-03 19:42
That's exactly what I'm experiencing.
I was hoping it was something I might fix.
Any idea if this will fail gradually?
> Scott
> 74 cal29
> Hatikvah
> --- On Fri, 2/3/12, vegasrigger <darcyawood@...> wrote:
> From: vegasrigger <darcyawood@...>
> Â
> Hello Group!
> What to do?
> Thanks!
> Darcy
> Cal 27 PT
Re: [Cal_Boats] Re: Vire engine, transmission slips=?UTF-8?B?Pw==?=
Mike McElhaney2012-02-03 20:26 UTC
Darcy,
I have seen a Hurth tyranny pull that stunt before. It turned out that the shifter mechanism was sticky and the gear was not fully engaged. This is an easy fix if this is the problem. Ensure that the cable throws far enough to fully engage. It should slide smoothly also. There should be an adjustment nut on the cable where it attaches to the lever. Adjust it in the way that makes the most sense. Hope this helps. The folks here may have some other, better solutions. They're a good group of fart smellers.
Sent: Fri, Feb 3, 2012 19:43:03 GMT+00:00
Subject: [Cal_Boats] Re: Vire engine, transmission slips?
> Scott
> 74 cal29
> Hatikvah
> Â
> Hello Group!
> What to do?
> Thanks!
> Darcy
> Cal 27 PT
Yahoo! Groups Links
Re: [Cal_Boats] Re: Vire engine, transmission slips?(Mike)
Gerald Sobel2012-02-03 21:03 UTC
Mike..fart smellers?
How about just reading the results of gas chromatography, or maybe the digital computerized version which must have replaced what I seen used 40 yars ago. How 'bout, just calling us: bildge sniffers? Reminds me of the noxious looking brown liquid I tasted to see whether is was from rain water or sea water when I had Shpritz on the hard, after buying her and innocently taking her down to Annacappa Marine for a quick haul and pressure wersh. Me credit card balances have never been the same.
Aarrgh.
Sent: Friday, February 3, 2012 12:26 PM
Subject: Re: [Cal_Boats] Re: Vire engine, transmission slips?
Darcy,
>> Scott
>> 74 cal29
>> Hatikvah
>> --- On Fri, 2/3/12, vegasrigger wrote:
>> From: vegasrigger
>> Â
>> Hello Group!
>> What to do?
>> Thanks!
>> Darcy
>> Cal 27 PT
>Yahoo! Groups Links
>*> To visit your group on the web, go to:
>http://groups.yahoo.com/group/Cal_Boats/
>*> Your email settings:
>Individual Email | Traditional
>*> To change settings online go to:
>http://groups.yahoo.com/group/Cal_Boats/join
>(Yahoo! ID required)
>*> To change settings via email:
>*> To unsubscribe from this group, send an email to:
>*> Your use of Yahoo! Groups is subject to:
>http://docs.yahoo.com/info/terms/
Nick2012-02-03 21:20
OK Boys,
Enough of the toilet humor.
Moderator
--- In Ca… [at] yahoogroups.com, Gerald Sobel <sobel_solar@...> wrote:
> Mike..
Re: [Cal_Boats] Re: Vire engine, transmission slips=?UTF-8?B?PyhNaWtlKQ==?=
Mike McElhaney2012-02-03 21:40 UTC
Its called a head on a sailboat. But message received.
Sent: Fri, Feb 3, 2012 21:20:49 GMT+00:00
Subject: [Cal_Boats] Re: Vire engine, transmission slips?(Mike)
OK Boys,
Moderator
> Mike..
Yahoo! Groups Links
RE: [Cal_Boats] Re: Vire engine, transmission slips?(Mike)
Harleigh Ewell2012-02-03 22:08 UTC
It’s an anagram of “smart fellers.”
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Mike McElhaney
Sent: Friday, February 03, 2012 4:40 PM
Subject: Re: [Cal_Boats] Re: Vire engine, transmission slips?(Mike)
OK Boys,
Moderator
--- In Ca… [at] yahoogroups.com, Gerald Sobel wrote:
> Mike..
Yahoo! Groups Links
RE: [Cal_Boats] Re: Vire engine, transmission slips=?UTF-8?B?PyhNaWtlKQ==?=
Mike McElhaney2012-02-03 22:46 UTC
That's what was meant. Figured most folks would have clued in on that. My apologies to anyone who may have had their delicate constitutions ruffled.
Sent: Fri, Feb 3, 2012 22:08:19 GMT+00:00
Subject: RE: [Cal_Boats] Re: Vire engine, transmission slips?(Mike)
OK Boys,
Moderator
> Mike..
Yahoo! Groups Links
Ca… [at] yahoogroups.com2012-02-03 22:55
I thought closer to a Spoonerism:
http://en.wikipedia.org/wiki/Spoonerism
but, regrettably, it immediately attracted several (deleted) comments not quite so subtle...
Moderator
--- In Ca… [at] yahoogroups.com, "Harleigh Ewell" <hpe@...> wrote:
> Itâs an anagram of âsmart fellers.â
Re: [Cal_Boats] Re: Vire engine, transmission slips?(Back on Topic)
mike2012-02-03 23:05 UTC
And since we are a boating site, we can call it a "Schoonerism". (Insert
punful groan here...).
At any rate, back to the real topic; Does anyone else have info that may
help Darcy and her transmission woes?
I think her symptoms could also be caused by a line wrapped just right
on the prop shaft...?
Mike
> Moderator
> --- In Ca… [at] yahoogroups.com, "Harleigh Ewell"<hpe@...> wrote:
>> It’s an anagram of “smart fellers.�
Joe DeMers2012-02-03 23:06 UTC
Is this a Vire 6 or Vire 7 engine?
*Joe DeMers - owner*
Sound Marine Diesel LLC
*phone & fax (860) 666-2184*
> Mike
>> Moderator
> Yahoo! Groups Links
> No virus found in this message.
> Version: 2012.0.1901 / Virus Database: 2109/4174 - Release Date: 01/29/12
Vire engine, transmission problem and options
Joe DeMers2012-02-03 23:32 UTC
The Vire transmission is unique to Vire engines. Repair parts are
impossible to find, and Westerbeke no longer supports this old engine.
MAYBE the transmission can be repaired by making the needed parts, along
with a large dose of luck.
Looks like a repower is in your future.
The least expensive option is outboard power, then a used inboard diesel
or gas engine, then a new diesel engine.
Your boat has everything needed for an inboard installation, such as
prop shaft, fuel system, engine bed, etc already installed. It would be
a straightforward process to repower with an inboard engine.
> *Joe DeMers - owner *
> *phone & fax (860) 666-2184 *
>> Mike
>> On 2/3/2012 5:55 PM,Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> wrote:
>>> Moderator
>>> --- In… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com>, "Harleigh Ewell"<hpe@...> <mailto:hpe@...> wrote:
>> Yahoo! Groups Links
>> Checked by AVG -www.avg.com <http://www.avg.com>
> Checked by AVG - www.avg.com <http://www.avg.com>
Gerald Sobel2012-02-04 03:47 UTC
Oh, I forgot I missed the point I was trying to make, regarding sniffing out the problem, after a fashion. The nasty brown water pooled in the bilge tasted very salty, and sure enuff, I found a hairline crack near where the keel joined the hull. After I pumped out the bildge with a plunger pump that came with the boat, I found huge rock candy sized salt crystals. Apparently the leak was so slow it was evaporating as fast as it was leaking. And so salty there was no dry rot, of course.
Gerald Sobel2012-02-04 03:52 UTC
Moderator, I'm impressed. I always suspected this group was pretty high brow; Spoonerism. Nevah even hoid of that and I thought me English education has been pretty thorough!
From: "Ca… [at] yahoogroups.com" <Ca… [at] yahoogroups.com>
Sent: Friday, February 3, 2012 2:55 PM
Moderator
