11 messages2012-02-08 20:25 UTCthrough 2012-02-09 12:31 UTC
advice on repairing polyethylene tank....
bill plywaski2012-02-08 20:25 UTC
Hi Everyone,
Good Morning.
My polyethylene water tank has a small crack at the top; I would appreciate advice on how to repair it given that most anything that I can think of will not adhere to its surface....Thank You. Fair Winds And Following Seas. Bill (for off contact: ph#: 303-444-2307
Re: [Cal_Boats] re: advice on repairing polyethylene tank....
Chris Campbell2012-02-08 21:16 UTC
On 2/8/2012 3:25 PM, bill plywaski wrote:
> Hi Everyone,
> Good Morning.
Gougeon Bros. (West System epoxies) have a technique for using epoxy on
plastics. It involves use of a propane torch waved lightly over the
surface just before applying the adhesive. It apparently oxidizes the
plasticizers that interfere with adhesion. Check their web site for
info. I have used epoxy to repair a very old Thetford Porta-Potti lower
(sewage) tank. This was before the Gougeon process was devised. I just
roughed it up and applied epoxy and fiberglass. It has endured--I'm
using that Porta-Potti on my Cal 20. I just try to avoid stressing the
corners, where the patches are. I think it's a polyethylene plastic.
The consequences of a leak at the bottom of a Porta-Potti are much worse
than those for a leak on the top of a fresh water tank, I'll observe.
Gerald Sobel2012-02-08 21:21 UTC
Bill,
I'm thinking two things. First, there are epoxies that are supposed to adhere to plastic, possibly, also, West System's G-Flex, consult them. I've seen epoxies coming in tubes, in hardware stores, that say they will stick to plastic.
The other thing is that possibly you could mend it with a heat gun, and lastly, a rubber patch and some super high quality instant glue. Urethane sealant/caulking is also worth a try, or even Silicone II.
Have fun. I betcha any one of these may work. Oh yeah, ask Mr. Google.
Sent: Wednesday, February 8, 2012 12:25 PM
Subject: [Cal_Boats] re: advice on repairing polyethylene tank....
Hi Everyone,
Good Morning.
Chris Campbell2012-02-08 21:50 UTC
In the old days, downhill skis had a PE bottom and there were melt-in
patches for repairing encounters with rocks. I don't know about current
ski technology but maybe they still make that stuff?
Allen Edwards2012-02-08 21:53 UTC
I believe that these are repaired by welding them which is basically taking
a piece of the same material and an old fashioned soldering iron (like from
75 years ago, and melting the new material into the tank. I had it done on
a holding tank on my motor home when I set the thing down on a curb before
the air suspension was pumped up. I have tried it and there is a little
skill to it (which I lacked).
On Wed, Feb 8, 2012 at 12:25 PM, bill plywaski <se… [at] yahoo.com>wrote:
> Hi Everyone,
> Good Morning.
ro… [at] charter.net2012-02-08 22:36 UTC
Shoe goo adhesive also can work on a roughed surface
Sender: Ca… [at] yahoogroups.com
Date: Wed, 08 Feb 2012 16:16:47
Reply-To: Ca… [at] yahoogroups.com
Subject: Re: [Cal_Boats] re: advice on repairing polyethylene tank....
> Hi Everyone,
> Good Morning.
Re: advice on repairing polyethylene tank....
old.spicecal2012-02-08 23:13
Bill,
I purchased a 79' Cal 34-3, had the survey done, purchased the boat and then discovered to my dismay that the PO left me a few items the surveyor did not catch. Two cracks in the 60 gal. Polyethylene water tank, one near the bottom and one large one by the filler inlet. I borrowed a Plastic welder and the poly rod to go with it from a friend. I cannot imagine a better fix. I work in the plastics business and nothing in the chemical world will stick to it besides parent material. Check out Harbor Freight or McMaster Carr for the equipment.
I showed it to the guys in the marina and they could not believe it.
Bob
--- In Ca… [at] yahoogroups.com, bill plywaski <seafarergroup@...> wrote:
> Hi Everyone,
> Good Morning.
RE: [Cal_Boats] re: advice on repairing polyethylene tank....
ti… [at] ch2m.com2012-02-08 23:17 UTC
Would an "Inspection port" work - is the area flat?
[Screw-Out Deck Plate by Beckson]
Cheers,
[cid:image005.png@01CBF93B.85770E70]
Timm Lessley
503.863.4019 Cell to cell calls
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of ro… [at] charter.net
Sent: Wednesday, February 08, 2012 3:36 PM
Date: Wed, 08 Feb 2012 16:16:47 -0500
ReplyTo: Ca… [at] yahoogroups.com
Hi Everyone,
Good Morning.
Gougeon Bros. (West System epoxies) have a technique for using epoxy on plastics. It involves use of a propane torch waved lightly over the surface just before applying the adhesive. It apparently oxidizes the plasticizers that interfere with adhesion. Check their web site for info. I have used epoxy to repair a very old Thetford Porta-Potti lower (sewage) tank. This was before the Gougeon process was devised. I just roughed it up and applied epoxy and fiberglass. It has endured--I'm using that Porta-Potti on my Cal 20. I just try to avoid stressing the corners, where the patches are. I think it's a polyethylene plastic. The consequences of a leak at the bottom of a Porta-Potti are much worse than those for a leak on the top of a fresh water tank, I'll observe.
Husar, Charlie [USA] (ASE)2012-02-08 23:47 UTC
Geez, Timm. I got 37 of those in my boat already. Anybody need anything fixed?
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of ti… [at] ch2m.com
Sent: Wednesday, February 08, 2012 6:17 PM
Subject: RE: [Cal_Boats] re: advice on repairing polyethylene tank....
[Description: Screw-Out Deck Plate by Beckson]
Cheers,
[Description: cid:image005.png@01CBF93B.85770E70]
Timm Lessley
Hi Everyone,
Good Morning.
ti… [at] ch2m.com2012-02-08 23:58 UTC
Well heck Charlie, I'm currently in the (Canadian) arctic.. gotta keep myself amused somehow.
Just thinking fixing it might include a mechanical (verses welding, gluing solution)... which I have very low confidence in.
I have welded poly pipe, with an air welder "heat gun" and plastic rods.. sorta like
[http://www.entegrisfluidhandling.com/Photos/Zoom/Welding1.gif]
Just be prepared for failure, incompatible materials oil, dirt... a mechanical clamped solution might be the best solution for the DIYer.
The best solution is a new tank.
Cheers,
Timm Lessley
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Husar, Charlie [USA] (ASE)
Sent: Wednesday, February 08, 2012 4:48 PM
Cheers,
Timm Lessley
Hi Everyone,
Good Morning.
Joe DeMers2012-02-09 12:31 UTC
I believe that West Systems G Flex will repair your tank.
*Joe DeMers - owner*
Sound Marine Diesel LLC
*phone & fax (860) 666-2184*
> Hi Everyone,
> Good Morning.
> No virus found in this message.
> Checked by AVG - www.avg.com <http://www.avg.com>
> Version: 2012.0.1901 / Virus Database: 2109/4174 - Release Date: 01/29/12
> Internal Virus Database is out of date.
